02-07-2016 #1
Hi all,
I've been using my cnc routerfor the last two years for mainly drilling holes for shelf peg holes and hinge holes for kitchen cupboards.
I also use it for cutting various curves and L shapes on corner cupboards.
I have a 2kw spindle and up until now i've been using a twin flute 1/2 inch 50mm straight cutter as they're cheap
The material used is 18mmMFC (melamine faced chipboard) and my cnc can only currently cut 2metres a minute
I've just bought a single flute compression spiral 1'2 shank Onsrud solid carbide cutter
So, given that the feed rate is that slow, What speed do you think I should set my spindle to run at ?
Thanks in advance
Noobs' Feeds & Speeds
By GaryWilliams in forum Metalwork DiscussionReplies: 11Last Post: 11-09-2016, 02:26 PM -
Speeds and feeds
By eurikain in forum Workshop & EquipmentReplies: 3Last Post: 26-03-2016, 06:00 PM -
Feeds and speeds software?
By Leadhead in forum Computer SoftwareReplies: 9Last Post: 31-10-2015, 09:34 PM -
Feeds and speeds
By dudz in forum Tool & Tooling TechnologyReplies: 0Last Post: 26-08-2013, 11:42 AM -
Speeds and Feeds
By Web Goblin in forum Tool & Tooling TechnologyReplies: 0Last Post: 20-09-2012, 01:38 PM
