    The sprint speed controller is not isolated, is the V4 isolated? if not i think you will find out that this can damage things.
    I'm using v4 board in my triac and microrouter both have sprint drive cards and I don't have any issues
    Quote Originally Posted by dodgygeeza View Post
    Quote Originally Posted by andy_con View Post
    Then the V4 card must be isolating it then.
    otherwise you would have 230V ac going onto the input of the V4 card.
    i think the description is pretty clear
    http://diycnc.co.uk/cnc-boards-v5-spindle-board/
    Fully Opto isolated inputs for live motor controller circuits
    Ok, this is the V5. I used the V4 a long time ago and this did not have isolation built in. But im not sure that they upgraded this though.
    both my denford machines with sprint drive cards use the v4 board
    We helped introduce and develop this board when Roy ran the company.
    It was done for the Sieg X3 machines that had mains voltage on the spindle side of the board.
    The original board was the V3, later to become the V4 that had an optional 2 relays fitted.
    All these boards are isolated by means of a DC to DC converter.
    The manual for the V4 is still on the web.
    www.diycnc.co.uk/forms/spindleV4.pdf
    One thing to note:
    On the V4 Roy made a bad choice when he chose the DC to DC converter in that he chose one with a low amperage. This showed itself when we built a control box that was 6' away from the machine for a disabled user and speed just didn't work.
    We found out that if the DC to DC unit was replaced with a higher amperage the problem went away. Ironically the 2 amp unit was cheaper than the 1 amp unit.
    This was reported to Roy but ignored.
    Together with some other problems it's one reason we stopped buying his boards.
    John S -
    Hi Andy,
    Thanks for the advice so far. I'm poor in money and time so I'm going to have to break this down into smaller chunks. So I'll concentrate on the spindle drive and control and get a V5 card. Can you tell me what you used for the spindle encoder, did you buy this or make it? Any pictures you could send me please?
    I do have a few more questions regarding the spindle, I've watched a few videos on YouTube of the ATC mechanism working. it looks like the spindle is positioned and locked in place, is there a mechanism within the motor spindle assembly that clicks in to do this? Or is aligned with the slot on the encoder and then motor braking is applied?
    Do I need to have any more inputs to the Sprint card such as breaking and the Taco? Lastly I have a temperature sensor wired in the spindle motor, does this do anything, do I need to use it?
    Mike
  1. Denford Triac VMC
    By fidia in forum Milling Machines, Builds & Conversions
    Last Post: 19-08-2016, 08:18 AM
  2. FOR SALE: Denford Triac
    By asto in forum Items For Sale
    Last Post: 07-02-2016, 08:28 PM
  3. 3kw Chinese Spindle - ER20 denford triac question
    By andy_con in forum Denford Mills
    Last Post: 03-11-2015, 10:14 PM
  4. eBay: Denford Novamill SmartStep Control Board + Spindle Board
    By danielbriggs in forum Items On eBay UK
    Last Post: 30-05-2013, 06:52 AM
  5. Denford Triac Spindle Fault
    By Sam_Smith in forum Denford Mills
    Last Post: 04-05-2011, 11:07 PM
