    Ah OK I figured that but going from my old drawing I think I had the frame at 4mm and then had the beams that the linear rails and ball screws being attached to at 10mm thick.
    I added steel strips to the faces where the rails bolt on - good for fixing but no damping effect, I suspect.
    Sand is your friend for dampening but wouldn't surprise me if that's gone up 5 times the price too lol.
    Quote Originally Posted by reefy86 View Post
    I've wondered if foam concrete would do the trick. Less weight and the air component of the mix is relatively inexpensive.
    Kit
  5. #15
    Kit
    My late next-door neighbour was a builder. His trick (and I suspect a trick common in the trade) was to give a good squirt of washing-up liquid into the compo mixer. It foamed up the mortar and made it lighter to handle and slippier off the trowel.
    Of course for filling beams you really need high density, low elasticity, acoustic decoupling air.
  6. #16
    Making foam concrete the DIY way is basically taking that a step further. I've been looking at it for possibly making raised garden beds. Suggesting it for damping a machine is primarily for the practicality of not being too heavy for one person to handle on their own, which is a consideration for all of my construction work.
    Kit
  7. #17
    Just got a quote from my local and they only do 7.5 meter lengths and for 80x80 5mm thick works out at £85 for 3 meters
  8. #18
    Well, that's half the price of the other place so you are already in front.
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
  9. #19
    More happy with the 5mm then the 4mm. Still worth filling with sand or is there an alternative way now?
  10. #20
    Sands ok but only to a point, depends on what you want the machine for.? If you're wanting to cut steel then your probably building the wrong machine with the wrong materials.?
    If it's for cutting wood and light aluminium work then I wouldn't waste your time and mess it makes, just use thicker material with plenty of bracing.
  1. Working with mild steel.
    By Wal in forum Metalwork Discussion
    Last Post: 19-09-2020, 04:35 PM
  2. RFQ: Large bed CNC Mild Steel (500 x 500 x 50)
    By Jono in forum Projects, Jobs & Requests
    Last Post: 03-04-2017, 05:05 PM
  3. Where to get Mild Steel Plate?
    By Chaz in forum Marketplace Discussion
    Last Post: 03-01-2017, 01:17 PM
  4. Milling mild steel
    Last Post: 16-02-2014, 02:31 PM
  5. RFQ: Several mild steel parts
    By dudz in forum Projects, Jobs & Requests
    Last Post: 26-08-2013, 11:37 AM
