    I was planning on making a little box, kinda only just realised a box (aka finger) joint might have issues with drill bits been cylindrical so I don't think it'll work.
    Is there another type of joint I could use instead that's a bit more straight forward to do on a CNC router, I was thinking a groove joint?
    Thanks for any advice,
    Mark.
    A finger joint is made easily with an end mill or router bit
    Place your work vertically and cut away 1 diameter of your bit and the thickness of the material deep step along by the diameter and repeat
    on the mating part step first and cut away
    you need to calculate your length of side so it works out to a full number of fingers
    Ian
  3. The Following User Says Thank You to IanParkin For This Useful Post:
    That's an interesting idea, I was planning to do this with decent birch plywood, do you think it'd work ok with that?
  5. #4
    Yes thats as good a wood as you can get without using a hardwood
    I use it extensively for utility boxes
    If you can do two at once with a sacrificial backing to avoid breakout
  6. The Following User Says Thank You to IanParkin For This Useful Post:
  7. #5
    Lives in Marple Stockport, United Kingdom. Last Activity: 21 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 3,333. Received thanks 618 times, giving thanks to others 78 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by mark84 View Post
    Mark.
    Now how about these that I found in the woodworking section:- 50 Digital Wood Joints | Flexible Stream ..Clive
  8. The Following User Says Thank You to Clive S For This Useful Post:
  9. #6
    Wal's Avatar
    Lives in Stockport, United Kingdom. Last Activity: 4 Weeks Ago Has been a member for 9-10 years. Has a total post count of 491. Received thanks 71 times, giving thanks to others 29 times.
    Great link, Clive - some really nice stuff on there..!
    Wal.
  1. Making the frame square
    By cropwell in forum Gantry/Router Machines & Building
    Last Post: 08-03-2014, 11:00 PM
  2. RFQ: aluminium mold making
    By kell in forum Projects, Jobs & Requests
    Last Post: 24-03-2013, 01:40 PM
  3. Mold Making?
    By Shinobiwan in forum Moulding Machines
    Last Post: 27-02-2013, 02:15 AM
  4. Anyone making fitted kitchens?
    By Chas in forum Woodwork Discussion
    Last Post: 31-01-2013, 05:29 PM
  5. Making a Jig
    By Wobblybootie in forum Gantry/Router Machines & Building
    Last Post: 06-06-2010, 11:17 AM
