    Hi all,
    As I'm busy with work and no longer have the time or space to run this machine, i'm looking to sell. Would alo consider selling parts seperate (control panel as a single unit), if there's more interest. Details as follows:
    General Info:
    Hours of use: Few hundered hours of hobby use (many of which were idle)
    Materials cut: Aluminium, brass, various woods, foams, plastics and more.
    Cutting area: ~700 x 400mm with Z axis of around 90mm (from spoil board (18mm thick) to spindle). There is also a 100mm overhang for taller objects at the front, so total ~800mm X axis.
    Machine construction:
    Components:
    - HIWIN 20mm rails on all axis (1000, 600, 300mm)
    - 1610 dual ball screws on X axis (1050mm long), 1605 single ball screws on Y/Z (650, 250mm)
    - All ball screws are belt driven
    Materials:
    - 4mm thick steel box section for the frame/gantry
    - 10mm steel gantry side plates
    - CNC machined aluminium Z axis and motor mounts
    - West System epoxy levelled rail base on X axis.
    Electrics:
    - 2.2kW Water cooled spindle + Huanyang VFD
    - AM882 digital drives on all axis
    - CSMIO/IP-M motion controller
    - PSU for drives + axillary PSU for others
    - 8.7Nm NEMA 34 on X axis and 3.1Nm NEMA 23's on Y/Z (all CNC4YOU)
    - Shielded cables used throughout
    Additional:
    - Mach3 license and setup files to suit this machine (can consider selling laptop too)
    - Manual valve controlled air blast setup for metal machining
    - 25L coolant system setup for spindle
    - Proximity sensors on each end of all axis for homing and limits
    - Various E-stops on the machine/control box
    Can also sell
    - Various size aluminium plates
    - Various tools/collets for the machine
    - Workshop tools (Drill press, bench grinder/sander, compressor, vibratory tumbler, ultrasonic cleaner, etc)
    Photos:
    Machine:
ID:	31631Click image for larger version.
ID:	31632Click image for larger version.
ID:	31633Click image for larger version.
ID:	31634Click image for larger version.
ID:	31635Click image for larger version.
ID:	31636Click image for larger version.
    Some machined parts:
ID:	31639Click image for larger version.
ID:	31638Click image for larger version.
ID:	31640Click image for larger version.
ID:	31642Click image for larger version.
ID:	31641Click image for larger version.
    Located in North East for collection, if anyones interested. Thanks
    How much are you wanting?
    Quote Originally Posted by Wylie View Post
    Hi, trying to send you a private message but doesnt seem to be working. Will see if I can get it sorted.
    Looks like it's your settings.
    Could you please check and send me a private message when able. Thanks.
    Hi also interested in price thanks Sam
    Hi, I’m also interested in the price, thank you.
    Quote Originally Posted by johnpaulcarter View Post
    Hi John, please could you private message me to discuss. Thanks
    This is still available.
    Looking for around Ł3,500 for the CNC, collection only — open to offers and would consider selling parts seperatly too (full electrics, frame/gantry, etc).
    Edit: Managed to sort storage for this, so availability is now TBC.
    AndyUK's Avatar
    Lives in Southampton, United Kingdom. Last Activity: 3 Weeks Ago Has been a member for 6-7 years. Has a total post count of 469. Received thanks 100 times, giving thanks to others 43 times. Referred 1 members to the community.
    Quote Originally Posted by raj221 View Post
    Hi all,
    This is now available as could really do with the extra space.
    Cost me quite a bit more for the components alone, so think it's a fair price. Thanks
    Bargain price. Hope you get a sale sorted soon.
  11. The Following User Says Thank You to AndyUK For This Useful Post:
  1. BUILD LOG: AVOR – a steel-framed medium-size router
    By Neale in forum DIY Router Build Logs
    Last Post: 10-06-2019, 10:15 PM
  2. Large Format Steel Framed Router
    By nathandavies in forum Gantry/Router Machines & Building
    Last Post: 07-02-2016, 02:51 PM
  3. BUILD LOG: Steel Framed CNC router
    By Joe in forum DIY Router Build Logs
    Last Post: 23-06-2013, 10:45 PM
  4. BUILD LOG: Steel Framed Router
    Last Post: 14-09-2011, 06:51 PM
  5. BUILD LOG: My steel framed router
    By pavlo in forum DIY Router Build Logs
    Last Post: 06-03-2011, 10:08 PM
