    New to the forum, came here because everything else seems US based and not always the best place for advice.
    I run a 3040 cnc ballscrew version and use it to make parts for model ships.
    Now I have just run into what could be best described as a bad issue..
    I have a damgaged Z axis ballscrew that needs replaces (endstop switch failed.. Broken wire)
    Now I;m having issues find a UK supplier of 150mm SFU1204 12mm Ballscrew. I mean no where can I find one.. ?
    I know the UK no has issues with the brexit situation but heck ,, Im at a loss..
    anyone know who would have one ?
    Lee Roberts's Avatar
    Lives in Wigan, United Kingdom. Current Activity: Viewing Moderator Control Panel Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,914. Received thanks 227 times, giving thanks to others 776 times. Made a monetary donation to the upkeep of the community. Referred 11 members to the community.
    eBay was looking at them myself just last night, longer than you need but on that length of screw you can get away with not supporting the floating end...simply lop it off where you need it.
    Link: https://www.ebay.co.uk/itm/353435740939
    .Me
    Thanks I must have searched hi and low.... found one of the correct length now from china :( so will see how that works out with customs... maybe will get the longer one from the link you provided "just in case"
    I appreciate you taking the time to answer cheers...
    I have a spare 1204, 300 mm long not machined if any use
    I have used the supplier that Lee mentioned quite successfuly
    Quote Originally Posted by johnsattuk View Post
    I need one end to fit 8mm bearing so would need it machined and I dont yet have a lathe.... other wise would have got that from you.. but thanks for the offer....
    I presume that you would also need a thread and a reduction for your coupling, if you can provide details, I have a lathe
    thats an amazing offer thankyou ..
    the total length is 145mm
    top diameter 8mm x 20mm
    bottom 8mm x8mm
    would that work for you and how much deliverd .. I asume your UK too
    Hi
    Is there no thread involved,is 145mm the thread length or the O/A length. Will the nut fit, my nut is 35mm O/A, the flange is 8mm thk x 40 dia. x 30mm A/F, the body is 22mm dia. the nuts/screws are not allways interchangeable
    overall length is 145mm 8mm at the lower section to fit the bearing, the top section is also 8mm and 20mm long,
    the flange is square 8mm thick ( I have posted photos)
    the nut is 36mm long
    https://photos.app.goo.gl/11azQFAJPcgnGtzz8
    trying to upload to here,, wont work is there a file size limit?https://flic.kr/s/aHsmVcSX4L
    loaded to google and flikr not sure which would be best for you
  1. NEW MEMBER: Hello everyone, bespoke spectacle maker in London pulling my hair out.
    By Worshipfulspectacles in forum New Member Introductions
    Last Post: 23-11-2019, 02:33 AM
  2. pulling my hair out with cam
    By universally in forum CAD & CAM Software
    Last Post: 09-04-2015, 01:41 PM
  3. Hair growth device. DIY version
    By gavztheouch in forum Electronic Project Building
    Last Post: 30-03-2014, 08:55 PM
  4. AM882,s and Mach3 ......plus hair removal !!!
    By Buba b in forum Motor Drivers & Controllers
    Last Post: 26-10-2012, 05:11 PM
  5. Heelp! Dual axis steppers.. Losing steps.. Pulling hair out..!
    By fasteddy in forum Motor Drivers & Controllers
    Last Post: 14-05-2010, 02:32 PM
