Thanks Lee
If you can, move it on over to the computer section if you want (I don't think I can do this myself?) - I've had a few requests to do a pfsense setup tutorial, which I'll start doing shortly (its quite easy for a simple setup via a wizard), but its very powerful once you start to dig into the menus.
ChrisMy CNC Projects: https://www.youtube.com/imadethisoncnc
17-06-2016 #2
Chris,
Nice one! I've given your videos a thumbs up.
Did you consider some additional venting/ducting to actively place incoming cooler air where you most want it?
Regards,
NickLast edited by magicniner; 17-06-2016 at 07:20 PM.
17-06-2016 #3
Hi Nick
Thanks for the likes and yes I did consider doing another vent pattern under the motherboard so the cooler air would get sucked up under that and vented out the top. However, I don't think I'll have to, as according to the management console its running at 26.8 deg C and hasn't budged yet. If it does get near the limit in the future then I'll CNC drill the holes.
I've found on a few other consumer rack chassis that getting shot of the noisy and probably cheap crap 40mm fans and putting a 120 or 140mm fan in does wonders for cooling in switches etc.My CNC Projects: https://www.youtube.com/imadethisoncnc
28-06-2016 #4
Hi all,
A bit of an update - my dual layer setup provoked a bit of comment, but I was asked so did a couple of setup videos:
Networking part:
and the actual setup part:
Back to guitars for the next vid or three.My CNC Projects: https://www.youtube.com/imadethisoncnc
RFQ: Custom corrugated sheet steel panels for home DIY project. Brake job anyone?
By Peter Dow in forum Projects, Jobs & RequestsReplies: 21Last Post: 01-06-2012, 09:31 PM -
FOR SALE: FOR SALE Large Custom Deskop MDL Router
By jonbabbz in forum Items For SaleReplies: 0Last Post: 25-05-2012, 10:47 AM -
Drivers,BOB and PSU are in a PC case, do i earth the case
By deannos in forum Motor Drivers & ControllersReplies: 4Last Post: 27-11-2011, 03:43 PM -
RFQ: RFQ - custom 43mm spindle mount
By HankMcSpank in forum Projects, Jobs & RequestsReplies: 15Last Post: 03-11-2011, 09:52 PM -
RFQ: Project Case End Plates Require Making
By flipflop in forum Projects, Jobs & RequestsReplies: 0Last Post: 17-08-2010, 09:03 AM
