Thread: Orac conversion
    Hi, I am partway converting an orac lathe to Mach3. However I am having a bit of a problem finding suitable motors for the axis. So far it looks like a nema 34 size motor fits, but the only ones I have found have all been 8 wire, I need 4 wire motor. The original shalf dia is 9.5mm, I can increase the diameter of the motors belt pulley a bit, but think that the nema 14mm shalf maybe pushing it a bit. So what motors have you used to replace the originals ones. Thanks.
    Lives in East Lothian, United Kingdom. Last Activity: 1 Day Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,910. Received thanks 360 times, giving thanks to others 8 times.
    8 wire motors can be wired to use 4 wire.
    I'd guess the old shaft diameter is more likely to be 3/8" (9.525mm).
    Suitably geared Nema 23/4 motors will likely give better performance than Nema 34, but sometimes the convenience of not having to adapt mountings makes the larger motors simpler to fit.
    Thanks m c for your reply. I can easily make the adapter plates, but I think the shelf’s would then be a bit short, will take a look at nema 23 thanks again
  1. Centroid Acorn Orac ATC conversion
    By Steve_p in forum Denford Lathes
    Last Post: 21-05-2020, 06:12 PM
  2. WANTED: Denford Orac old electronics
    By matoxx in forum Items Wanted
    Last Post: 27-07-2016, 06:55 PM
  3. Orac lathe to Mach3 conversion advice/direction please
    By Hunter in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 18-08-2014, 09:36 PM
  4. RFQ: Spindle for a Denford ORAC
    By rnr107 in forum Projects, Jobs & Requests
    Last Post: 07-11-2012, 05:20 PM
  5. Orac lathe
    By phill05 in forum Milling Machines, Builds & Conversions
    Last Post: 13-07-2012, 09:05 PM
