Thread: 3 Axis CNC router
16-11-2012 #71
16-11-2012 #72
It's certainly strong enough, but the 50mm thick aluminium seems a bit over the top. It's a mildly interesting part to machine though so I'd do it cheaply as I tend to charge less if the part is interesting! You could replace it with 2 pieces.
06-12-2012 #73
I am now the proud owner of some shiny new taps
06-12-2012 #74
06-01-2013 #75
06-01-2013 #76
Did Jonathan make you the X Ball Nut/Endplates? any pics?
06-01-2013 #77
06-01-2013 #78
Welding wood you should be ashamed of yourself...tck tck tck!
06-01-2013 #79
It's cheaper that steel! No fires yet
04-03-2013 #80
OK, so I'm getting the hang of this welding business and selling all of my possessions to afford the steel!
here are some images of the steel frame design so far:
It consists of
1no. 6000 x 50 x 50 x 3mm SHS for the bed
2no. 6000 x 100 x 50 x 3mm RHS for the legs and cross members
1no. 6000 x 75 x 50 x 3mm RHS for the bearings and ball screws to mount to
1no. 6000 x 60 x 6mm flat for the plates and cross bracing
1no. 3000 x 60 x 6mm flat for the plates and cross bracing
1no. 1500 x 60 x 60 x 6 RSA for the brackets
Now all seems fine till I cost the sucker up and it comes in at (Internet price) £460 - a little over what I was hoping!
Now I reckon I can get this down by going to a local supplier, but not by a lot.
The other idea is to take the 100 x 50 x 3 box section down to 50 x 50 x 4 which will save about £60. I cant think of any other ideas. Do you think the loss in section size will be offset by the increased weight?
maybe i'm over designing the whole thing and it could all come down in size?? I know Jazz has mentioned somewhere that skimping on the frame is a bad idea due to resonance issues - but how far do you go? I mean I'm not casting it as one lump of iron!
One other thing. I am welding plates onto the end of most box sections and then bolting together so as to allow for a bit of adjustment, and I'm not planning on welding the RHS's that take the bearings / ball screws so as to limit heat distortion. Trust this is a smart move?!
Joe
BUILD LOG: 3 Axis Router
By GTJim in forum DIY Router Build LogsReplies: 8Last Post: 22-06-2020, 08:49 AM -
3-Axis CNC Router - For Helices.
By Dalmango in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 08-02-2014, 07:27 PM -
BUILD LOG: Wobbly: my first 3-axis router
By Sodster68 in forum DIY Router Build LogsReplies: 8Last Post: 20-01-2013, 10:28 AM -
3 axis cnc/router bed
By dudz in forum Marketplace DiscussionReplies: 23Last Post: 28-12-2012, 09:38 PM -
Need 6' x 4' bed, 4 axis router design.. Help..!
By fasteddy in forum Gantry/Router Machines & BuildingReplies: 29Last Post: 17-09-2010, 12:56 PM
