28-04-2015 #1
Howdy,
I use an early version 1 of Mach cnc. I mostly mill complex low relief forms in polystyrene using Aspire to write the gcode. I have started recently to use the profile cut mode in Aspire. It has highlighted an issue which I need to address.
In profile mode, infact all modes the program has a tendency to not cut into corners preferring the shortest distance. I therefor must need to instruct Mach and or Aspire to slow/ recognise certain angles.
My question is how do I do this? Do I need a different version of Mach 3, and which page allows me to make the alterations to stop it cutting corners.
Are you using bits that are a greater dia than corners you are cutting? ..Clive
28-04-2015 #3
Hi Clive,
Thanks for reply. The bits are less dia than the corner radius.
28-04-2015 #4
You might be better posting some Gcode Have a read through this http://www.cnczone.com/forums/mach-m...are-posts.html ..Clive
28-04-2015 #5
i think the issue I have is related to Constant Velocity versus Absolute Stop on the Config page of Mach.
28-04-2015 #6
I think there is a setting for this in Mach on the settings page. Clive
28-04-2015 #7
It's not that simple really. Chances are you have the acceleration to low for the commanded speed and radius your asking the machine to do.
Try turning acceleration up and Velocity down then try again and you may find it works.?
What is your acceleration set at and what feed rates are you trying to cut with what radius etc. Posting the Gcode would be best.
28-04-2015 #8
Here are the g-code and three screen grabs from Mach and one from Aspire. I've enlarged part of the screen to show how the toolpath shows it cutting corners on both the N and M on the text being cut out. I can post more/ or less if helps. Apologies for the large amount of gcode, I can post less in future if its suggested where I cut and paste.
Gcode
( myname3-Quick Engrave 2 )
( File created: Thursday, April 23, 2015 - 03:09 PM)
( for Mach2/3 from Vectric )
( Material Size)
( X= 150.000, Y= 150.000, Z= 6.000)
(Toolpaths used in this file:)
(Quick Engrave 2)
(Tools used in this file: )
(1 = End Mill {2 mm} xta slow)
N100G00G21G17G90G40G49G80
N110G71G91.1
N120T1M06
N130 (End Mill {2 mm} xta slow)
N140G00G43Z20.000H1
N150S50M03
N160(Toolpath:- Quick Engrave 2)
N170()
N180G94
N190X0.000Y0.000F3600.0
N200G00X5.231Y-11.135Z5.999
N210G1Z-1.000F1200.0
N220G1X7.377F3600.0
N230G1Y-13.121
N240G1X7.551Y-12.868
N250G1X7.738Y-12.627
N260G1X7.939Y-12.399
N270G1X8.154Y-12.183
N280G1X8.382Y-11.981
N290G1X8.624Y-11.791
N300G1X8.880Y-11.613
N310G1X9.150Y-11.449
N320G1X9.431Y-11.300
N330G1X9.722Y-11.172
N340G1X10.023Y-11.063
N350G1X10.333Y-10.974
N360G1X10.653Y-10.905
N370G1X10.982Y-10.855
N380G1X11.321Y-10.825
N390G1X11.669Y-10.816
N400G1X12.054Y-10.826
N410G1X12.420Y-10.856
N420G1X12.769Y-10.907
N430G1X13.100Y-10.979
N440G1X13.414Y-11.071
N450G1X13.710Y-11.183
N460G1X13.988Y-11.316
N470G1X14.248Y-11.469
N480G1X14.491Y-11.640
N490G1X14.714Y-11.828
N500G1X14.920Y-12.032
N510G1X15.106Y-12.252
N520G1X15.275Y-12.488
N530G1X15.424Y-12.741
N540G1X15.555Y-13.010
N550G1X15.668Y-13.295
N560G1X15.882Y-12.994
N570G1X16.104Y-12.714
N580G1X16.333Y-12.452
N590G1X16.571Y-12.210
N600G1X16.816Y-11.987
N610G1X17.070Y-11.784
N620G1X17.331Y-11.600
N630G1X17.601Y-11.435
N640G1X17.878Y-11.290
N650G1X18.163Y-11.164
N660G1X18.456Y-11.058
N670G1X18.757Y-10.970
N680G1X19.066Y-10.903
N690G1X19.382Y-10.854
N700G1X19.707Y-10.825
N710G1X20.040Y-10.816
N720G1X20.551Y-10.834
N730G1X21.032Y-10.888
N740G1X21.482Y-10.980
N750G1X21.902Y-11.107
N760G1X22.292Y-11.271
N770G1X22.651Y-11.472
N780G1X22.980Y-11.708
N790G1X23.279Y-11.982
N800G1X23.544Y-12.293
N810G1X23.774Y-12.644
N820G1X23.969Y-13.034
N830G1X24.128Y-13.463
N840G1X24.252Y-13.932
N850G1X24.341Y-14.440
N860G1X24.394Y-14.987
N870G1X24.412Y-15.574
N880G1Y-25.291
N890G1X22.026
N900G1Y-16.374
N910G1X22.011Y-15.704
N920G1X21.967Y-15.136
N930G1X21.894Y-14.668
N940G1X21.792Y-14.301
N950G1X21.652Y-14.000
N960G1X21.464Y-13.730
N970G1X21.229Y-13.490
N980G1X20.946Y-13.281
N990G1X20.626Y-13.112
N1000G1X20.280Y-12.991
N1010G1X19.906Y-12.919
N1020G1X19.507Y-12.895
N1030G1X19.141Y-12.910
N1040G1X18.792Y-12.957
N1050G1X18.458Y-13.034
N1060G1X18.140Y-13.143
N1070G1X17.838Y-13.283
N1080G1X17.552Y-13.453
N1090G1X17.282Y-13.655
N1100G1X17.027Y-13.888
N1110G1X16.796Y-14.155
N1120G1X16.596Y-14.459
N1130G1X16.426Y-14.800
N1140G1X16.288Y-15.179
N1150G1X16.180Y-15.595
N1160G1X16.103Y-16.048
N1170G1X16.056Y-16.539
N1180G1X16.041Y-17.067
N1190G1Y-25.291
N1200G1X13.642
N1210G1Y-16.094
N1220G1X13.633Y-15.706
N1230G1X13.605Y-15.344
N1240G1X13.559Y-15.007
N1250G1X13.495Y-14.694
N1260G1X13.413Y-14.407
N1270G1X13.312Y-14.144
N1280G1X13.193Y-13.907
N1290G1X13.055Y-13.695
N1300G1X12.897Y-13.507
N1310G1X12.716Y-13.345
N1320G1X12.511Y-13.207
