Thread: Hi precision desktop machine
Hey fellas, I'm on the lookout for a high precision (ish) desktop machine for engraving and light milling of tuffnol or similar material (0.5mm depth)
Do you good fellas have any suggestions on a many machines??
Many thanks
	23-06-2016 #2
I don't have specific machines in mind but for high precision possibly something with harmonic drive reduction on the steppers?
	23-06-2016 #3
Cheers Nick, it doesn't have to be that drastic.
I'm engraving plastic sheet but the letters are quite small. Think electrical control panels and the name tags on the buttons etc
	23-06-2016 #4
If you can find one the Connect CNC desktop milling machines are compact and have the precision, I suspect that most ex-educational CNC mills will suffice.
Are you dead set on CNC or have you considered a pantograph? I still use My IM3 for some things as it's quick and easy to set up for text.You think that's too expensive? You're not a Model Engineer are you? :D
	23-06-2016 #5
i would prefer a cnc to be honest pal as i will need to cut through that plastic at some point
	24-06-2016 #6
Have you considered the Seig KX1 from Arceurotrade?
I know they bill it as "Hobby" but if the envelope is large enough id might do.
Failing that you could hang an auxiliary high speed spindle off the head of just about any CNC mill, at which point the world is your oyster;-)
WANTED: Wanted: Proxxon MF70 Desktop Milling Machine or Similar
By jnash in forum Items WantedReplies: 2Last Post: 25-01-2016, 05:02 PM -
FOR SALE: Selling my desktop CNC machine
By clbc in forum Items For SaleReplies: 1Last Post: 17-08-2015, 01:58 PM -
5 axis desktop machine Kickstarter
By 5AXISMAKER in forum Machine DiscussionReplies: 6Last Post: 24-09-2014, 08:41 PM -
RFQ: looking for a cnc / precision engineer
By jonisonvespa in forum Projects, Jobs & RequestsReplies: 0Last Post: 29-11-2012, 05:44 PM -
Opinions sought on cheap desktop PCB milling machine
By ksangeelee in forum Milling Machines, Builds & ConversionsReplies: 55Last Post: 16-03-2012, 01:57 PM
