    I am trying to set the default Stepper frequency in Mach3 and I cannot find the setting, for completeness I am going through a CSMIP controller first and our Stepper controllers (EM542S Controller) are set at 25k
    Is this right or wrong?
    Lives in East Lothian, United Kingdom. Last Activity: 5 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,909. Received thanks 360 times, giving thanks to others 8 times.
    Stepper frequency will be the result of the steps per unit, and the feedrate.
    It's been a while since I've used Mach 3, but I don't think you even set the maximum frequency, it just relies on the max feedrate and steps/unit.
    Also CS-Labs may move some of the settings to their own plugin.
    Something to be aware off, is the older Leadshine drivers need longer than normal direction setup timing, but I'm not sure about the newer EMS drives. It was certainly the case with the older EM drives.
  1. eBay: cnc controller for mach3 or linux
    By rrossetti in forum Items On eBay UK
    Last Post: 27-02-2016, 01:33 PM
  2. Mach 3 default settings,
    By chris w in forum Artsoft Mach (3 & 4)
    Last Post: 08-01-2016, 01:54 PM
  3. USB/Ethernet controller for Mach3/4 advice
    By paulus.v in forum Control Hardware & Systems
    Last Post: 17-02-2015, 09:37 PM
  4. stepper with DIY type controller
    Last Post: 11-02-2015, 05:15 PM
  5. USB and Ethernet Mach3 motion controller PLCM-E3
    By Purelogic R&D in forum Manufacturer News
    Last Post: 29-12-2012, 09:38 AM
