Thread: step and dir pulse problem Mach3
If the copy of Mach3 came with the machine, is it a genuine licensed copy? There are quite a lot of "pre-licensed" copies around and they are notorious for giving weird results and inexplicable problems. One possibility is to download a genuine demo copy of Mach3, use your existing configuration files, and test to see if that works. Demo versions are limited in the length of gcode they can run but are otherwise fully functional so that would see if there is a Mach3 problem or not.
05-11-2021 #2
Z axis out by 2mm mach3 or fusion360 problem?
By Richardtweed in forum Machine DiscussionReplies: 21Last Post: 01-05-2022, 08:41 PM -
Mach3 lathe spindle pulleys problem
By John11668 in forum Artsoft Mach (3 & 4)Replies: 32Last Post: 30-01-2021, 03:04 PM -
Small Mach3 Problem
By needleworks in forum General DiscussionReplies: 8Last Post: 11-05-2020, 10:46 AM -
Mach3 & V-Carve Problem
By Ricardoco in forum Computer SoftwareReplies: 2Last Post: 31-05-2013, 12:53 PM -
Mach3 small problem
By dudz in forum Artsoft Mach (3 & 4)Replies: 7Last Post: 15-11-2012, 05:56 PM
