06-09-2013 #1
I am putting together a cnc based guitar pickup winder and need some help with power. The winder has 2 stepper motors - one rated at 3.4v / 1.68a and the other at 2.8v / 1.68a
How do I power these motors? Do I need 2 power supply's for the different voltages?
Also any recommendations on good, cheap, easy to set up drives and breakout board would be appreciated.
As you can tell, I am very new at this. If this project goes well I am going to build a cnc for guitar body's and necks.
06-09-2013 #2
If you work a rule of thumb Max 20x the rated voltage of the lowest motor you'll be ok. . . .BUT . . The drives you use may be the limiting factor more than the motors.? . . . For instance if you take the 2.8 and 20x rule then thats 56Vdc so you'll need drives capably handling higher than this value.
Mostly drives come in 2 basic voltage flavours upto 50Vdc and upto 75-80vdc. So if you buy 50V drives then you'll need to run these motors around 44-45vdc Max, you never run at drives maximum rated voltage has steppers generate electricity at times and can pass this back and blow drives so safety factor needs allowing.
Now you don't need to run these steppers at 56v they will happily work at lower voltages like 24-36Vdc but at a reduced speed/torque. Most drives won't work below 24Vdc.
Before recommending a drive, Even thou they will probably easily do what you want for guitar winder I will recommend that you don't buy the cheap TB chip based All-in-one boards has they are very poor quality and can be unreliable, they are also easily damaged in the hands of inexperienced users.!! . . .Stay clear is my advice.
Now if you want to buy drives that can migrate to a CNC machine then you'll want to buy decent drives and not skimp, it's false economy and leads to poor and often frustrating results.
So if just drives for a winder and to test the waters of a CNC machine then I'd say buy any of the cheap Chinese drives like these CNC Mill Router DIY CNC Stepper Driver Board Controller M542 1.0A-4.5A 20V-50VDC | eBay
If you want to build a decent CNC machine then I'd say wait and select drives when you know better what your building.!!
Digital drives are becoming cheaper every month and for best machine you'll want these so I'd wait until the time then buy. You'll also know better then if larger motors with higher voltages are required.
08-09-2013 #3
Thanks very much for the reply - I now have a better understanding of my power requirements. With regards to stepper drivers I have seen some that are 3 axis rather than individual for each stepper motor. Is this a good idea or are they not recommended?
Thanks in advance for the advice.
08-09-2013 #4
No chances are these are the TB based boards I suggest you stay away from. The only multi axis board I recommend is the Gecko G540 which is 4 axis and not cheap but is a high quality unit with good support and excellent warranty.
If you can post linkto what your looking at will take a look.!
08-09-2013 #5
Use 24v and the cheapest drives you can find. It's a pickup winder!
08-09-2013 #6
08-09-2013 #7
08-09-2013 #8
No he won't need to over spec the PSU those motors will easily handle 50V so running at 44-45Vdc on 50V drives will be fine for most small to medium machines or winder, so they will migrate nicely when the time comes and he will be getting optimum performance from the drives/motors at all times.
24V on the other hand while perfectly fine for a winder will be very restrictive in speed terms for a CNC machine. TB based 3 axis boards will probably run fine without issues at 24V but they don't like staying alive much after 36V.
The motors are capable of running above 50V so why not have the ability to use there full potential, Better to have spare capacity than be lacking at later date when needed.
09-09-2013 #9
09-09-2013 #10
Only in terms of amps but he'll only pull what's needed there.!! . . . . But yes your correct I am assuming he's thinking to use same motors where he might not.!!. . . But still he possibly could want to use the same drives and if he had 50V drives with 44V 8-10A psu then he easily could do it where has with poxy TB based drives then it start again from scratch.!!
Anyway only he knows where he wants to go we just point out the different directions he can take.!!Last edited by JAZZCNC; 09-09-2013 at 12:30 AM.
ebay power supply
By irving2008 in forum General ElectronicsReplies: 91Last Post: 29-04-2012, 06:28 PM -
Minimal-cost Power Supply Strategy - Repurpose Laptop Power Supplies
By LoveLearn in forum General ElectronicsReplies: 0Last Post: 25-01-2012, 09:29 PM -
FOR SALE: 50V 20A Power supply
By Jimmybristol in forum Items For SaleReplies: 8Last Post: 30-05-2011, 11:01 PM -
power supply problms
By Scott in forum General ElectronicsReplies: 13Last Post: 11-07-2010, 12:58 PM -
power supply
By hitmythumb in forum General ElectronicsReplies: 6Last Post: 21-06-2009, 10:27 AM
