    So, I'm in need of a spindle holder or two,
    would it be possible for one of you to make one or two for me?
    the spindle is 80mm in diameter so it should be simple to make.
    I can buy the alu needed and pay postage both ways,
    All I will need of you is your time, machine and your skills.
    Thanks.
    Me again...
    I've made a few 80mm spindle mounts (only one picture shows finished mount):
Name:	DSC07628 (Medium).JPG
Name:	DSC07627 (Medium).JPG
Name:	80mm spindle mount2.jpg
Name:	DSC08036 (Medium).JPG
    The drawing is just an example - if you want a different size or to draw your own that's fine. I have got aluminium in stock to do up to 150mm wide and 1/2" thick, or 5/8" thick and 125mm wide.
    If you're interested send me a PM or make me an offer...
    Jonathan,
    Do you think that mount is strong enough? it looks to be very thin near the clamping bolt (If my maths is right, 4.7mm) and you have a sharp internal corner at this point too. With this stress concentration and the cyclical loading that a spindle typically gets, I wouldn't expect it to be too long before a crack appears.
    Yes I thought that looked like a weak point when I'd made it. Once it's clamped on to the spindle it can't bend, so fatigue shouldn't be an issue. It seems perfectly solid.
    That's why on the next version (last photo) I rounded off that corner and moved it further from the spindle to make it stronger. Changing the drawing is not a problem.
    If it breaks naturally I would replace it free of charge.
    Possibly a bit late now, but just in case anyone reads this and is interested in one here's the 'latest version' without the aforementioned weaker point:
Name:	DSC08268 (Medium).JPG
    One with the clamping bolt at the side:
    Hi Jonathan,
    I could be interested, ive got one of these spindles sitting on my bench waiting to be fitted!, what sort of price you looking for?
    Jonathan,
    have you been copying my design ?
    Only kidding. Mine is very similar, basically the same shape but without the rounded off corners seeing as I made it on the milling machine then lathed out the inside.
    I have just cut two more alu plates today at work and I am going to make two more spindle mounts and see if I can get two identical mounts that are a better fit for the spindle than the last one I made.
    My original plan was to make two as my first job for the cnc machine but I am still having problems trying to get USBCNC to work properly and also my workshop pc died earlier tonight. At least the weather was nice today!
    Ian
    Jonathan,
    Not seen yours...
    [QUOTE=Web Goblin;23056] Mine is very similar, basically the same shape but without the rounded off corners seeing as I made it on the milling machine then lathed out the inside.
    I see, same as the one I made with my CNC router then bored on the lathe...last photo in post #2 shows it before boring.
    Jonathan,
    I would have loved to make them on the router, that way they would have been identical. Why didnt you mill out the inside completely on the router?
    Ian
    I did them on my router as it's far quicker than the milling machine. I left small (1mm thick) tabs so that the middle bit didn't go walkies on the final pass. Boring the hole is more accurate (by accurate I mean it's closer to a circle, and better finish) than milling it.
  2. WANTED: 2.2 KW Chinese Spindle
    By Chaz in forum Items Wanted
    Last Post: 17-06-2013, 10:03 AM
  3. WANTED: Chinese 1.5kw spindle/vfd
    By Philly in forum Items Wanted
    Last Post: 10-02-2013, 11:44 AM
  4. Aluminium Kress Spindle Holder
    By Lee Roberts in forum Metalwork Project Showcase
    Last Post: 16-07-2009, 12:00 AM
  5. Kress Spindle Holder
    By GTJim in forum Kress Milling Motors
    Last Post: 25-05-2009, 07:02 PM
