    Looking forward to this one, the computers sections would have been the other place to post it.
    .Me
    Thanks Lee
    If you can, move it on over to the computer section if you want (I don't think I can do this myself?) - I've had a few requests to do a pfsense setup tutorial, which I'll start doing shortly (its quite easy for a simple setup via a wizard), but its very powerful once you start to dig into the menus.
    Chris
    Chris,
    Nice one! I've given your videos a thumbs up.
    Did you consider some additional venting/ducting to actively place incoming cooler air where you most want it?
    Regards,
    Nick
    Hi Nick
    Thanks for the likes and yes I did consider doing another vent pattern under the motherboard so the cooler air would get sucked up under that and vented out the top. However, I don't think I'll have to, as according to the management console its running at 26.8 deg C and hasn't budged yet. If it does get near the limit in the future then I'll CNC drill the holes.
    I've found on a few other consumer rack chassis that getting shot of the noisy and probably cheap crap 40mm fans and putting a 120 or 140mm fan in does wonders for cooling in switches etc.
    Hi all,
    A bit of an update - my dual layer setup provoked a bit of comment, but I was asked so did a couple of setup videos:
    Networking part:
    and the actual setup part:
    Back to guitars for the next vid or three.
  1. RFQ: Custom corrugated sheet steel panels for home DIY project. Brake job anyone?
    By Peter Dow in forum Projects, Jobs & Requests
    Last Post: 01-06-2012, 09:31 PM
  2. FOR SALE: FOR SALE Large Custom Deskop MDL Router
    By jonbabbz in forum Items For Sale
    Last Post: 25-05-2012, 10:47 AM
  3. Drivers,BOB and PSU are in a PC case, do i earth the case
    By deannos in forum Motor Drivers & Controllers
    Last Post: 27-11-2011, 03:43 PM
  4. RFQ: RFQ - custom 43mm spindle mount
    By HankMcSpank in forum Projects, Jobs & Requests
    Last Post: 03-11-2011, 09:52 PM
  5. RFQ: Project Case End Plates Require Making
    By flipflop in forum Projects, Jobs & Requests
    Last Post: 17-08-2010, 09:03 AM
