More workshop stuff . . .
30-01-2020 #2
Episode 2 : making the control box and deep dive into the XSY AT1 inverter setup. Impressed so far (for the price) . .
30-01-2020 #3
Beautiful control box. Really enjoyed the vid.
Small comment re: the pot they are usually 10K lin. not log. (I know you say not say log)
I am pretty sure you can go from forward straight to reverse without problems. The ramp up and down seems very conservative.
31-01-2020 #4
Hi Clive,
Thanks, I didn't know if people would find it interesting or not as it ended up quite long.
I'm intrigued by the pot comment - did you hear me say 'log' or are you saying it is worth clarifying ? I'll need to watch it again ! There was a bit of audio clipping in places which might have made it sound like I said something else.
The accel and decel rates are the defaults and yes you can switch between forward and reverse straight away and the inverter will ramp between them. I'll set those up when it is on the machine and driving all the correct inertia loads (pulleys, spindle, chuck, and large drill). There is a limit to the braking as it is all done inside the inverter (this model does not have external brake resistor option).
31-01-2020 #5I'm intrigued by the pot comment - did you hear me say 'log' or are you saying it is worth clarifying ?..Clive
31-01-2020 #6
31-01-2020 #7
RE: Machining 1050 plate it's better to cut thru it in a single pass using a slot mill rather than trying to mill it away.
30-01-2020 #8
31-01-2020 #9
Hi Voicecoil
You are welcome. I'm impressed with it so far . . . .
31-01-2020 #10
Good quality pillar drill?
By newtoid1986 in forum Machine DiscussionReplies: 6Last Post: 19-04-2013, 01:40 PM -
Pillar Drill Restoration
By Treemonkey in forum Machine DiscussionReplies: 0Last Post: 24-03-2013, 07:42 PM -
pillar drill?
By wilfy in forum Machine DiscussionReplies: 22Last Post: 10-11-2012, 09:18 PM -
Something for the metalworking guys
By John S in forum Computer SoftwareReplies: 1Last Post: 21-06-2010, 11:00 PM -
Dead pillar drill...
By irving2008 in forum Machine DiscussionReplies: 11Last Post: 27-10-2008, 03:54 PM
