24-05-2018 #7
There are different schools... some prefer limit switches, some don't. Personally I would not run a CNC without limit switches to prevent unintentional runaway. On my 3D printer I only have home switches, and those work as limit switches for one end of the axis, but have no limit switches at the other. Now and then I make a mistake resulting in hitting the wrong end, and even with the weak NEMA17 motors it sounds pretty violent. I want my CNC to stop in a more controlled and less violent way so I have limit switches at both ends to prevent that. On the other hand, I don't use home switch on my CNC at all, since I always start from zero on the material I work with and I set the zero each time I need to.
Planet CNC initial setup and limits?
By ravihotwok in forum General DiscussionReplies: 19Last Post: 22-06-2017, 08:09 AM -
Help needed Dahlgren System 4824 And a DSC controller, what software will run it???
By fraserguitars in forum Machine DiscussionReplies: 0Last Post: 13-12-2015, 08:22 PM -
DSP controller questions, Will this work well with Deskproto as my CAM software?
By chris in forum DeskProtoReplies: 7Last Post: 18-01-2014, 07:04 AM -
Reversed axis on a AXYZ 6010 after installing DNC controller software...
By RickyThunders in forum Machine Control SoftwareReplies: 1Last Post: 12-02-2013, 03:56 AM -
HME Technology router NEE AMC-E controller WinAMC software
By artmin in forum Motor Drivers & ControllersReplies: 39Last Post: 24-01-2012, 11:29 PM
