Continuing with my Fehlmann mill-drill conversion, I have been sorting out what might be referred to as the W axis, that is the coarse positioning of the milling head. The machine as originally designed uses a microswitches and stops to obtain three user settable positions of the head. This vid from a couple of years ago shows the head and stop arrangement
I've had this working with the stops but they only appear to be repeatable to about 0.1mm - which will mean tool height setting every time the head is moved.
I was intrigued to find that Fehlmann continued developing my machine until about 2011 with the later Picomax 54 and 55 being almost identical but with CNC control of the W axis. Seen here:
The Picomax 54 uses the same motor as in my P50 but has a rotary encoder on the end of the pinion shaft - I'm sure Fehmann's rack and pinions are very accurate but it doesn't seem like the greatest way of obtaining positional info. The motor is controlled by a VFD and somehow this controls the position of milling head using info from the encoder.
I think that the Picomax 55 is doing the same thing but with a glass scale - I'll check with Fehlmann.
Can anyone illuminate me about how it is possible to use an induction motor, inverter and encoder to obtain absolute position? I see this clever chap manages to achieve it:
Can anyone illuminate me about how it is possible to use an induction motor, inverter and encoder to obtain absolute position? I see this clever chap manages to achieve it:..Clive
23-04-2020 #3
Thanks Clive, I'll drop him a line.
David
VFD 220v single phase to 380v three phase.
By Richard in forum General DiscussionReplies: 28Last Post: 14-12-2020, 11:19 PM -
FOR SALE: For sale: 5 induction motors, 2 servo motors
By Jonathan in forum Items For SaleReplies: 1Last Post: 30-09-2018, 04:18 PM -
WANTED: 2.2 KW 3 Phase Induction Motor
By Chaz in forum Items WantedReplies: 5Last Post: 23-11-2017, 06:18 PM -
Basics on control and positioning with stepper motors
By richard2112 in forum Stepper & Servo MotorsReplies: 4Last Post: 30-06-2014, 08:39 AM -
AC servo motor to replace a 3 phase induction motor on a mill spindle.
By rnr107 in forum Spindles & Drive MotorsReplies: 2Last Post: 23-04-2014, 03:14 PM
