07-12-2012 #1
Had a strange one or may be two today, first I put a sheet of 15 mill ply on the bed and did a 300 x 200 area clearance @ 5mm. All went fine no problems, until I put in an engineer square and it was out over the 200 length by 3mm! I took off the ply and put in a block of 200 x 250 @ 15 mm and did a profile 5mm in, all-round the edge of the block @ 5 mill deep, using the front of the bed to square up the material. The first time I did it at normal 72 feed it seemed to stick on the y axis (the bed moving Forwards toward me), then there was a sort of small bang and it went off again. The spindle returned to the origin and it was 6 mm off along the y axis. I reset and flipped the blank then dropped it to 60% feed rate, restarted the job. This time it ran perfect and all the angles on the job where correct, any ideas what’s going on?
Ralph Waldo Emerson
FOR SALE: Denford MIRAC CNC Lathe. Single Phase. Absolutely complete and perfect running order.
By Nick Butler in forum Items For SaleReplies: 19Last Post: 21-08-2013, 11:20 PM -
Need a perfect 8mm hole - to ream or bore?
By HankMcSpank in forum Machine DiscussionReplies: 26Last Post: 12-03-2013, 12:42 PM -
a perfect 90deg joint - 15mm Alu
By dsc in forum Gantry/Router Machines & BuildingReplies: 12Last Post: 24-02-2013, 01:31 PM -
Z axis not cutting to required depth
By dinasblu in forum Machine DiscussionReplies: 10Last Post: 02-07-2012, 05:38 PM -
XYZ Centurian 450 VMC tools sticking during tool change (M06)
By craftydonkey in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 19-10-2011, 03:11 PM
