    It doesn't matter if you use inch or mm for setting up your motor steps per, if you've done it right the machine will run imperial or metric code accurately.
    The body of each feature in the code is simply in numeric units and G20 or G21 in the header tells Mach 3 if those units will be interpreted as (G21) mm or (G20) inches.
    G20 specifies imperial, G21 specifies metric so if you are getting accurate Inch moves with G21 then you have configured your system incorrectly and your steps per out by a factor of exactly 25.4 and your initial commanded moves in inches with G20 will have been simply huge!
    - Nick
  2. The Following User Says Thank You to magicniner For This Useful Post:
  3. #2
    Not exactly correct as explained above.!! . . . It will scale the moves but not the feedrate.
    Try it load road runner and put G20 on first line or type G20 in MDI before running.
    The Feedrate in Gcode will be in inches minute but motors tuning is relative to MM/min. This is why you have to retune the motors if you change from metric to imperial units.
  5. #3
    Thanks for that Jazz, that's interesting.
    Given the simplicity of the conversion I'm shocked that they didn't make motor tuning/feed rate automatic for changes in G Code units, I had assumed this was the case but only ever work in Metric,
    Regards,
    Nick
  6. The Following User Says Thank You to magicniner For This Useful Post:
  7. #4
    ECCO's Avatar
    Lives in Tamworth, United Kingdom. Last Activity: 23-07-2016 Has been a member for 9-10 years. Has a total post count of 12. Received thanks 7 times, giving thanks to others 0 times.
    Many thanks for your replies. The mill is having mechanical parts modified at the moment and as soon as it is reassembled I will do some investigation and get back to you all. Once again thanks.
  8. The Following User Says Thank You to ECCO For This Useful Post:
  9. #5
    ECCO's Avatar
    Right the mech parts are now modified ok, back to the problems. could you please check over the following calculations for steps per.
    By the way this is a fully licenced version of Mach3. Have re-installed Mach3 and chosen inch base units.
    Motor Steps= 1.8deg =200 steps per 1 motor rev.
    Motor Micro steps =10 therefor 200x10 = 2000 micro steps per 1 motor rev
    Pitch of ball screws = 5mm = 0.19685 inches per 1 motor rev
    No of motor revs to move 1 inch = 1/0.19685 = 5.08 revs
    No of micro steps per 1 inch move = 2000 x 5.08 =10160 micro steps per inch
    Z axis is a 2:1 reduction ratio so 10160 x 2 = 20320 micro steps per inch
    Many thanks ( More to follow )
  10. The Following User Says Thank You to ECCO For This Useful Post:
  11. #6
    Yes that's correct go to top of the Class.
  12. The Following User Says Thank You to JAZZCNC For This Useful Post:
  13. #7
    ECCO's Avatar
    After a quite successful re-set on the miller we now have Imperial units. The machine homes properly onto 3 limit switches and runs a simple program ok and accurately.
    The issue now is what to specify in soft limits and soft limit slow zones. I honestly have not got a clue. I can accurately measure the distances that the machine is capable of moving in all axis.
    These dimensions are from the home positions. X +19.000" Y+7.375 Z-13.500.
    Any help most gratefully received.
  14. The Following User Says Thank You to ECCO For This Useful Post:
  1. cnc 3040 and mach3 problems
    By hoggy in forum Machine Discussion
    Last Post: 11-10-2014, 10:58 PM
  2. tree problems!
    By kingcreaky in forum Woodwork Discussion
    Last Post: 02-06-2014, 12:35 PM
  3. Mach3 PC problems, help please....
    Last Post: 30-01-2014, 07:05 PM
  4. NEW MEMBER: MDF Problems
    By MrWiz73 in forum New Member Introductions
    Last Post: 31-12-2011, 12:39 AM
  5. homing problems in mach3
    By johngoodrich in forum Artsoft Mach (3 & 4)
    Last Post: 17-09-2011, 08:28 PM
