I used to have an MF70 and documented extending the Y axis here:
https://0xfred.wordpress.com/2012/04...-mf70s-y-axis/
Why change the spindle? I doubt the tiny mill could handle much more power.
30-06-2016 #2
I° case : I have think if leaves a original motor ,I will change only the spindle same diameter 10mm but have a ER11 chuck for drill up to 7mm.
II° case, if I will replacement motor original with a bushless power up to 400-500Watt, I need increase the diameter spindle because the new bushless motor have more power..
28-07-2016 #3
the diameter of shank er11 is same the diameter bearing proxxon mf70 , I have also a new motor brushless 600watt power.
12-12-2017 #4
Old post but...can you give some details about motor, adapters, spindle etc? I have a burned MF70 motor and it's time to move to a brushless one...
19-02-2018 #5
I have modify my MF70 with the brushless and spindle ER11, also I think of convert the MF70 to CNC.
So I have already the breakboard 5 axis and motors stepper with each drivers.
The motors is a turnigy-aerodrive-sk3-3542-1250kv, the speed controller Turnigy dlux 70A SBEC Brushless Speed Controller and for variable speed I use a servo tester.
I had modified also the head of mill with a gear and belt.
Now I need of know how to control the motor brushless and speed controller with my cnc card.
Someone of this post can help me ?Last edited by cnc.miller; 19-02-2018 at 04:44 PM.
WANTED: Wanted: Proxxon MF70 Desktop Milling Machine or Similar
By jnash in forum Items WantedReplies: 2Last Post: 25-01-2016, 05:02 PM -
WANTED: Proxxon MF70
By jnash in forum Items WantedReplies: 0Last Post: 12-05-2015, 03:52 PM -
Proxxon MF70 for making injection molds
By forrest in forum Moulding MachinesReplies: 8Last Post: 11-04-2012, 11:30 PM -
Z-axis huge slack / beginning a conversion
By diy-john in forum Gantry/Router Machines & BuildingReplies: 11Last Post: 04-03-2012, 10:26 PM -
FOR SALE: Proxxon MF70 XXL 320
By fidia in forum Items For SaleReplies: 1Last Post: 20-05-2011, 02:35 PM