N1330G1X12.282Y-13.095
N1340G1X12.031Y-13.007
N1350G1X11.756Y-12.945
N1360G1X11.458Y-12.907
N1370G1X11.136Y-12.895
N1380G1X10.885Y-12.903
N1390G1X10.639Y-12.928
N1400G1X10.398Y-12.970
N1410G1X10.161Y-13.028
N1420G1X9.930Y-13.103
N1430G1X9.703Y-13.195
N1440G1X9.481Y-13.303
N1450G1X9.263Y-13.428
N1460G1X9.056Y-13.569
N1470G1X8.863Y-13.725
N1480G1X8.685Y-13.897
N1490G1X8.522Y-14.084
N1500G1X8.374Y-14.287
N1510G1X8.240Y-14.505
N1520G1X8.121Y-14.739
N1530G1X8.017Y-14.987
N1540G1X7.927Y-15.258
N1550G1X7.848Y-15.557
N1560G1X7.782Y-15.885
N1570G1X7.727Y-16.240
N1580G1X7.655Y-17.037
N1590G1X7.631Y-17.946
N1600G1Y-25.291
N1610G1X5.231
N1620G1Y-11.135
N1630G00Z5.999
N1640G00X26.611
N1650G1Z-1.000F1200.0
N1660G1X29.197F3600.0
N1670G1X32.142Y-19.333
N1680G1X32.421Y-20.122
N1690G1X32.685Y-20.932
N1700G1X32.934Y-21.762
N1710G1X33.169Y-22.612
N1720G1X33.385Y-21.790
N1730G1X33.622Y-20.979
N1740G1X33.878Y-20.177
N1750G1X34.155Y-19.386
N1760G1X37.181Y-11.135
N1770G1X39.580
N1780G1X34.195Y-25.531
N1790G1X33.786Y-26.606
N1800G1X33.425Y-27.500
N1810G1X33.113Y-28.212
N1820G1X32.849Y-28.743
N1830G1X32.686Y-29.029
N1840G1X32.517Y-29.296
N1850G1X32.343Y-29.543
N1860G1X32.162Y-29.771
N1870G1X31.976Y-29.978
N1880G1X31.784Y-30.166
N1890G1X31.586Y-30.334
N1900G1X31.382Y-30.482
N1910G1X31.171Y-30.612
N1920G1X30.949Y-30.724
N1930G1X30.718Y-30.819
N1940G1X30.476Y-30.897
N1950G1X30.225Y-30.958
N1960G1X29.963Y-31.001
N1970G1X29.691Y-31.027
N1980G1X29.410Y-31.035
N1990G1X29.053Y-31.017
N2000G1X28.677Y-30.962
N2010G1X28.280Y-30.870
N2020G1X27.864Y-30.742
N2030G1X27.597Y-28.490
N2040G1X27.978Y-28.583
N2050G1X28.334Y-28.649
N2060G1X28.664Y-28.689
N2070G1X28.970Y-28.703
N2080G1X29.350Y-28.686
N2090G1X29.690Y-28.636
N2100G1X29.990Y-28.553
N2110G1X30.250Y-28.436
N2120G1X30.479Y-28.290
N2130G1X30.686Y-28.116
N2140G1X30.872Y-27.916
N2150G1X31.036Y-27.690
N2160G1X31.167Y-27.443
N2170G1X31.333Y-27.063
N2180G1X31.769Y-25.904
N2190G1X31.982Y-25.317
N2200G1X26.611Y-11.135
N2210G00Z5.999
N2220G00X39.673Y-35.327
N2230G1Z-1.000F1200.0
N2240G1X49.390F3600.0
N2250G1Y-37.620
N2260G1X41.592
N2270G1X40.539Y-42.871
N2280G1X40.982Y-42.584
N2290G1X41.430Y-42.335
N2300G1X41.883Y-42.124
N2310G1X42.342Y-41.952
N2320G1X42.806Y-41.817
N2330G1X43.276Y-41.722
N2340G1X43.751Y-41.664
N2350G1X44.231Y-41.645
N2360G1X44.859Y-41.673
N2370G1X45.461Y-41.756
N2380G1X46.038Y-41.894
N2390G1X46.318Y-41.984
N2400G1X46.591Y-42.088
N2410G1X46.857Y-42.206
N2420G1X47.118Y-42.337
N2430G1X47.372Y-42.483
N2440G1X47.620Y-42.642
N2450G1X48.098Y-43.002
N2460G1X48.550Y-43.418
N2470G1X48.763Y-43.643
N2480G1X48.962Y-43.877
N2490G1X49.148Y-44.118
N2500G1X49.320Y-44.367
N2510G1X49.478Y-44.625
N2520G1X49.622Y-44.890
N2530G1X49.753Y-45.163
N2540G1X49.870Y-45.444
N2550G1X49.973Y-45.733
N2560G1X50.062Y-46.029
N2570G1X50.138Y-46.334
N2580G1X50.199Y-46.647
N2590G1X50.282Y-47.296
N2600G1X50.309Y-47.976
N2610G1X50.285Y-48.628
N2620G1X50.213Y-49.257
N2630G1X50.092Y-49.864
N2640G1X49.923Y-50.449
N2650G1X49.705Y-51.011
N2660G1X49.440Y-51.550
N2670G1X49.126Y-52.067
N2680G1X48.763Y-52.561
N2690G1X48.523Y-52.849
N2700G1X48.272Y-53.117
N2710G1X48.010Y-53.368
N2720G1X47.738Y-53.599
N2730G1X47.455Y-53.812
N2740G1X47.161Y-54.007
N2750G1X46.856Y-54.183
N2760G1X46.541Y-54.341
N2770G1X46.215Y-54.480
N2780G1X45.878Y-54.600
N2790G1X45.530Y-54.702
N2800G1X45.172Y-54.786
N2810G1X44.803Y-54.850
N2820G1X44.423Y-54.897
N2830G1X44.033Y-54.925
N2840G1X43.632Y-54.934
N2850G1X42.981Y-54.910
N2860G1X42.360Y-54.841
N2870G1X41.770Y-54.724
N2880G1X41.211Y-54.561
N2890G1X40.682Y-54.351
N2900G1X40.184Y-54.094
N2910G1X39.717Y-53.791
N2920G1X39.280Y-53.441
N2930G1X38.881Y-53.053
N2940G1X38.527Y-52.634
N2950G1X38.219Y-52.185
N2960G1X37.955Y-51.705
N2970G1X37.737Y-51.195
N2980G1X37.564Y-50.654
N2990G1X37.436Y-50.084
N3000G1X37.354Y-49.482
N3010G1X39.873Y-49.269
N3020G1X39.954Y-49.715
N3030G1X40.059Y-50.132
N3040G1X40.187Y-50.520
N3050G1X40.338Y-50.880
N3060G1X40.512Y-51.212
N3070G1X40.709Y-51.515
N3080G1X40.929Y-51.789
N3090G1X41.172Y-52.035
N3100G1X41.434Y-52.252
N3110G1X41.709Y-52.440
N3120G1X41.996Y-52.599
N3130G1X42.297Y-52.730
N3140G1X42.611Y-52.831
N3150G1X42.938Y-52.903
N3160G1X43.278Y-52.947
N3170G1X43.632Y-52.961
N3180G1X44.056Y-52.941
N3190G1X44.465Y-52.880
N3200G1X44.856Y-52.777
N3210G1X45.231Y-52.635
N3220G1X45.589Y-52.451
N3230G1X45.931Y-52.226
N3240G1X46.256Y-51.961
N3250G1X46.564Y-51.655
N3260G1X46.845Y-51.315
N3270G1X47.089Y-50.949
N3280G1X47.295Y-50.555
N3290G1X47.464Y-50.135
N3300G1X47.595Y-49.689
N3310G1X47.689Y-49.216
N3320G1X47.745Y-48.716
N3330G1X47.764Y-48.189
N3340G1X47.746Y-47.690
N3350G1X47.692Y-47.217
N3360G1X47.601Y-46.772
N3370G1X47.475Y-46.353
N3380G1X47.313Y-45.962
N3390G1X47.115Y-45.598
N3400G1X46.881Y-45.261
N3410G1X46.611Y-44.951
N3420G1X46.311Y-44.673
N3430G1X45.990Y-44.432
