    Hi all.
    I’m looking for manual or explanation of Lichuan debugging software for LCDA357H. I already connect it to the drives and tried to adjust the anti-vibration parameter but I can’t see any differences no matter it is 500% or 20000%.. What is “Initialize” and “Oline” in the main menu?
    I tried to contact to Lichuan technical support but of course no reply yet for 10 days.
    Any help will be very appreciated
    Many thanks
    Lives in East Lothian, United Kingdom. Last Activity: 4 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,909. Received thanks 360 times, giving thanks to others 8 times.
    I'll be honest, that as much as I think Lichuan products themselves and the sales team are pretty good, their software is horrendous!
    Oline, should be Online (aka Realtime monitoring), although I'm not sure what exactly it can monitor...
    I received the first English draft of one of their manuals for some drives I got for testing, and it has an automatic translation of the original Chinese software-
    Unfortunately they didn't use that when they translated the software, so the software doesn't match the manual.
    Thank you. I’ll try it a bit more over the weekend and will see. If any successes I’ll share here
    If you've used a "proper" GUI such as you get from Yaskawa, the Lichuan "software" seems pretty underwhelming. I've only use the Lichuan servo products but the stepper screenshot looks fairly similar. If so, then you download the parameters into the "GUI"(?) which is little more than a display table, change the parameters you want to change and then save it back ("write parameter"?). If that's what you were doing and still no cigar, then I've no idea what the problem is.
    Presumably Jazz is your man for expert Lichuan questions here.
  1. FOR SALE: Lichuan 4.5Nm Closed loop stepper systems
    By JAZZCNC in forum Items For Sale
    Last Post: 29-07-2021, 05:48 PM
  2. Replies: 0
    Last Post: 28-03-2021, 06:27 PM
  3. Toroidal Transformer for Lichuan 5.5Nm closed loop steppers.
    By handles in forum General Electronics
    Last Post: 06-10-2020, 09:48 PM
  4. Buck Boost Transformer 380V 240V 3Phase
    By brandon_costa in forum Motor Drivers & Controllers
    Last Post: 28-08-2018, 05:38 PM
  5. Replies: 0
    Last Post: 02-01-2018, 10:56 AM
