Page 15 of 17 FirstFirst ... 51314151617 LastLast
  1. #141
    Chris, I have added you to the Dropbox folder. Good luck with the downloads. Regards.
  2. #142
    If there's a chance you can help me out as well for a previous version: [email protected]
  3. #143
    Should be sorted. I've added you to the Dropbox folder which gives you access to versions 1.932 and 1.935. Good luck.
  4. #144
    Bladevane
    Could you please possibly add me so i could get the older software, made the mistake of upgrading and can't export now, been frantically searching for the older software - [email protected] cheers!
  5. #145
    All sorted. You should have access to versions 1.932 and 1.935 via Dropbox. Regards.
  6. #146
    Quote Originally Posted by Bladevane View Post
    I just wanted to say a big thank you to you for helping me out!
  7. #147
    dudz's Avatar
    Lives in Dunedin, New Zealand. Last Activity: 2 Days Ago Has been a member for 9-10 years. Has a total post count of 280. Received thanks 2 times, giving thanks to others 69 times.
    Please can I get access to that dropbox ?. Thanks
  8. #148
    Ace's Avatar
    Lives in City, American Samoa. Last Activity: 07-03-2023 Has been a member for 0-1 years. Has a total post count of 1.
    Hi, Could you please link me to your dropbox list for the older version of EMS.
    Thanks Ace
    [email protected]
  9. #149
    Ace, All sorted.
  10. The Following User Says Thank You to Bladevane For This Useful Post:
  11. #150
    Do you still have the dropbox for version 1.932 and 1.935? Could you add [email protected]?
  1. PC Upgrade Options?
    By Chaz in forum General Discussion
    Last Post: 31-08-2016, 04:53 PM
  2. Laser Upgrade
    By dcrowder in forum Laser Machines & Building
    Last Post: 06-05-2016, 01:06 PM
  3. VFD upgrade
    By paulus.v in forum Spindles & Drive Motors
    Last Post: 05-11-2014, 11:09 PM
  4. Upgrade
    By Dopy in forum General Discussion
    Last Post: 09-11-2011, 01:57 AM
  5. BUILD LOG: Time for mk2 upgrade!
    By routercnc in forum DIY Router Build Logs
    Last Post: 26-02-2011, 11:38 PM
