Thread: noobie
thanks for the input guys , may bin the mdf idea seen aluminium herehttp://www.aluminium-profile.co.uk/a...10mm_Slot.html
could get a frame for about £60 ,would it crab with 2 bearings per rail spaced say 200mm , could i run two skate bearings against the outside of the frame on the non driven side to keep it parallel and stop the racking , i have aready ordered the 16mm rails from zapp
19-07-2009 #2
I would still say drive it from both sides, just get another motor and trapazoidal screw and it will be a much better solution. It may cost you a little bit more but at least you know it will be right!
Just wire both motors to the same driver card, so you won't need to spend more on electronics.
19-07-2009 #3
I dont suggest connecting both motors to the same driver.
This can cause problems with the driver and will also void the warrantee of the driver.
As an example of the problems you will see is that if the driver has any anti resonance circuitry this will most likely cause this to not function as expected.
You will also have issues with BEMF.
Visit Us: www.automationshop.co.uk
19-07-2009 #4
thanks hilton steve
will gladly take your advice and go for twin screws , i dont want to waste time and money and end up with a machine that
needs.... well more time and money !! . this, by the way is a great forum for information
19-07-2009 #5Nothing is foolproof......to a sufficiently talented fool!
19-07-2009 #6Visit Us: www.automationshop.co.uk
19-07-2009 #7
To be honest I have never tried driving 2 motors from 1 driver, I was thinking about doing this in my initial design stage because someone suggested it but gave up on the idea.
Well you learn something every day!Last edited by HiltonSteve; 19-07-2009 at 10:08 PM.
19-07-2009 #8
So have I, shed loads of it, tried to sell some to you
.John S -
20-07-2009 #9Visit Us: www.automationshop.co.uk
NEW MEMBER: another noobie
By wilfy in forum New Member IntroductionsReplies: 0Last Post: 17-07-2012, 10:34 PM