N3440G1X45.646Y-44.228
N3450G1X45.279Y-44.061
N3460G1X44.891Y-43.931
N3470G1X44.480Y-43.838
N3480G1X44.047Y-43.783
N3490G1X43.592Y-43.764
N3500G1X43.305Y-43.773
N3510G1X43.026Y-43.797
N3520G1X42.754Y-43.838
N3530G1X42.489Y-43.896
N3540G1X42.231Y-43.970
N3550G1X41.980Y-44.060
N3560G1X41.736Y-44.167
N3570G1X41.499Y-44.291
N3580G1X41.058Y-44.574
N3590G1X40.856Y-44.730
N3600G1X40.666Y-44.896
N3610G1X40.489Y-45.071
N3620G1X40.324Y-45.257
N3630G1X40.172Y-45.452
N3640G1X40.033Y-45.657
N3650G1X37.780Y-45.364
N3660G1X39.673Y-35.327
N3670G00Z5.999
N3680G00X34.114Y-37.815
N3690G1Z-1.000F1200.0
N3700G1X34.345Y-38.286F3600.0
N3710G1X34.524Y-38.781
N3720G1X34.652Y-39.299
N3730G1X34.729Y-39.841
N3740G1X34.755Y-40.405
N3750G1X34.747Y-40.698
N3760G1X34.725Y-40.989
N3770G1X34.635Y-41.568
N3780G1X34.485Y-42.142
N3790G1X34.275Y-42.711
N3800G1X34.145Y-42.996
N3810G1X33.995Y-43.285
N3820G1X33.637Y-43.874
N3830G1X33.199Y-44.478
N3840G1X32.682Y-45.097
N3850G1X32.034Y-45.782
N3860G1X31.201Y-46.583
N3870G1X30.184Y-47.501
N3880G1X28.983Y-48.536
N3890G1X28.000Y-49.369
N3900G1X27.211Y-50.057
N3910G1X26.614Y-50.599
N3920G1X26.211Y-50.995
N3930G1X25.918Y-51.319
N3940G1X25.651Y-51.643
N3950G1X25.411Y-51.969
N3960G1X25.198Y-52.295
N3970G1X34.781
N3980G1Y-54.601
N3990G1X21.866
N4000G1X21.873Y-54.172
N4010G1X21.922Y-53.751
N4020G1X22.013Y-53.339
N4030G1X22.146Y-52.934
N4040G1X22.278Y-52.605
N4050G1X22.429Y-52.277
N4060G1X22.599Y-51.950
N4070G1X22.787Y-51.625
N4080G1X22.994Y-51.301
N4090G1X23.219Y-50.978
N4100G1X23.463Y-50.656
N4110G1X23.725Y-50.335
N4120G1X24.329Y-49.671
N4130G1X25.053Y-48.956
N4140G1X25.898Y-48.191
N4150G1X26.864Y-47.376
N4160G1X27.628Y-46.740
N4170G1X28.328Y-46.138
N4180G1X28.963Y-45.570
N4190G1X29.533Y-45.036
N4200G1X30.039Y-44.535
N4210G1X30.480Y-44.069
N4220G1X30.857Y-43.636
N4230G1X31.169Y-43.238
N4240G1X31.432Y-42.859
N4250G1X31.659Y-42.485
N4260G1X31.851Y-42.117
N4270G1X32.009Y-41.753
N4280G1X32.131Y-41.395
N4290G1X32.219Y-41.042
N4300G1X32.271Y-40.695
N4310G1X32.289Y-40.352
N4320G1X32.273Y-40.003
N4330G1X32.225Y-39.667
N4340G1X32.145Y-39.345
N4350G1X32.034Y-39.038
N4360G1X31.891Y-38.744
N4370G1X31.715Y-38.464
N4380G1X31.508Y-38.198
N4390G1X31.269Y-37.946
N4400G1X31.005Y-37.717
N4410G1X30.721Y-37.518
N4420G1X30.417Y-37.349
N4430G1X30.095Y-37.212
N4440G1X29.753Y-37.104
N4450G1X29.391Y-37.028
N4460G1X29.010Y-36.982
N4470G1X28.610Y-36.967
N4480G1X28.188Y-36.983
N4490G1X27.787Y-37.032
N4500G1X27.408Y-37.113
N4510G1X27.051Y-37.227
N4520G1X26.715Y-37.373
N4530G1X26.401Y-37.551
N4540G1X26.108Y-37.763
N4550G1X25.838Y-38.006
N4560G1X25.594Y-38.279
N4570G1X25.382Y-38.576
N4580G1X25.202Y-38.898
N4590G1X25.055Y-39.246
N4600G1X24.939Y-39.618
N4610G1X24.856Y-40.016
N4620G1X24.804Y-40.438
N4630G1X24.785Y-40.885
N4640G1X22.319Y-40.632
N4650G1X22.404Y-39.963
N4660G1X22.533Y-39.335
N4670G1X22.706Y-38.747
N4680G1X22.922Y-38.201
N4690G1X23.182Y-37.696
N4700G1X23.486Y-37.232
N4710G1X23.834Y-36.809
N4720G1X24.225Y-36.427
N4730G1X24.656Y-36.088
N4740G1X25.122Y-35.794
N4750G1X25.624Y-35.546
N4760G1X26.161Y-35.342
N4770G1X26.733Y-35.184
N4780G1X27.341Y-35.071
N4790G1X27.985Y-35.003
N4800G1X28.663Y-34.981
N4810G1X29.348Y-35.005
N4820G1X29.996Y-35.078
N4830G1X30.608Y-35.200
N4840G1X31.183Y-35.370
N4850G1X31.721Y-35.590
N4860G1X31.976Y-35.718
N4870G1X32.222Y-35.858
N4880G1X32.459Y-36.010
N4890G1X32.687Y-36.175
N4900G1X32.906Y-36.351
N4910G1X33.115Y-36.540
N4920G1X33.499Y-36.942
N4930G1X33.832Y-37.366
N4940G1X34.114Y-37.815
N4950G00Z5.999
N4960G00X53.202Y-40.445
N4970G1Z-1.000F1200.0
N4980G1X55.348F3600.0
N4990G1Y-42.431
N5000G1X55.521Y-42.178
N5010G1X55.708Y-41.937
N5020G1X55.909Y-41.709
N5030G1X56.124Y-41.493
N5040G1X56.353Y-41.291
N5050G1X56.595Y-41.101
N5060G1X56.851Y-40.923
N5070G1X57.120Y-40.759
N5080G1X57.402Y-40.610
N5090G1X57.693Y-40.482
N5100G1X57.993Y-40.373
N5110G1X58.303Y-40.284
N5120G1X58.623Y-40.215
N5130G1X58.952Y-40.165
N5140G1X59.291Y-40.135
N5150G1X59.640Y-40.126
N5160G1X60.024Y-40.136
N5170G1X60.391Y-40.166
N5180G1X60.739Y-40.217
N5190G1X61.071Y-40.289
N5200G1X61.384Y-40.381
N5210G1X61.680Y-40.493
N5220G1X61.958Y-40.626
N5230G1X62.219Y-40.779
N5240G1X62.461Y-40.950
N5250G1X62.685Y-41.138
N5260G1X62.890Y-41.342
N5270G1X63.077Y-41.562
N5280G1X63.245Y-41.798
N5290G1X63.394Y-42.051
N5300G1X63.526Y-42.320
N5310G1X63.638Y-42.605
N5320G1X63.852Y-42.304
N5330G1X64.074Y-42.024
N5340G1X64.304Y-41.762
N5350G1X64.541Y-41.520
N5360G1X64.787Y-41.297
N5370G1X65.040Y-41.094
N5380G1X65.302Y-40.910
N5390G1X65.571Y-40.745
N5400G1X65.848Y-40.600
N5410G1X66.133Y-40.474
N5420G1X66.426Y-40.368
N5430G1X66.727Y-40.280
N5440G1X67.036Y-40.213
N5450G1X67.353Y-40.164
N5460G1X67.677Y-40.135
N5470G1X68.010Y-40.126
N5480G1X68.521Y-40.144
N5490G1X69.002Y-40.198
N5500G1X69.453Y-40.290
N5510G1X69.873Y-40.417
N5520G1X70.262Y-40.581
N5530G1X70.622Y-40.782
