    Hi all, My Friend has asked me How to Use CNC to cut many items from an 8x4 x 1-2mm stainless sheet, he is making some odd shaped items that have an area of about 6" square but the edge finish has to be precise, and I couldn't think for the life of me how I would do it. What would you guys suggest for the cutting and holding, the nesting isn't a problem..
    Rick
    S/S is notorious for wearing cutters out and you have to use slow speeds and high feeds to prevent work hardening. Complicated shapes are best cut using a none-contact method such as water jet, laser or plasma.
    EDIT:
    Depending on quantity, would it be worth making press/punch tools from tool steel?
    Quote Originally Posted by birchy View Post
    S/S is notorious for wearing cutters out and you have to use slow speeds and high feeds to prevent work hardening. Complicated shapes are best cut using a none-tool method such as water jet, laser or plasma.
    Waterjet would be a no no for me, and well Plasma is not out of the question but the finish is not great when I use mine by hand, and I suspect although better with CNC its not that great either although I'm not Certain of that. And laser, well if I could have a laser that would cut 2mm metal of any kind I would jump at that but I understand the lasers cost a packet...
    Rick
    TBH, plasma would be a last resort as the finish usually requires a bit of fettlin'. Stainless will cut OK on a mill if you use Cobalt tools and suitable speeds and feeds with plenty of coolant.
    On an 8x4 sheet I think plenty of coolant would be fun to say the least LOL I was wondering if it would be worth advising him to get a tool made for a press rather than a CNC..
    Shearing would probably be the cleanest method but it depends how complex the piece is. Another off-the-cuff option is a CNC nibbler. Never seen one, but I'm sure they must exist.
  1. RFQ: Water or laser cut stainless flanges
    By r0bsk1 in forum Projects, Jobs & Requests
    Last Post: 23-09-2013, 08:12 PM
  2. RFQ: RFQ: Micro Precision in Stainless Steel.
    By mikewatch in forum Projects, Jobs & Requests
    Last Post: 12-04-2013, 11:49 PM
  3. RFQ: 16mm long stainless pins with m5 tap
    Last Post: 11-03-2013, 03:12 PM
  4. stainless steel fasteners - quality
    By dsc in forum Metalwork Discussion
    Last Post: 30-11-2012, 12:35 PM
  5. Mini lathes - possible to turn stainless?
    By HankMcSpank in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 03-08-2010, 03:14 AM
