    kell's Avatar
    Lives in doncaster, United Kingdom. Last Activity: 05-08-2023 Has been a member for 9-10 years. Has a total post count of 53.
    Just ordering some parts for the comp which will run the cnc when its built and jazz told me the port i will need out of pc (but i have now forgot ) when i need to remember ?
    is it a paralel port and i know that cannot be spelt right ?
    Lives in East Lothian, United Kingdom. Last Activity: 2 Days Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,911. Received thanks 360 times, giving thanks to others 8 times.
    Parallel/LPT port
    If your Breakout board needs a parallel connection and you don't have a printer port on the back of your computer (magenta 25pin female D) then you can get a PCI card which will give you two. I run Mach3 using one of the outputs and it is OK. http://www.eclipsecomputers.com/prod...ode=IO-PPRINT2
    Check that you have a spare PCI slot though !!
    Cheers, Rob
  1. USB TO Parallel Port DIY Interface
    By Lee Roberts in forum Electronic Project Building
    Last Post: 17-02-2018, 07:46 PM
  2. new computer with parrelel port?
    By kingcreaky in forum Computer Hardware
    Last Post: 25-04-2014, 06:52 PM
  3. Replies: 12
    Last Post: 25-05-2013, 12:41 AM
  4. vista - parallele port = help
    By Dan Brown in forum Gantry/Router Machines & Building
    Last Post: 16-11-2009, 11:11 PM
  5. Laptop, ie no parallel port?
    By tompsky in forum Laptops & Tablets
    Last Post: 11-11-2008, 07:12 PM
