Thread: Mach 3 Turn - CAM Issues
So, Ive been using my Emco 120 for a bit and had no real issues.
Ive now setup my mill to have it be able to do some form of turning. The problem I am having is that of deciding which post processor to use and then seeing 'odd' stuff in the tool paths.
If there a guidance on whether we should use Inc or ABS in the Mach 3 general settings for Distance and IJ mode specifically? I have tried forcing ABS by using G91.1 (or whatever the command is, no change).
Ive tried every option and I am getting either.
The radius is greater than error, weird big circles or small circles where there is a change of direction.
It's like something has changed however I am not sure what. Ive tried another post processor for Mach 3 which should work, same result. Previously I have used the Fanuc one which is advised as the 'default' one for Mach 3.
Any ideas / thoughts? I dont think Mach 3 Turn wants to see I and K values.
04-08-2017 #2
Anyone?
05-08-2017 #3
Mach 3 Forum?
05-08-2017 #4
The only thing I can think of, is did you have to alter the arc settings in the mill profile, and they've some how been carried over the turn profile?
Failing that, as Nick says, Mach 3 forum is your best bet. I've never used CAM on my lathe, as I either hand code things, or glue together the wizard outputs. Plus I've not used Mach on the lathe for a few years now.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
06-08-2017 #5
06-08-2017 #6
Emco PC120 Turn
By Chaz in forum Emco LathesReplies: 140Last Post: 14-08-2017, 09:47 AM -
Mach Turn
By Kai in forum CAD & CAM SoftwareReplies: 5Last Post: 02-08-2016, 02:40 PM -
Getting the stepper to turn
By thorphar in forum General ElectronicsReplies: 0Last Post: 16-09-2014, 07:48 PM -
11 hours of trying to get the motors to turn, help please
By Wotsit in forum Stepper & Servo MotorsReplies: 19Last Post: 05-02-2013, 03:07 AM -
LED not turn on
By Awel in forum Motor Drivers & ControllersReplies: 1Last Post: 06-12-2011, 06:59 AM
