Thread: tb6560
07-04-2013 #1
hi
what do the folks on this site think of the 4 axis tb6560 motor driver
07-04-2013 #2
Here are a couple of threads that will give the general idea...
http://www.mycncuk.com/forums/motor-...er-boards.html
http://www.mycncuk.com/forums/motor-...ay-update.html
I Suspect there will be a few people using them who have no problems, but i understand they dont like to be pushed, it that is the word..
RickAlways bear in mind that your own resolution to succeed is more important than any other - Abe Lincoln
The Following User Says Thank You to Ricardoco For This Useful Post:
07-04-2013 #3
In a short reply - Crap
The Following User Says Thank You to John S For This Useful Post:
07-04-2013 #4
07-04-2013 #5
hi
what else can i use
07-04-2013 #6
07-04-2013 #7
Her who must be obeyed has given me permission to buy three of 2M542's and the board that goes with 'em although I've noticed 542H - emailed the seller as to what the H is but no response yet, if I don't get one within the next few days I'll just grab the 542's as the price difference is an additional 60+/- a bit quid all up. . .
Addon Bit: Found out the difference, the 542 has a typical supply voltage of +36, whereas the 542H has a +50Last edited by Carlb1058; 08-04-2013 at 12:12 AM. Reason: info found
Carl
Cardiff City Supporter ~ Real Sporting de Gijon Supporter ~ Vintage Synthesizer Collector
La gente dice que tu vida esta planeado, me gustarķa encontrarse con el jefe de planificacion para que yo pudiera darle un punetazo en la cara!
The Following User Says Thank You to Carlb1058 For This Useful Post:
08-04-2013 #8
Carl
I run my 542's (or 2m542, same spec) at 42v the 'H's can run at slightly more current i believe (4.5). For your set up the standard 542's will be fine, ignore the +50 bit as well. 50v is really max for these drivers.If the nagging gets really bad......Get a bigger shed:naughty:
The Following User Says Thank You to Swarfing For This Useful Post:
1 axis tb6560 any good?
By lazzymonk in forum Motor Drivers & ControllersReplies: 15Last Post: 08-08-2012, 07:58 AM -
TB6560 auto current reduction
By Mjolinor in forum Motor Drivers & ControllersReplies: 1Last Post: 08-12-2011, 09:53 PM -
Who knows this updated chips than TB6560?
By Christina in forum Motor Drivers & ControllersReplies: 0Last Post: 25-11-2011, 08:26 AM -
TB6560 Motor Match
By Telly in forum Motor Drivers & ControllersReplies: 10Last Post: 22-02-2011, 06:29 PM -
TB6560 > Timer > GMFC
By Theo in forum Motor Drivers & ControllersReplies: 0Last Post: 17-10-2010, 06:59 PM
