18-10-2012 #6
Indeed, I've realised that (it's something obvious if you've ever used a CNC, says something about me I guess) and came out with this to allow for the boards to match:
it's simply a cut into the corner until the tool bit touches the 'corner' of the original square, which takes the corner off, but leaves the sides intact. I'm sure this is an often used cut on squares.
Regards,
TomLast edited by dsc; 18-10-2012 at 01:42 PM.
RFQ: Joint assembly needed making from 7075 T6 billet.
By dudz in forum Projects, Jobs & RequestsReplies: 2Last Post: 06-11-2013, 11:26 PM -
ballnut housing and floating end ballscrew assembly
By dsc in forum Lead Screws, Nuts & SupportsReplies: 12Last Post: 12-07-2013, 08:22 AM -
RFQ: simple plates for a z axis assembly - 15mm Ecocast Alu
By dsc in forum Projects, Jobs & RequestsReplies: 7Last Post: 04-01-2013, 04:31 PM -
Z axis assembly - unsupported rail for very limited movement
By dsc in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 10-10-2012, 12:44 PM -
RFQ: RFQ: Aluminium gear selector assembly
By Bokoshoko in forum Projects, Jobs & RequestsReplies: 2Last Post: 30-08-2011, 10:32 AM
