07-05-2021 #1
so i purchased one of these -
https://www.ebay.co.uk/itm/184601717...EAAOSwjyxZci17
not actually used it yet, but my initial thoughts
he said 5 weeks and it took 7, didnt get a single communication from him for 5 weeks until i questioned what was happened.
the machine has no homing switches, which im totally shocked at. didnt even know you could get a cnc without homing switches, my £350 laser cutter has homing switches. not even sure i know how to use it without homing switches and limits.
when i go into homing/limits in mach its empty, so looks like i could easily damage the machine, i will be adding limit switches.
the estop is wired backwards :(
took me about an hour of faffing to work out why mach would activate, push the estop down and mach engages. easy fix i know, but come on...
when you hit the estop when the machine is running it appears to kill the uc100 controller, which is highly annoying. it disconnects from mach.
very heavy machine which is good.
will report more once i use it.
07-05-2021 #2
Seriously an MDF backplate in the control box with not a fuse in sight.!!. . . . Be afraid very afraid..
Email: [email protected]
Web site: www.jazzcnc.co.uk
07-05-2021 #3
whats the kitchen sink strainer in side of electrical box supposed to do?
07-05-2021 #4
07-05-2021 #5-use common sense, if you lack it, there is no software to help that.
07-05-2021 #6
07-05-2021 #7-use common sense, if you lack it, there is no software to help that.
07-05-2021 #8
08-05-2021 #9
Can lead a horse to water but can't make it drink.! . . . . . I have several smooth steppers in a draw somewhere USB and Ethernet which I've fit and removed because of issues and bugs and removed several from other machines because they gave nothing but trouble. So yes it was certainly tried but sadly not tested enough.!
I was a big Mach3 fanboy for the best part of 20yrs, so it's sad and hard to say but Mach3 is done and finished, Mach4 is so bad they made a film about it called BUGs Life.! . . . . UCCNC blows them both away and is rock-solid stable.-use common sense, if you lack it, there is no software to help that.
09-05-2021 #10
I'm using an ESS/Mach3 combination on my CNC mill at the moment because that's what it came with. I'm seriously considering a change because of unreliability - random crashes, ESS buffer underruns, problems restarting from a given line, typically. Main thing stopping me at the moment is that the ESS is plugged into a motherboard that carries all the external connectors and I need to look at just how much work will be needed to re-engineer a conversion. UC300/UCCNC probable candidate, though. Would have re-used my CSMIO IP/M except that sticks with Mach3. I also run a PV Automation ET6 board with MyCNC software for my router which is mostly OK although I still have one or two issues with it. At least it's more reliable than the ESS, though.
Wood cnc router for hobbyist
By nerostjames in forum Machine DiscussionReplies: 9Last Post: 01-01-2018, 09:28 PM -
SWAP: CNC Wood Router
By petesurrey in forum Items For SwapReplies: 1Last Post: 29-12-2017, 07:44 PM -
Big-ish router concept review
By mbele in forum Gantry/Router Machines & BuildingReplies: 6Last Post: 23-04-2017, 07:27 PM -
Please review this router gantry idea
By EddyCurrent in forum Gantry/Router Machines & BuildingReplies: 34Last Post: 09-09-2013, 04:47 PM -
BUILD LOG: Wood Router
By Buba b in forum DIY Router Build LogsReplies: 18Last Post: 03-10-2012, 09:49 AM
