19-01-2023 #6
You could change controller to an ethernet one like a UC400eth. (Better than USB) .
Get a couple of IDC26 to DB25 cables. Then use your existing parallel board with it on one of the ports and just change the pin numbers accordingly. You then have a second port for another parallel board if you want to add any other items later on.
Chances are you'd only need to deal with power supplies in the box that's all.
I'm assuming your system is using 5v? that all stays the same.
You'd just need a small extra one to power the new controller. (the UC400eth needs 24v I believe).
The Following User Says Thank You to dazp1976 For This Useful Post:
Entry level Probe
By Leadhead in forum Probing, Digitizing & ScaningReplies: 5Last Post: 09-10-2013, 07:55 AM -
help needed going to the next level
By luke11cnc in forum Computer SoftwareReplies: 8Last Post: 20-09-2012, 08:53 AM -
Which end mill to level my acrylic bed?
By HankMcSpank in forum Tool & Tooling TechnologyReplies: 18Last Post: 03-02-2012, 02:57 PM -
NEW MEMBER: Just joined, hobby level
By cncgcg in forum New Member IntroductionsReplies: 12Last Post: 03-12-2011, 02:32 PM -
Level Y Axis
By sfallan in forum Machine DiscussionReplies: 3Last Post: 26-09-2010, 12:52 PM
