11-03-2016 #151
I think the first post of this thread needs to be updated with the following information:
- If you're controlling the spindle speed from Mach3, you also need to:
- set PD002 to 1. It might be done automatically, but it's worth checking.
- change the jumper on the right side of the VFD control terminal to VI instead of VR - Set PD070 according to your BOB's specifications. It is the input voltage that the VFD receives on its control terminal. My BOB sends 0-10V, so I had to change the setting. Check the manual for more information.
Cheers,
G.
21-04-2016 #152
Jazz previously suggested upgrading the coolant fittings on these spindles for some push fit/lock type, I like this idea so here is a link to some on eBay:
High Pressure Metal Push-in Fittings for Air or Central Lubrication Systems Tube
http://m.ebay.co.uk/itm/271182576634
You want the M8x1 fine thread option for the correct fit, dose/maybe the OP wants to add this info to the first post.
EDIT: Better prices and info can be found here:
http://www.mycncuk.com/threads/9452-...g?goto=newpost
.MeLast edited by Lee Roberts; 22-04-2016 at 01:49 PM.
.Me
29-04-2016 #153
OK, guys so before I start plugging in wires is this diagram right?
I want to be able to start the spindle and control the RPM from the EDINGCNC Software
Link to the board manual in case needed http://www.edingcnc.com/upload/files/cpu5a_flyer_tech.pdf
29-04-2016 #154
Don't know if its just me but clicking on your diagram to view it locks my system, could be links blocked on my sysem for security reasons but only image on site I've tried to view that does this.
29-04-2016 #155
Not quite sure what it should be, but I don't think that there should be any connection to the "spindle sensor" pin. That's for sensing spindle position on a lathe for threading purposes, nothing to do with router spindle. I think you've wired the VFD so that it is forward-running only (no reverse, which seems reasonable) but there's no spindle start/stop signal from the board to VFD. I don't know how the Eding board and software handle for/rev or start/stop - I'm going through the same wiring design process with CSMIO/Mach3 and VFD which is a better-documented route.
29-04-2016 #156
Yeah seems a bit of a headache
29-04-2016 #157
The Following User Says Thank You to eurikain For This Useful Post:
29-04-2016 #158
29-04-2016 #159
As far as I can see, the Eding manual says that you use the "tool" output pin as a start/stop signal to the VFD but I haven't worked out for myself which VFD pin it goes to yet - still reading that manual!
29-04-2016 #160
Chinese Spindles
By Ricardoco in forum Generic Chinese SpindlesReplies: 123Last Post: 05-12-2016, 12:16 AM -
Info on Chinese suppliers, their reliability and reputation
By Want2build1 in forum Marketplace DiscussionReplies: 38Last Post: 07-12-2013, 09:37 PM -
NEW MEMBER: Seeking advice on a CNC setup for (one off) machining carbon fiber plate
By Tomcat in forum New Member IntroductionsReplies: 0Last Post: 03-03-2013, 01:43 PM -
Chinese spindles
By Colin Barron in forum Marketplace DiscussionReplies: 15Last Post: 23-08-2011, 08:58 PM -
Chinese 1.5kw Spindles
By jcb121 in forum Generic Chinese SpindlesReplies: 12Last Post: 28-07-2011, 06:20 PM
