23-09-2016 #1
Hi Guys
Have been meaning to have a look @ a rechargable device that stopped working a while ago.
Stripped it and the batteries are AA but the connection is made via a small pin on either end that locates in a v shaped connector.
Has anyone come across this type of Battery and do you know the type or part No i can Google.
Regards
Mike
23-09-2016 #2
Hi Mike,
A picture might be useful. Any markings on the batteries,are they NiCd or NiMh or lithium ?
RS have tag ended AA's but not pin ended.
Cheers,
Rob
23-09-2016 #3
Hi Rob
Thanks for your reply, i boxed the device back up to try it on the charger again after cleaning the contacts.
got a reading of about 1.3 volts on both cells and when i pressed one of the buttons a LED flickered into life then faded, new item is about 50 squids so will have a look at a Chinese knock off.
Thanks again.
Mike
23-09-2016 #4
A quick google threw this up - https://cellpacksolutions.co.uk/prod...mmon-sizes/aa/
Try the Termination selection menu down the right hand side to see if any look similar.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
23-09-2016 #5
Thanks for that m-c
the pins are about 2.5mm dia and about 4mm long one end and 6mm the other.
more chance of finding Hen's teeth.
Regards
Mike
23-09-2016 #6
If you're otherwise going to bin the item, just get some tag ended batteries and solder them onto the contacts. Even use a bit wire if needed.
Other option would be to make up some suitable adapters/pins from something solderable, and get some of the axial pinned batteries from that link and solder/trim them to the adapters.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
The Following User Says Thank You to m_c For This Useful Post:
23-09-2016 #7
There are tricks for getting dead rechargeables back to life. I don't think they always work, but maybe.........
Have a google - I found this https://www.youtube.com/watch?v=A5k0ljHLF58.
Old NiCd batteries grow cadmium whiskers inside them that short out the cell and need to be got rid of, before the chargers will recognise there is a chargeable battery present.
Turning the charger on and off repeatedly is one trick and flashing the battery with a charged capacitor is another. Somebody mentions using a welder to do the same, but I certainly wouldn't try it, it sounds too dangerous.
I don't endorse any of it though.
Cheers,
Rob
The Following User Says Thank You to cropwell For This Useful Post:
1 voltage meter for both solar panel and battery
By deannos in forum General DiscussionReplies: 7Last Post: 01-08-2014, 07:41 PM -
Very simple for special tool expert … heeeelp!
By hoezap in forum Tool & Tooling TechnologyReplies: 0Last Post: 14-07-2012, 08:57 AM -
WANTED: Anyone have one of the ebay special 50V 500W Minebea PSU's still?
By jamezwarner in forum Items WantedReplies: 13Last Post: 28-05-2012, 11:14 AM -
Special offer on Shark Fx v7
By m.marino in forum General DiscussionReplies: 0Last Post: 05-01-2012, 05:17 PM