N5540G1X70.950Y-41.018
N5550G1X71.249Y-41.292
N5560G1X71.514Y-41.603
N5570G1X71.745Y-41.954
N5580G1X71.939Y-42.344
N5590G1X72.099Y-42.773
N5600G1X72.223Y-43.242
N5610G1X72.311Y-43.750
N5620G1X72.364Y-44.297
N5630G1X72.382Y-44.884
N5640G1Y-54.601
N5650G1X69.996
N5660G1Y-45.684
N5670G1X69.981Y-45.014
N5680G1X69.938Y-44.446
N5690G1X69.865Y-43.978
N5700G1X69.763Y-43.611
N5710G1X69.622Y-43.310
N5720G1X69.435Y-43.040
N5730G1X69.199Y-42.800
N5740G1X68.916Y-42.591
N5750G1X68.596Y-42.422
N5760G1X68.250Y-42.301
N5770G1X67.877Y-42.229
N5780G1X67.477Y-42.205
N5790G1X67.112Y-42.220
N5800G1X66.762Y-42.267
N5810G1X66.428Y-42.344
N5820G1X66.111Y-42.453
N5830G1X65.809Y-42.593
N5840G1X65.523Y-42.763
N5850G1X65.252Y-42.965
N5860G1X64.998Y-43.198
N5870G1X64.767Y-43.465
N5880G1X64.566Y-43.769
N5890G1X64.397Y-44.110
N5900G1X64.258Y-44.489
N5910G1X64.150Y-44.905
N5920G1X64.073Y-45.358
N5930G1X64.027Y-45.849
N5940G1X64.011Y-46.377
N5950G1Y-54.601
N5960G1X61.612
N5970G1Y-45.404
N5980G1X61.603Y-45.016
N5990G1X61.576Y-44.654
N6000G1X61.530Y-44.317
N6010G1X61.466Y-44.004
N6020G1X61.383Y-43.717
N6030G1X61.282Y-43.454
N6040G1X61.163Y-43.217
N6050G1X61.026Y-43.005
N6060G1X60.867Y-42.817
N6070G1X60.686Y-42.655
N6080G1X60.481Y-42.517
N6090G1X60.253Y-42.405
N6100G1X60.001Y-42.317
N6110G1X59.726Y-42.255
N6120G1X59.428Y-42.217
N6130G1X59.106Y-42.205
N6140G1X58.856Y-42.213
N6150G1X58.609Y-42.238
N6160G1X58.368Y-42.280
N6170G1X58.132Y-42.338
N6180G1X57.900Y-42.413
N6190G1X57.673Y-42.505
N6200G1X57.451Y-42.613
N6210G1X57.234Y-42.738
N6220G1X57.026Y-42.879
N6230G1X56.833Y-43.035
N6240G1X56.655Y-43.207
N6250G1X56.492Y-43.394
N6260G1X56.344Y-43.597
N6270G1X56.210Y-43.815
N6280G1X56.091Y-44.049
N6290G1X55.987Y-44.297
N6300G1X55.897Y-44.568
N6310G1X55.818Y-44.867
N6320G1X55.752Y-45.195
N6330G1X55.698Y-45.550
N6340G1X55.625Y-46.347
N6350G1X55.601Y-47.256
N6360G1Y-54.601
N6370G1X53.202
N6380G1Y-40.445
N6390G00Z5.999
N6400G00X75.941
N6410G1Z-1.000F1200.0
N6420G1X78.087F3600.0
N6430G1Y-42.431
N6440G1X78.260Y-42.178
N6450G1X78.447Y-41.937
N6460G1X78.648Y-41.709
N6470G1X78.863Y-41.493
N6480G1X79.091Y-41.291
N6490G1X79.334Y-41.101
N6500G1X79.590Y-40.923
N6510G1X79.859Y-40.759
N6520G1X80.141Y-40.610
N6530G1X80.432Y-40.482
N6540G1X80.732Y-40.373
N6550G1X81.042Y-40.284
N6560G1X81.362Y-40.215
N6570G1X81.691Y-40.165
N6580G1X82.030Y-40.135
N6590G1X82.378Y-40.126
N6600G1X82.763Y-40.136
N6610G1X83.129Y-40.166
N6620G1X83.478Y-40.217
N6630G1X83.810Y-40.289
N6640G1X84.123Y-40.381
N6650G1X84.419Y-40.493
N6660G1X84.697Y-40.626
N6670G1X84.958Y-40.779
N6680G1X85.200Y-40.950
N6690G1X85.424Y-41.138
N6700G1X85.629Y-41.342
N6710G1X85.816Y-41.562
N6720G1X85.984Y-41.798
N6730G1X86.133Y-42.051
N6740G1X86.264Y-42.320
N6750G1X86.377Y-42.605
N6760G1X86.591Y-42.304
N6770G1X86.813Y-42.024
N6780G1X87.042Y-41.762
N6790G1X87.280Y-41.520
N6800G1X87.526Y-41.297
N6810G1X87.779Y-41.094
N6820G1X88.040Y-40.910
N6830G1X88.310Y-40.745
N6840G1X88.587Y-40.600
N6850G1X88.872Y-40.474
N6860G1X89.165Y-40.368
N6870G1X89.466Y-40.280
N6880G1X89.775Y-40.213
N6890G1X90.092Y-40.164
N6900G1X90.416Y-40.135
N6910G1X90.749Y-40.126
N6920G1X91.260Y-40.144
N6930G1X91.741Y-40.198
N6940G1X92.192Y-40.290
N6950G1X92.612Y-40.417
N6960G1X93.001Y-40.581
N6970G1X93.361Y-40.782
N6980G1X93.689Y-41.018
N6990G1X93.988Y-41.292
N7000G1X94.253Y-41.603
N7010G1X94.483Y-41.954
N7020G1X94.678Y-42.344
N7030G1X94.838Y-42.773
N7040G1X94.961Y-43.242
N7050G1X95.050Y-43.750
N7060G1X95.103Y-44.297
N7070G1X95.121Y-44.884
N7080G1Y-54.601
N7090G1X92.735
N7100G1Y-45.684
N7110G1X92.720Y-45.014
N7120G1X92.677Y-44.446
N7130G1X92.604Y-43.978
N7140G1X92.502Y-43.611
N7150G1X92.361Y-43.310
N7160G1X92.173Y-43.040
N7170G1X91.938Y-42.800
N7180G1X91.655Y-42.591
N7190G1X91.335Y-42.422
N7200G1X90.989Y-42.301
N7210G1X90.616Y-42.229
N7220G1X90.216Y-42.205
N7230G1X89.850Y-42.220
N7240G1X89.501Y-42.267
N7250G1X89.167Y-42.344
N7260G1X88.850Y-42.453
N7270G1X88.548Y-42.593
N7280G1X88.261Y-42.763
N7290G1X87.991Y-42.965
N7300G1X87.737Y-43.198
N7310G1X87.505Y-43.465
N7320G1X87.305Y-43.769
N7330G1X87.136Y-44.110
N7340G1X86.997Y-44.489
N7350G1X86.889Y-44.905
N7360G1X86.812Y-45.358
N7370G1X86.766Y-45.849
N7380G1X86.750Y-46.377
N7390G1Y-54.601
N7400G1X84.351
N7410G1Y-45.404
N7420G1X84.342Y-45.016
N7430G1X84.314Y-44.654
N7440G1X84.269Y-44.317
N7450G1X84.204Y-44.004
N7460G1X84.122Y-43.717
N7470G1X84.021Y-43.454
N7480G1X83.902Y-43.217
N7490G1X83.765Y-43.005
N7500G1X83.606Y-42.817
N7510G1X83.425Y-42.655
N7520G1X83.220Y-42.517
N7530G1X82.992Y-42.405
N7540G1X82.740Y-42.317
N7550G1X82.465Y-42.255
N7560G1X82.167Y-42.217
N7570G1X81.845Y-42.205
N7580G1X81.594Y-42.213
N7590G1X81.348Y-42.238
N7600G1X81.107Y-42.280
N7610G1X80.871Y-42.338
N7620G1X80.639Y-42.413
N7630G1X80.412Y-42.505
N7640G1X80.190Y-42.613
N7650G1X79.973Y-42.738
N7660G1X79.765Y-42.879
