Thread: 3 Axis CNC router
24-10-2016 #301
24-10-2016 #302
25-10-2016 #303
yes yes confirmed.
Will do, was hoping some of you lot would want to get more involved and man the organizing/setting up?, someone to "take the reins" as they say would be nice.
I cant do everything, all at the same time. Wish I was an octopus i've got that much going on, if no one wants to lead the way on this then it will just be something I do at my own leisure.
I'm still not well at all so the last thing I need right now is more things to stress about, I'd much rather wait and fully enjoy the endeavour.
.Last edited by Lee Roberts; 25-10-2016 at 11:36 AM.
.Me
03-12-2016 #304
Small update:
The Following User Says Thank You to JoeHarris For This Useful Post:
It's alive, well nearly Always nice to see it move
03-12-2016 #306
Yes, great moment when something moves under power! Now, if you can sync two cordless drills for testing master plus slave axes...
Edit - just flicked back and see you are using the long-belt sync method. Saves requirement for synchronised cordless drillsLast edited by Neale; 03-12-2016 at 09:24 AM.
03-12-2016 #307
03-12-2016 #308
I always fancied using my router like an etch-a-sketch with drills 😁 Well done Joe, its getting better and better...
The Following User Says Thank You to njhussey For This Useful Post:
10-12-2016 #309
Sorry Joe just looking back at your build and didn't see these questions. So here goes.
Yes still want fault signals in E-stop. What I meant was use another contact on the Relay and run 24V thru it which then turns on Mains Contactor.
Only the Shield of the Motor cable and only the control box end needs grounding to Star point. To save wasting wire and stripping insulation back so shield wire reachs star point and drives just run single wire from Star point to point near drives and solder to the Shields or use connector block.
The Earth wire on the Plug and the Star point should be the same thing, that's the whole idea. You have one Point that the main Earth comes into which is then distributed to all that need Earth. You also take all shields back to this point.
So in this case if the VFD is in the main Control box case (which personally I don't like) and turns on with control box you would take to Star earth point.
The shield for Spindle cable is best or easier if connected to the Earth Terminal in VFD.
If the VFD is external then just use the cables earth wire back to Plug. Same connection as above applies with shield.
IP-M Earth goes to the Star point.
10-12-2016 #310
BUILD LOG: 3 Axis Router
By GTJim in forum DIY Router Build LogsReplies: 8Last Post: 22-06-2020, 08:49 AM -
3-Axis CNC Router - For Helices.
By Dalmango in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 08-02-2014, 07:27 PM -
BUILD LOG: Wobbly: my first 3-axis router
By Sodster68 in forum DIY Router Build LogsReplies: 8Last Post: 20-01-2013, 10:28 AM -
3 axis cnc/router bed
By dudz in forum Marketplace DiscussionReplies: 23Last Post: 28-12-2012, 09:38 PM -
Need 6' x 4' bed, 4 axis router design.. Help..!
By fasteddy in forum Gantry/Router Machines & BuildingReplies: 29Last Post: 17-09-2010, 12:56 PM
