Thread: Which metal would flex more?
17-12-2017 #1
What would be the most rigid of these flatbar?
Flexing as if you were using them as a bridge and standing in middle. I'm sure there is a tech term for it, but I don't know it.
25mm thick aluminium 500x100mm
10mm thick 500 x100mm mild steel
10mm thick 500x100mm stainless steel.
Thanks in advance.
17-12-2017 #2
That's easy -
https://en.wikipedia.org/wiki/Three-point_flexural_test
Unless you expect someone else to do the work for you?You think that's too expensive? You're not a Model Engineer are you? :D
17-12-2017 #3
I was kinda hoping not to spend £250K+ on a test rig to find out. Lol
Just looking for advice for people that work with metals what they thought.
17-12-2017 #4
Would depend on the aluminium alloy to some extent but Youngs modulus of steel is roughly 3x that of Aluminium.
There is not really a particularly significant difference in modulus between stainless/mild.
Flexural modulus is usually fairly in line with Youngs modulus in metals. Polymers can vary more.
https://www.engineeringtoolbox.com/y...lus-d_773.html
Edit - as it pertains to machine design, the general rule of thumb I've seen bandied around is that you need twice the thickness of aluminium to achieve similar stiffness to steel. No idea where that rule of thumb started though nor how accurate it is when considering all the different variables in real applications.Last edited by Zeeflyboy; 17-12-2017 at 08:57 PM.
The Following User Says Thank You to Zeeflyboy For This Useful Post:
17-12-2017 #5
And in giving dimensions and materials you are asking them to perform standard calculations based on set formulae which are easily found.
It isn't Rocket Science and if yo want to pay my hourly rate I will look up the equations and do the calculations for you.
Around 8 years ago I wanted to know about material thicknesses in cylinders for a variety of diameters and pressures and looked up the required mechanical engineering equations, if you were to ask this on a mechanical engineering forum I'd expect an "off the cuff" answer but generally speaking by asking this here you are just expecting someone else to do your work for you, and someone might, but without seeing their working how will you know if the answer is any good?You think that's too expensive? You're not a Model Engineer are you? :D
17-12-2017 #6
17-12-2017 #7
17-12-2017 #8
Good man!
Someone else was willing to do the basic maths for you!
You should do a degree course now! :DLast edited by magicniner; 17-12-2017 at 09:42 PM.
17-12-2017 #9
17-12-2017 #10
Yes,
I'm glad you ask, actually I answer lots of direct relevant questions with well thought out technical answers from people who aren't lazy clueless wakners who can't be bothered to carry out a basic Google search to see if there is a good answer just sitting there for them on the net.
But I guess you are too lazy to search and discover that too!
#SLACKER!
;-)You think that's too expensive? You're not a Model Engineer are you? :D
Metal 3D printing
By mekanik in forum 3D Printing MachinesReplies: 5Last Post: 28-07-2017, 06:38 PM -
Metal Bandsaw or Cut-Off Saw?
By Gytis in forum Metalwork DiscussionReplies: 25Last Post: 18-01-2017, 08:36 PM -
RFQ: laser cut - very simple rectangular parts, PTFE and other flex plastics
By dsc in forum Projects, Jobs & RequestsReplies: 0Last Post: 19-06-2015, 12:59 AM -
FOR SALE: metal cabinets
By kingcreaky in forum Items For SaleReplies: 17Last Post: 26-10-2013, 05:40 PM -
Metal Spinner
By vueselection in forum Opportunities Available & SoughtReplies: 0Last Post: 28-05-2012, 03:30 PM