N7670G1X79.572Y-43.035
N7680G1X79.394Y-43.207
N7690G1X79.231Y-43.394
N7700G1X79.083Y-43.597
N7710G1X78.949Y-43.815
N7720G1X78.830Y-44.049
N7730G1X78.726Y-44.297
N7740G1X78.636Y-44.568
N7750G1X78.557Y-44.867
N7760G1X78.491Y-45.195
N7770G1X78.436Y-45.550
N7780G1X78.364Y-46.347
N7790G1X78.340Y-47.256
N7800G1Y-54.601
N7810G1X75.941
N7820G1Y-40.445
N7830G00Z5.999
N7840G00X73.538Y-76.435
N7850G1Z-1.000F1200.0
N7860G1X73.191Y-76.615F3600.0
N7870G1X72.803Y-76.789
N7880G1X72.375Y-76.955
N7890G1X71.905Y-77.115
N7900G1X71.395Y-77.267
N7910G1X70.844Y-77.413
N7920G1X70.252Y-77.552
N7930G1X69.620Y-77.684
N7940G1X68.934Y-77.836
N7950G1X68.357Y-77.996
N7960G1X67.888Y-78.166
N7970G1X67.527Y-78.345
N7980G1X67.238Y-78.550
N7990G1X66.984Y-78.797
N8000G1X66.765Y-79.087
N8010G1X66.581Y-79.420
N8020G1X66.435Y-79.783
N8030G1X66.331Y-80.166
N8040G1X66.268Y-80.568
N8050G1X66.247Y-80.990
N8060G1X66.259Y-81.313
N8070G1X66.293Y-81.623
N8080G1X66.349Y-81.919
N8090G1X66.429Y-82.202
N8100G1X66.531Y-82.470
N8110G1X66.656Y-82.725
N8120G1X66.803Y-82.966
N8130G1X66.974Y-83.194
N8140G1X67.166Y-83.400
N8150G1X67.379Y-83.579
N8160G1X67.613Y-83.731
N8170G1X67.868Y-83.855
N8180G1X68.145Y-83.951
N8190G1X68.442Y-84.020
N8200G1X68.760Y-84.061
N8210G1X69.100Y-84.075
N8220G1X69.441Y-84.062
N8230G1X69.774Y-84.023
N8240G1X70.096Y-83.958
N8250G1X70.409Y-83.866
N8260G1X70.713Y-83.749
N8270G1X71.007Y-83.605
N8280G1X71.291Y-83.435
N8290G1X71.566Y-83.239
N8300G1X71.826Y-83.021
N8310G1X72.070Y-82.783
N8320G1X72.295Y-82.526
N8330G1X72.502Y-82.250
N8340G1X72.691Y-81.955
N8350G1X72.863Y-81.640
N8360G1X73.016Y-81.306
N8370G1X73.152Y-80.953
N8380G1X73.242Y-80.656
N8390G1X73.321Y-80.326
N8400G1X73.387Y-79.963
N8410G1X73.442Y-79.566
N8420G1X73.514Y-78.673
N8430G1X73.538Y-77.647
N8440G1Y-76.435
N8450G00Z5.999
N8460G00X72.756Y-74.165
N8470G1Z-1.000F1200.0
N8480G1X73.171Y-74.008F3600.0
N8490G1X73.538Y-73.846
N8500G1X73.552Y-72.983
N8510G1X73.541Y-72.496
N8520G1X73.509Y-72.047
N8530G1X73.456Y-71.635
N8540G1X73.382Y-71.261
N8550G1X73.286Y-70.924
N8560G1X73.169Y-70.624
N8570G1X73.031Y-70.361
N8580G1X72.872Y-70.136
N8590G1X72.628Y-69.873
N8600G1X72.356Y-69.646
N8610G1X72.056Y-69.453
N8620G1X71.729Y-69.296
N8630G1X71.373Y-69.173
N8640G1X70.990Y-69.086
N8650G1X70.579Y-69.033
N8660G1X70.139Y-69.016
N8670G1X69.730Y-69.028
N8680G1X69.348Y-69.067
N8690G1X68.994Y-69.131
N8700G1X68.668Y-69.220
N8710G1X68.370Y-69.335
N8720G1X68.099Y-69.475
N8730G1X67.856Y-69.641
N8740G1X67.640Y-69.833
N8750G1X67.445Y-70.057
N8760G1X67.263Y-70.320
N8770G1X67.094Y-70.623
N8780G1X66.939Y-70.965
N8790G1X66.796Y-71.346
N8800G1X66.667Y-71.766
N8810G1X66.550Y-72.226
N8820G1X66.447Y-72.725
N8830G1X64.101Y-72.285
N8840G1X64.188Y-71.778
N8850G1X64.287Y-71.297
N8860G1X64.399Y-70.841
N8870G1X64.525Y-70.409
N8880G1X64.663Y-70.003
N8890G1X64.814Y-69.621
N8900G1X64.978Y-69.265
N8910G1X65.154Y-68.933
N8920G1X65.348Y-68.623
N8930G1X65.562Y-68.332
N8940G1X65.796Y-68.058
N8950G1X66.051Y-67.804
N8960G1X66.326Y-67.567
N8970G1X66.621Y-67.349
N8980G1X66.937Y-67.149
N8990G1X67.274Y-66.968
N9000G1X67.627Y-66.807
N9010G1X67.994Y-66.667
N9020G1X68.375Y-66.548
N9030G1X68.770Y-66.451
N9040G1X69.178Y-66.376
N9050G1X69.600Y-66.322
N9060G1X70.036Y-66.290
N9070G1X70.486Y-66.279
N9080G1X70.928Y-66.288
N9090G1X71.350Y-66.316
N9100G1X71.750Y-66.362
N9110G1X72.129Y-66.426
N9120G1X72.486Y-66.509
N9130G1X72.823Y-66.610
N9140G1X73.138Y-66.729
N9150G1X73.432Y-66.867
N9160G1X73.705Y-67.019
N9170G1X73.961Y-67.180
N9180G1X74.197Y-67.350
N9190G1X74.415Y-67.530
N9200G1X74.613Y-67.720
N9210G1X74.794Y-67.919
N9220G1X74.955Y-68.127
N9230G1X75.098Y-68.345
N9240G1X75.226Y-68.575
N9250G1X75.344Y-68.820
N9260G1X75.551Y-69.353
N9270G1X75.717Y-69.945
N9280G1X75.844Y-70.595
N9290G1X75.897Y-71.102
N9300G1X75.934Y-71.780
N9310G1X75.957Y-72.627
N9320G1X75.964Y-73.644
N9330G1Y-78.051
N9340G1X75.974Y-80.144
N9350G1X76.002Y-81.814
N9360G1X76.050Y-83.060
N9370G1X76.117Y-83.882
N9380G1X76.213Y-84.487
N9390G1X76.346Y-85.078
N9400G1X76.516Y-85.657
N9410G1X76.724Y-86.224
N9420G1X74.218
N9430G1X74.048Y-85.688
N9440G1X73.911Y-85.108
N9450G1X73.808Y-84.485
N9460G1X73.738Y-83.818
N9470G1X73.406Y-84.194
N9480G1X73.078Y-84.541
N9490G1X72.753Y-84.860
N9500G1X72.430Y-85.149
N9510G1X72.111Y-85.411
N9520G1X71.795Y-85.643
N9530G1X71.482Y-85.847
N9540G1X71.172Y-86.022
N9550G1X70.861Y-86.172
N9560G1X70.545Y-86.303
N9570G1X70.222Y-86.413
N9580G1X69.894Y-86.504
N9590G1X69.561Y-86.574
N9600G1X69.222Y-86.624
N9610G1X68.877Y-86.654
N9620G1X68.527Y-86.665
N9630G1X67.960Y-86.640
N9640G1X67.428Y-86.566
N9650G1X66.929Y-86.444
N9660G1X66.464Y-86.272
N9670G1X66.033Y-86.051
N9680G1X65.635Y-85.781
N9690G1X65.271Y-85.462
N9700G1X64.941Y-85.094
N9710G1X64.647Y-84.688
N9720G1X64.393Y-84.255
N9730G1X64.178Y-83.794
N9740G1X64.001Y-83.306
N9750G1X63.864Y-82.791
N9760G1X63.767Y-82.248
