Whilst I'm thinking about it - worth a sanity check on the cooling to the laser tube - my inlet/outlet on a cheap 40W Chinese special were swapped (fed through each other's holes in the back of the enclosure) - the water inlet is supposed to be on the lowest point on the tube and the outlet is on the highest part of the tube - to ensure that once coolant is flowing that it completely encloses the laser cavity (and thus cooling it). If you get those the wrong way around, the water flows in from the upper inlet, and drains out of the lower outlet without being able to form the water bath to properly cool the laser.
It's the work of a couple of minutes and (thanks to the Chinese manufacture) a single screw (from what I recall) to visually confirm this before risking damage to the tube.
20-06-2016 #2
Thanks that is good advise didn't I will check that to make sure its right
FOR SALE: Denford MIRAC CNC Lathe. Single Phase. Absolutely complete and perfect running order.
By Nick Butler in forum Items For SaleReplies: 19Last Post: 21-08-2013, 11:20 PM -
Make your own Super- PID ... not that hard to make ! .... says electronics genius!
By Buba b in forum General ElectronicsReplies: 4Last Post: 26-04-2013, 08:37 AM -
Need a perfect 8mm hole - to ream or bore?
By HankMcSpank in forum Machine DiscussionReplies: 26Last Post: 12-03-2013, 12:42 PM -
a perfect 90deg joint - 15mm Alu
By dsc in forum Gantry/Router Machines & BuildingReplies: 12Last Post: 24-02-2013, 01:31 PM -
Not cutting perfect right angles and sticking on Y axis ?
By Fivetide in forum Milling Machines, Builds & ConversionsReplies: 7Last Post: 10-12-2012, 09:41 PM
