    Hello everyone,
    The time has come unfortunately to sell my kit. It's no longer earning its keep so up for grabs is my complete 4 axis machine.
    I also have this listed on ebay AUCTION LINK HERE.
    Im looking for offers in the region of £2650 for the lot if anyone is interested?
    Any questions, I will try my best to answer them!
    Pictures at bottom of listing....There are more images on the ebay listing if you are interested.
    Sorry but I would like to sell the whole lot in one lump as I dont have the time to sell everything individually.
    Machine Dimensions:
    Total Footprint: 1005mm x 1080mm
    Bed Size: 795mm x 1000mm
    Cutting area: approx 630mm x 880mm (plus 120mm if using overhang)
    Height from floor to bed: 310mm
    Total machine height: 950mm
    Motor Specifications:
    4no. Nema 23 stepper motors (76mm x 57mm) Click here for spec
    All necessary cables & connectors
    4th Axis:
    Heavy duty cast rotary axis for machining horizontal items such as bannisters etc.
    I have never got around to making use of this component (or learn how to use it) but I have checked that it works.
    The Z-Axis is adjustable to allow for clearance of the rotary 4th axis
    Cutter:
    Kress 1050 FME Click here for spec
    -The Kress cutter can run at 6 speeds and automatically adjusts force to the resistance of the material being cut
    Includes the following additional components:
    -5no. collets: 3mm, 6mm, 8mm, 1/8" & 1/4" Click here for spec
    -3no. Collet nuts Click here for spec Click here for spec
    -6mm flute cutting bit
    -8mm tri blade flute cutting bit
    -1/4" V-cutting bit
    -Set of fine etching bits ideal for detail work
    I have upgraded the X & Y axis lead screws fairly recently with quality ball screws for extra precision, the Z axis lead screw runs on a nylon nut.
    Power Supply & controller:
    Controller board mounted in a metal casing for connection of all four axis connections.
    24V power supply with all cables and connections
    The control board & power supply are housed in a plastic container to protect them from dust. The container has two fans connected to the PCto keep them cool and away from dust.
    PC & Software:
    Monitor
    Keyboard & Wireless Mouse
    Standard windows PC with Mach 3, V-Carve Pro as well as Vectric Cut 3D & Cut 2D software installed and ready to go.
    Additional Items:
    Spanner for changing cutting bits
    3-in-1 oil for ongoing lubrication of parts
    2 additional spindle mounts for routers with collar diameters of 52mm and 62mm.
ID:	5389Click image for larger version.
    Ha ha love the tupper ware control box. . . .Classic..:dance:
    I was quite impressed with the unsupported rails on the Y instead of a beam.
    John S -
    Sure I've seen a similar machine recently.? . . . . Maybe this is MK1. .
    dont know what you mean.:rofl::rofl:
    The more I know, I know, I know the less. (John Owen)
    Hi are those 12mm precision ballscrews? it's a little bit blurry.
    same cutting bed size as mine but a tad over priced me thinks:lmao:
    love the Tupperware also
    James
  1. Q: Start Kress 1050 with Gecko540?
    By Trulsen in forum Kress Milling Motors
    Last Post: 01-10-2013, 04:50 PM
  2. eBay: Kress 1050 FME-1 Spindle
    By viz in forum Items On eBay UK
    Last Post: 21-08-2013, 04:04 PM
  3. eBay: Kress 1050 FME router
    By rbs in forum Items On eBay UK
    Last Post: 08-05-2012, 12:40 PM
  4. Where's the cheapest place to buy a Kress 1050?
    By Jonathan in forum Marketplace Discussion
    Last Post: 05-01-2011, 07:00 PM
  5. collets for a Kress 1050
    By groov in forum Kress Milling Motors
    Last Post: 20-08-2009, 11:54 PM