N9770G1X63.708Y-81.679
N9780G1X63.688Y-81.082
N9790G1X63.696Y-80.727
N9800G1X63.718Y-80.381
N9810G1X63.755Y-80.042
N9820G1X63.806Y-79.711
N9830G1X63.873Y-79.388
N9840G1X63.954Y-79.072
N9850G1X64.050Y-78.765
N9860G1X64.161Y-78.465
N9870G1X64.416Y-77.902
N9880G1X64.557Y-77.642
N9890G1X64.708Y-77.397
N9900G1X64.867Y-77.167
N9910G1X65.036Y-76.951
N9920G1X65.214Y-76.750
N9930G1X65.401Y-76.564
N9940G1X65.796Y-76.227
N9950G1X66.216Y-75.935
N9960G1X66.659Y-75.686
N9970G1X67.127Y-75.480
N9980G1X67.525Y-75.353
N9990G1X68.013Y-75.228
N10000G1X68.592Y-75.105
N10010G1X69.260Y-74.984
N10020G1X70.617Y-74.734
N10030G1X71.223Y-74.600
N10040G1X71.782Y-74.461
N10050G1X72.293Y-74.316
N10060G1X72.756Y-74.165
N10070G00Z5.999
N10080G00X82.106Y-74.851
N10090G1Z-1.000F1200.0
N10100G1X82.082Y-76.105F3600.0
N10110G1Y-86.224
N10120G1X79.683
N10130G1Y-66.720
N10140G1X81.829
N10150G1Y-69.456
N10160G1X82.002Y-69.107
N10170G1X82.189Y-68.775
N10180G1X82.390Y-68.461
N10190G1X82.605Y-68.164
N10200G1X82.834Y-67.885
N10210G1X83.076Y-67.623
N10220G1X83.332Y-67.378
N10230G1X83.601Y-67.152
N10240G1X83.883Y-66.947
N10250G1X84.174Y-66.770
N10260G1X84.474Y-66.620
N10270G1X84.784Y-66.497
N10280G1X85.104Y-66.402
N10290G1X85.433Y-66.334
N10300G1X85.772Y-66.293
N10310G1X86.121Y-66.279
N10320G1X86.505Y-66.293
N10330G1X86.872Y-66.336
N10340G1X87.220Y-66.406
N10350G1X87.552Y-66.504
N10360G1X87.865Y-66.631
N10370G1X88.161Y-66.786
N10380G1X88.439Y-66.968
N10390G1X88.700Y-67.179
N10400G1X88.942Y-67.415
N10410G1X89.166Y-67.674
N10420G1X89.371Y-67.955
N10430G1X89.558Y-68.258
N10440G1X89.726Y-68.584
N10450G1X89.876Y-68.932
N10460G1X90.007Y-69.302
N10470G1X90.119Y-69.695
N10480G1X90.333Y-69.282
N10490G1X90.555Y-68.895
N10500G1X90.785Y-68.534
N10510G1X91.022Y-68.201
N10520G1X91.268Y-67.894
N10530G1X91.521Y-67.614
N10540G1X91.783Y-67.360
N10550G1X92.052Y-67.133
N10560G1X92.329Y-66.933
N10570G1X92.614Y-66.760
N10580G1X92.907Y-66.613
N10590G1X93.208Y-66.493
N10600G1X93.517Y-66.399
N10610G1X93.834Y-66.333
N10620G1X94.158Y-66.293
N10630G1X94.491Y-66.279
N10640G1X95.002Y-66.304
N10650G1X95.483Y-66.380
N10660G1X95.934Y-66.505
N10670G1X96.354Y-66.681
N10680G1X96.743Y-66.907
N10690G1X97.103Y-67.183
N10700G1X97.431Y-67.510
N10710G1X97.730Y-67.886
N10720G1X97.995Y-68.315
N10730G1X98.226Y-68.798
N10740G1X98.420Y-69.336
N10750G1X98.580Y-69.927
N10760G1X98.704Y-70.573
N10770G1X98.792Y-71.273
N10780G1X98.845Y-72.027
N10790G1X98.863Y-72.836
N10800G1Y-86.224
N10810G1X96.477
N10820G1Y-73.938
N10830G1X96.462Y-73.015
N10840G1X96.419Y-72.232
N10850G1X96.346Y-71.587
N10860G1X96.244Y-71.082
N10870G1X96.103Y-70.667
N10880G1X96.015Y-70.475
N10890G1X95.916Y-70.294
N10900G1X95.804Y-70.124
N10910G1X95.680Y-69.964
N10920G1X95.545Y-69.815
N10930G1X95.397Y-69.677
N10940G1X95.241Y-69.552
N10950G1X95.077Y-69.444
N10960G1X94.908Y-69.352
N10970G1X94.731Y-69.277
N10980G1X94.548Y-69.219
N10990G1X94.358Y-69.178
N11000G1X94.161Y-69.153
N11010G1X93.958Y-69.144
N11020G1X93.593Y-69.166
N11030G1X93.243Y-69.230
N11040G1X92.909Y-69.337
N11050G1X92.592Y-69.486
N11060G1X92.290Y-69.679
N11070G1X92.004Y-69.914
N11080G1X91.733Y-70.192
N11090G1X91.479Y-70.512
N11100G1X91.248Y-70.880
N11110G1X91.047Y-71.299
N11120G1X90.878Y-71.770
N11130G1X90.739Y-72.292
N11140G1X90.631Y-72.865
N11150G1X90.554Y-73.489
N11160G1X90.508Y-74.165
N11170G1X90.492Y-74.893
N11180G1Y-86.224
N11190G1X88.093
N11200G1Y-73.552
N11210G1X88.084Y-73.018
N11220G1X88.057Y-72.519
N11230G1X88.011Y-72.054
N11240G1X87.947Y-71.624
N11250G1X87.864Y-71.228
N11260G1X87.763Y-70.866
N11270G1X87.644Y-70.539
N11280G1X87.507Y-70.246
N11290G1X87.348Y-69.988
N11300G1X87.167Y-69.764
N11310G1X86.962Y-69.575
N11320G1X86.734Y-69.420
N11330G1X86.482Y-69.299
N11340G1X86.207Y-69.213
N11350G1X85.909Y-69.161
N11360G1X85.587Y-69.144
N11370G1X85.337Y-69.156
N11380G1X85.090Y-69.190
N11390G1X84.849Y-69.248
N11400G1X84.613Y-69.328
N11410G1X84.381Y-69.431
N11420G1X84.154Y-69.557
N11430G1X83.932Y-69.707
N11440G1X83.715Y-69.879
N11450G1X83.507Y-70.073
N11460G1X83.314Y-70.289
N11470G1X83.136Y-70.525
N11480G1X82.973Y-70.783
N11490G1X82.825Y-71.063
N11500G1X82.691Y-71.363
N11510G1X82.572Y-71.685
N11520G1X82.468Y-72.028
N11530G1X82.378Y-72.401
N11540G1X82.299Y-72.813
N11550G1X82.233Y-73.264
N11560G1X82.179Y-73.754
N11570G1X82.106Y-74.851
N11580G00Z5.999
N11590G00X60.823Y-74.231
N11600G1Z-1.000F1200.0
N11610G1Y-86.224F3600.0
N11620G1X58.423
N11630G1Y-74.360
N11640G1X58.406Y-73.414
N11650G1X58.353Y-72.595
N11660G1X58.266Y-71.903
N11670G1X58.209Y-71.605
N11680G1X58.143Y-71.339
N11690G1X58.067Y-71.095
N11700G1X57.976Y-70.864
N11710G1X57.873Y-70.645
N11720G1X57.755Y-70.439
N11730G1X57.624Y-70.246
N11740G1X57.480Y-70.065
N11750G1X57.322Y-69.897
N11760G1X57.150Y-69.741
N11770G1X56.968Y-69.601
N11780G1X56.778Y-69.480
N11790G1X56.581Y-69.377
N11800G1X56.376Y-69.293
