Thread: help with elctronic component
28-12-2016 #2
I suspect it's a thermal fuse and what it came out of isn't working?
If I've guessed correctly the thing that doesn't work overheated ;-)
http://sinolec.co.uk/en/19-thermal-c...metal-switches
- NickLast edited by magicniner; 28-12-2016 at 06:06 PM.
Its an over temp. safety cut off switch. You should be able to get one from RS components or a good Electrical wholesaler
or http://sinolec.co.uk/en/search?contr...submit_search=Last edited by Clive S; 28-12-2016 at 06:08 PM.
28-12-2016 #4
Bi-metallic thermostat. Will carry up to 16 amps and opens at 85 degrees centigrade. Safety device to prevent over heating. They normally close when cooled down again but easily tested with a meter and a boiling kettle or pan.
28-12-2016 #5
thanks everyone
makes sense what your telling me
one of the terminals looks to have overheated and come lose tried to solder it back
looks like a bad contact and caused the wire to overheated and become corroded
need to buy a new one thanks Geoff
28-12-2016 #6
CPC is a good price to get this sort of thing:
http://cpc.farnell.com/temperature-switches
Hard not to find the £5 worth of parts you need to buy for free postage.
06-01-2017 #7
many thanks for all your help
part ordered delivered today
fitted to heater works great no longer freezing my bits off
once again thanks geoff
Component Check
By manofgresley in forum General ElectronicsReplies: 1Last Post: 22-04-2014, 06:04 PM -
Motedis.co.uk - Aluminium Profile and Component Supplier
By KB Aluminium in forum Marketplace DiscussionReplies: 1Last Post: 17-02-2014, 01:52 AM
