01-07-2016 #1You think that's too expensive? You're not a Model Engineer are you? :D
The Following User Says Thank You to magicniner For This Useful Post:
01-07-2016 #2
Sorry Nick don't agree. Softlimits work good because they won't allow code to run unless it fits within the machines cutting range. They also stop you accidently running into the hard limits which can be pain.
The only thing is that the machine must be homed first for them to work properly.
ECCO: First Slow zones don't work so forget them.
Setting the Soft limits is easy. Set Soft Max for X & Y to +19 & 7.375 and Soft Min =0. For Z axis Soft Max =0 Soft Min -13.500
Remember you must always Home when first starting machine or after resetting for soft limits to work correctly.
01-07-2016 #3
01-07-2016 #4
07-07-2016 #5
Ok gentlemen the soft limits are now functioning as they should. X & Y movements are declared in Soft Max and the Z negative movement is entered in Soft Min. Even slow limits work. Many thanks for your assistance. Regards ECCO.
The Following User Says Thank You to ECCO For This Useful Post:
07-07-2016 #6
If your meaning Slow Zone then it doesn't work like you probably think. It's only used when jogging NOT when homing. So when approaching the limits it will slow down gradual at the distance entered.
When homing the Speed% is used which is % of the velocity set in motor tuning for that axis but will travel at this speed over the full distance each axis has to move.
08-07-2016 #7
JAZZCNC thanks for the advice. Can we presume that when running a program that the cycle would not exceed the soft limit envelope? ECCO.
cnc 3040 and mach3 problems
By hoggy in forum Machine DiscussionReplies: 18Last Post: 11-10-2014, 10:58 PM -
tree problems!
By kingcreaky in forum Woodwork DiscussionReplies: 8Last Post: 02-06-2014, 12:35 PM -
Mach3 PC problems, help please....
By Davek0974 in forum Plasma Table MachinesReplies: 13Last Post: 30-01-2014, 07:05 PM -
NEW MEMBER: MDF Problems
By MrWiz73 in forum New Member IntroductionsReplies: 4Last Post: 31-12-2011, 12:39 AM -
homing problems in mach3
By johngoodrich in forum Artsoft Mach (3 & 4)Replies: 2Last Post: 17-09-2011, 08:28 PM