N11810G1X56.163Y-69.228
N11820G1X55.942Y-69.182
N11830G1X55.714Y-69.154
N11840G1X55.478Y-69.144
N11850G1X55.101Y-69.165
N11860G1X54.738Y-69.228
N11870G1X54.387Y-69.333
N11880G1X54.050Y-69.479
N11890G1X53.726Y-69.668
N11900G1X53.415Y-69.898
N11910G1X53.117Y-70.171
N11920G1X52.832Y-70.485
N11930G1X52.697Y-70.662
N11940G1X52.571Y-70.858
N11950G1X52.454Y-71.072
N11960G1X52.345Y-71.306
N11970G1X52.154Y-71.829
N11980G1X51.997Y-72.427
N11990G1X51.875Y-73.101
N12000G1X51.789Y-73.849
N12010G1X51.736Y-74.673
N12020G1X51.719Y-75.572
N12030G1Y-86.224
N12040G1X49.320
N12050G1Y-66.720
N12060G1X51.479
N12070G1Y-69.493
N12080G1X51.679Y-69.104
N12090G1X51.891Y-68.740
N12100G1X52.113Y-68.401
N12110G1X52.345Y-68.087
N12120G1X52.589Y-67.798
N12130G1X52.844Y-67.535
N12140G1X53.109Y-67.296
N12150G1X53.385Y-67.083
N12160G1X53.672Y-66.894
N12170G1X53.970Y-66.731
N12180G1X54.278Y-66.593
N12190G1X54.598Y-66.480
N12200G1X54.928Y-66.392
N12210G1X55.269Y-66.330
N12220G1X55.621Y-66.292
N12230G1X55.984Y-66.279
N12240G1X56.301Y-66.289
N12250G1X56.611Y-66.319
N12260G1X56.915Y-66.368
N12270G1X57.212Y-66.438
N12280G1X57.503Y-66.527
N12290G1X57.787Y-66.636
N12300G1X58.065Y-66.764
N12310G1X58.337Y-66.913
N12320G1X58.597Y-67.077
N12330G1X58.839Y-67.254
N12340G1X59.066Y-67.444
N12350G1X59.275Y-67.645
N12360G1X59.467Y-67.859
N12370G1X59.642Y-68.085
N12380G1X59.801Y-68.324
N12390G1X59.943Y-68.575
N12400G1X60.189Y-69.113
N12410G1X60.396Y-69.700
N12420G1X60.563Y-70.335
N12430G1X60.689Y-71.018
N12440G1X60.748Y-71.563
N12450G1X60.789Y-72.280
N12460G1X60.814Y-73.170
N12470G1X60.823Y-74.231
N12480G00Z5.999
N12490G00X39.696Y-66.720
N12500G1Z-1.000F1200.0
N12510G1X34.312Y-86.554F3600.0
N12520G1X33.903Y-88.036
N12530G1X33.542Y-89.268
N12540G1X33.229Y-90.249
N12550G1X32.965Y-90.980
N12560G1X32.802Y-91.375
N12570G1X32.634Y-91.743
N12580G1X32.459Y-92.084
N12590G1X32.279Y-92.397
N12600G1X32.093Y-92.683
N12610G1X31.901Y-92.941
N12620G1X31.703Y-93.173
N12630G1X31.499Y-93.377
N12640G1X31.288Y-93.556
N12650G1X31.066Y-93.710
N12660G1X30.834Y-93.841
N12670G1X30.593Y-93.949
N12680G1X30.341Y-94.032
N12690G1X30.080Y-94.091
N12700G1X29.808Y-94.127
N12710G1X29.527Y-94.139
N12720G1X29.170Y-94.114
N12730G1X28.793Y-94.038
N12740G1X28.397Y-93.912
N12750G1X27.980Y-93.735
N12760G1X27.714Y-90.631
N12770G1X28.095Y-90.760
N12780G1X28.450Y-90.852
N12790G1X28.781Y-90.907
N12800G1X29.087Y-90.925
N12810G1X29.467Y-90.902
N12820G1X29.806Y-90.833
N12830G1X30.106Y-90.719
N12840G1X30.241Y-90.644
N12850G1X30.366Y-90.558
N12860G1X30.595Y-90.356
N12870G1X30.803Y-90.117
N12880G1X30.989Y-89.842
N12890G1X31.153Y-89.529
N12900G1X31.283Y-89.190
N12910G1X31.449Y-88.666
N12920G1X31.886Y-87.069
N12930G1X32.099Y-86.260
N12940G1X26.727Y-66.720
N12950G1X29.313
N12960G1X32.259Y-78.015
N12970G1X32.538Y-79.103
N12980G1X32.802Y-80.218
N12990G1X33.051Y-81.362
N13000G1X33.285Y-82.532
N13010G1X33.502Y-81.401
N13020G1X33.738Y-80.283
N13030G1X33.995Y-79.178
N13040G1X34.272Y-78.088
N13050G1X37.297Y-66.720
N13060G1X39.696
N13070G00Z5.999
N13080G00X24.245Y-69.927
N13090G1Z-1.000F1200.0
N13100G1X24.369Y-70.573F3600.0
N13110G1X24.457Y-71.273
N13120G1X24.511Y-72.027
N13130G1X24.528Y-72.836
N13140G1Y-86.224
N13150G1X22.142
N13160G1Y-73.938
N13170G1X22.128Y-73.015
N13180G1X22.084Y-72.232
N13190G1X22.011Y-71.587
N13200G1X21.909Y-71.082
N13210G1X21.769Y-70.667
N13220G1X21.681Y-70.475
N13230G1X21.581Y-70.294
N13240G1X21.469Y-70.124
N13250G1X21.346Y-69.964
N13260G1X21.210Y-69.815
N13270G1X21.063Y-69.677
N13280G1X20.906Y-69.552
N13290G1X20.743Y-69.444
N13300G1X20.573Y-69.352
N13310G1X20.396Y-69.277
N13320G1X20.213Y-69.219
N13330G1X20.023Y-69.178
N13340G1X19.826Y-69.153
N13350G1X19.623Y-69.144
N13360G1X19.258Y-69.166
N13370G1X18.908Y-69.230
N13380G1X18.575Y-69.337
N13390G1X18.257Y-69.486
N13400G1X17.955Y-69.679
N13410G1X17.669Y-69.914
N13420G1X17.399Y-70.192
N13430G1X17.144Y-70.512
N13440G1X16.913Y-70.880
N13450G1X16.713Y-71.299
N13460G1X16.543Y-71.770
N13470G1X16.404Y-72.292
N13480G1X16.296Y-72.865
N13490G1X16.219Y-73.489
N13500G1X16.173Y-74.165
N13510G1X16.158Y-74.893
N13520G1Y-86.224
N13530G1X13.759
N13540G1Y-73.552
N13550G1X13.749Y-73.018
N13560G1X13.722Y-72.519
N13570G1X13.676Y-72.054
N13580G1X13.612Y-71.624
N13590G1X13.529Y-71.228
N13600G1X13.429Y-70.866
N13610G1X13.310Y-70.539
N13620G1X13.172Y-70.246
N13630G1X13.014Y-69.988
N13640G1X12.832Y-69.764
N13650G1X12.627Y-69.575
N13660G1X12.399Y-69.420
N13670G1X12.147Y-69.299
N13680G1X11.873Y-69.213
N13690G1X11.574Y-69.161
N13700G1X11.253Y-69.144
N13710G1X11.002Y-69.156
N13720G1X10.756Y-69.190
N13730G1X10.515Y-69.248
N13740G1X10.278Y-69.328
N13750G1X10.046Y-69.431
N13760G1X9.819Y-69.557
N13770G1X9.597Y-69.707
N13780G1X9.380Y-69.879
N13790G1X9.173Y-70.073
N13800G1X8.980Y-70.289
N13810G1X8.802Y-70.525
N13820G1X8.639Y-70.783
N13830G1X8.490Y-71.063
N13840G1X8.357Y-71.363
