    Hi all
    I have 2 12v dc actuators connected to a 4 position joystick.
    i need to be able to control the speed of one actuator only. the other will run at full speed.Can you draw and or explain how i need to wire a 12v dc speed controller into this circuit. if i put in the motor out contacts it doesnt work because the power polarities change when the joystick is in a reverse position. Maybe have to run 2 complete circuits but how do i wire the joystick controller. thanks for any answers
    RichardClick image for larger version.
Name:	Screenshot 2022-12-12 at 10-27-35 Joystick__4-Way__Control_of__Linear_Actuator.pdf.png
    ah, ignore this post.... I got it wrong
    If the speed control is positive side speed controlled (motor ground goes to ground) then insert the speed control output to drive pins 1&4 of the upper relay.
    so your comment between 1&4 is wrong?
    this is the speed controller i got Click image for larger version.
Name:	Screenshot 2022-12-12 at 11-38-08 DC Motor Speed Controller PWM Motor Driver 6-90v 10A - Buy Onl.png
    Quote Originally Posted by rjsutton View Post
    Apologies - I can't believe what rubbish I wrote. The intent was to remove a previous reply (hence the "ignore this post"), with a possible follow-on solution. But that was as clear as mud, I read that now.
    In any case, having looked at all similar images of similar PWM controllers, in each case the Bat-/Mot- and Bat+/Mot+ pins are non-common. Question: Are you comfortable that the joystick can handle the start-up current of the motor? As you've drawn the schematic you're depending upon that behaviour. If so, there might be options, but may include a couple of diodes (and if not, an additional relay). The main thought process I have is to provide the PWM output via the change-over relay potentially with a third relay to isolate the motor if neither direction is demanded. If you're prepared for a third relay I can sketch something.
    Hi yes the joystick seems to handle the current at start no problems
    the schematic is just a downloaded one which i used to get the machine working.
    i can add relay etc as required. thanks for the help
    R
    Hi Doddy
    if you can sketch circuit would be appreciated
    thanks
  1. Strong vibrations in ball screw linear actuator - is it normal
    By mbridge87 in forum Gantry/Router Machines & Building
    Last Post: 25-01-2021, 06:27 PM
  2. PWM control for single AC motor?
    By AcrimoniousMirth in forum Control Hardware & Systems
    Last Post: 07-04-2018, 11:01 AM
  3. RFQ: Semi automatic welding system Linear beam control system
    By richway in forum Projects, Jobs & Requests
    Last Post: 24-01-2017, 08:54 PM
  4. eBay: THK KR33 Linear Actuator (Great for Z-Axis)
    By biketrialsdave in forum Items On eBay UK
    Last Post: 21-01-2016, 03:17 PM
  5. Mark Carew Nema 23 Lead Actuator Example Build
    By centurian in forum Gantry/Router Machines & Building
    Last Post: 01-06-2015, 02:49 PM
