Thread: Am882 drives
    Hi
    I'm looking at the AM882 drives to run nema 23 stepper motors,
    There are 3 types
    AM882
    AM882H
    AM882H DK
    It's for a Cnc router
    Any one know what the differences are and which one is best for a router.
    Thank you ( again ) lol
    How about links to the drives
    Found it thanks
    leadshine 2phase stepper driver AM882 AM882H DMA882S, input voltage :0VDC-100VDC/20VAC-80VAC both can work
    the latest version is DMA882S use for replace AM882 AM882H
    ​the different between am882 and AM882H is am882h with fan, am882 no fan
    1.Sensorless stall detection
    2.Extra-low motor noise offers excellent quietness
    3.Optimizes torque and nulls mid-range instability
    4.Self-test and Auto-configuration technology
    5.Options to set output current and microstep relolutions via DIP switch or software
    6.Microstep from 1 to 512
    7.Supply voltage up to +80 VDC
    8.Output current programmable, from 0.5A to 8.2A
    9.Automatic idle-current reduction and reduction rate is software configurable
    10.Fault out prevents damages to your machines or the materials
    Quote Originally Posted by Crunch View Post
    Ok The cheapest one is DC only and the other will take AC or DC
    If you intend to build a power supply the go with the cheapest
    Lives in East Lothian, United Kingdom. Last Activity: 17 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,909. Received thanks 360 times, giving thanks to others 8 times.
    IIRC AM882 are DC input only, whereas the H version will accept DC or AC input.
    Not sure about the DK bit.
    The DM-S drives are Leadshines latest drives, aimed to replace the old DM, AM, and EM drives, however they don't appear to have the same functionality as AM/EM drives as the only configuration is via DIP switches.
    And having just checked the leadshine website, I see they've just launched an EM-S drive, and all mention of DM-S has disappeared...
    I wonder if the DM-S didn't quite pass CE approval like the AM drives, so they've launched a new tweaked design for the EU/US?
    Thanks guys
    I think I will go with the standard DC ones as I'm going to build power supply.
    ( with all your help hopefully )
    Sent from my SM-G900F using Tapatalk
    I have 3 AM882 drives running my CNC and would like to tune them using ProTuner but am missing the serial cable.
    Would anyone have the pinout for that cable? Thanks
    Hope this helps.
  1. Vfd drives/dc motor drives question
    By Toolman321 in forum General Electronics
    Last Post: 23-05-2018, 06:31 PM
  2. EM806 vs AM882
    By Ger21 in forum Motor Drivers & Controllers
    Last Post: 27-02-2017, 09:57 PM
  3. I NeeD HeLp PLease AM882 a good choise
    By jpsicilia in forum Motor Drivers & Controllers
    Last Post: 16-08-2014, 10:27 PM
  4. AM882 Alarm Circuit
    By Wobblycogs in forum General Electronics
    Last Post: 28-03-2014, 06:06 PM
  5. Problem with AM882 drivers !..... or it could just be me !
    By Buba b in forum Motor Drivers & Controllers
    Last Post: 03-04-2013, 09:28 AM
