15-08-2021 #1
I have been working on my first ever fixture and I am so close to having it complete.My problem is that my part won't fit into my fixture correctly,the bottom left corner sits higher than than the other corners which sit Flat.Im try to achieve a
good fit so my part sits tight,my fixture is 5microns bigger than the part.Iv tried deburring,offsetting my wall width where my part is raised,amongst several other things,any suggestions will really help.
15-08-2021 #2
What material is the fixture made from.?
What material is the part.?
What type of machine.? Mill or Router.
What type and material is the bed made from.?
Do you know if your part is flat or for that matter your fixture is truly flat or even the surface the fixture fastens down to is flat.? If any of them has any twist you will struggle to get a perfect fit.
Usually, you would surface the fixture so it's co-planer to the spindle, then you would machine the mating surface of the part if you need a close fit to the fixture.
If you have removed all burrs then I would suspect a twist in any of the areas mentioned above and most likely a little in each.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
FOR SALE: Fixture plate
By GOOSEISLAND in forum Items For SaleReplies: 5Last Post: 05-06-2020, 03:34 PM -
Tooling Fixture Plate for Milling Machine - guidance requested
By GND in forum Milling Machines, Builds & ConversionsReplies: 10Last Post: 16-04-2020, 11:19 AM -
Fixture advice
By Voicecoil in forum Metalwork DiscussionReplies: 8Last Post: 10-04-2020, 09:42 PM -
Flat bar or plate for CNC
By dfox1787 in forum Metalwork DiscussionReplies: 18Last Post: 25-05-2018, 06:46 PM -
WANTED: Rotating Nut Fixture x2
By PaulP in forum Items WantedReplies: 13Last Post: 02-01-2018, 10:50 PM