N13850G1X8.238Y-71.685
N13860G1X8.134Y-72.028
N13870G1X8.043Y-72.401
N13880G1X7.965Y-72.813
N13890G1X7.898Y-73.264
N13900G1X7.844Y-73.754
N13910G1X7.771Y-74.851
N13920G1X7.747Y-76.105
N13930G1Y-86.224
N13940G1X5.348
N13950G1Y-66.720
N13960G1X7.494
N13970G1Y-69.456
N13980G1X7.668Y-69.107
N13990G1X7.855Y-68.775
N14000G1X8.056Y-68.461
N14010G1X8.270Y-68.164
N14020G1X8.499Y-67.885
N14030G1X8.741Y-67.623
N14040G1X8.997Y-67.378
N14050G1X9.267Y-67.152
N14060G1X9.548Y-66.947
N14070G1X9.839Y-66.770
N14080G1X10.140Y-66.620
N14090G1X10.450Y-66.497
N14100G1X10.769Y-66.402
N14110G1X11.099Y-66.334
N14120G1X11.437Y-66.293
N14130G1X11.786Y-66.279
N14140G1X12.170Y-66.293
N14150G1X12.537Y-66.336
N14160G1X12.886Y-66.406
N14170G1X13.217Y-66.504
N14180G1X13.531Y-66.631
N14190G1X13.826Y-66.786
N14200G1X14.105Y-66.968
N14210G1X14.365Y-67.179
N14220G1X14.607Y-67.415
N14230G1X14.831Y-67.674
N14240G1X15.036Y-67.955
N14250G1X15.223Y-68.258
N14260G1X15.391Y-68.584
N14270G1X15.541Y-68.932
N14280G1X15.672Y-69.302
N14290G1X15.785Y-69.695
N14300G1X15.998Y-69.282
N14310G1X16.220Y-68.895
N14320G1X16.450Y-68.534
N14330G1X16.688Y-68.201
N14340G1X16.933Y-67.894
N14350G1X17.187Y-67.614
N14360G1X17.448Y-67.360
N14370G1X17.717Y-67.133
N14380G1X17.994Y-66.933
N14390G1X18.280Y-66.760
N14400G1X18.573Y-66.613
N14410G1X18.873Y-66.493
N14420G1X19.182Y-66.399
N14430G1X19.499Y-66.333
N14440G1X19.824Y-66.293
N14450G1X20.156Y-66.279
N14460G1X20.668Y-66.304
N14470G1X21.149Y-66.380
N14480G1X21.599Y-66.505
N14490G1X22.019Y-66.681
N14500G1X22.409Y-66.907
N14510G1X22.768Y-67.183
N14520G1X23.097Y-67.510
N14530G1X23.395Y-67.886
N14540G1X23.661Y-68.315
N14550G1X23.891Y-68.798
N14560G1X24.086Y-69.336
N14570G1X24.245Y-69.927
N14580G00Z5.999
N14590G00X12.719Y-115.204
N14600G1Z-1.000F1200.0
N14610G1Y-118.528F3600.0
N14620G1X5.348
N14630G1Y-115.204
N14640G1X12.719
N14650G00Z5.999
N14660G00X23.579Y-121.173
N14670G1Z-1.000F1200.0
N14680G1X23.842Y-120.732F3600.0
N14690G1X24.128Y-120.282
N14700G1X24.445Y-119.816
N14710G1X25.170Y-118.831
N14720G1X26.015Y-117.777
N14730G1X26.981Y-116.655
N14740G1X27.745Y-115.778
N14750G1X28.444Y-114.948
N14760G1X29.079Y-114.165
N14770G1X29.650Y-113.429
N14780G1X30.156Y-112.740
N14790G1X30.597Y-112.097
N14800G1X30.974Y-111.501
N14810G1X31.286Y-110.952
N14820G1X31.548Y-110.430
N14830G1X31.776Y-109.915
N14840G1X31.968Y-109.407
N14850G1X32.126Y-108.907
N14860G1X32.248Y-108.413
N14870G1X32.336Y-107.927
N14880G1X32.388Y-107.448
N14890G1X32.406Y-106.976
N14900G1X32.390Y-106.495
N14910G1X32.342Y-106.032
N14920G1X32.262Y-105.589
N14930G1X32.151Y-105.165
N14940G1X32.007Y-104.760
N14950G1X31.832Y-104.375
N14960G1X31.625Y-104.008
N14970G1X31.386Y-103.661
N14980G1X31.121Y-103.345
N14990G1X30.837Y-103.071
N15000G1X30.534Y-102.839
N15010G1X30.211Y-102.649
N15020G1X29.869Y-102.501
N15030G1X29.508Y-102.396
N15040G1X29.127Y-102.333
N15050G1X28.727Y-102.312
N15060G1X28.304Y-102.334
N15070G1X27.904Y-102.401
N15080G1X27.525Y-102.513
N15090G1X27.167Y-102.670
N15100G1X26.832Y-102.871
N15110G1X26.518Y-103.117
N15120G1X26.225Y-103.408
N15130G1X25.954Y-103.744
N15140G1X25.711Y-104.119
N15150G1X25.499Y-104.529
N15160G1X25.319Y-104.973
N15170G1X25.171Y-105.452
N15180G1X25.056Y-105.965
N15190G1X24.972Y-106.513
N15200G1X24.921Y-107.095
N15210G1X24.901Y-107.711
N15220G1X22.436Y-107.362
N15230G1X22.521Y-106.440
N15240G1X22.650Y-105.574
N15250G1X22.822Y-104.765
N15260G1X23.039Y-104.013
N15270G1X23.163Y-103.658
N15280G1X23.299Y-103.317
N15290G1X23.445Y-102.990
N15300G1X23.603Y-102.677
N15310G1X23.771Y-102.379
N15320G1X23.950Y-102.094
N15330G1X24.140Y-101.824
N15340G1X24.342Y-101.568
N15350G1X24.553Y-101.326
N15360G1X24.773Y-101.101
N15370G1X25.001Y-100.891
N15380G1X25.239Y-100.696
N15390G1X25.485Y-100.517
N15400G1X25.741Y-100.354
N15410G1X26.005Y-100.206
N15420G1X26.278Y-100.073
N15430G1X26.559Y-99.957
N15440G1X26.850Y-99.855
N15450G1X27.150Y-99.770
N15460G1X27.458Y-99.700
N15470G1X27.775Y-99.645
N15480G1X28.101Y-99.606
N15490G1X28.436Y-99.583
N15500G1X28.780Y-99.575
N15510G1X29.127Y-99.584
N15520G1X29.465Y-99.609
N15530G1X29.794Y-99.651
N15540G1X30.113Y-99.709
N15550G1X30.423Y-99.785
N15560G1X30.724Y-99.877
N15570G1X31.016Y-99.986
N15580G1X31.299Y-100.112
N15590G1X31.573Y-100.255
N15600G1X31.837Y-100.415
N15610G1X32.093Y-100.591
N15620G1X32.339Y-100.784
N15630G1X32.576Y-100.994
N15640G1X32.804Y-101.220
N15650G1X33.022Y-101.464
N15660G1X33.232Y-101.724
N15670G1X33.430Y-101.996
N15680G1X33.616Y-102.277
N15690G1X33.789Y-102.566
N15700G1X33.949Y-102.863
N15710G1X34.231Y-103.480
N15720G1X34.462Y-104.130
N15730G1X34.641Y-104.812
N15740G1X34.769Y-105.525
N15750G1X34.846Y-106.272
N15760G1X34.871Y-107.050
N15770G1X34.864Y-107.453
N15780G1X34.841Y-107.854
N15790G1X34.804Y-108.254
N15800G1X34.751Y-108.652
N15810G1X34.684Y-109.048
N15820G1X34.601Y-109.443
N15830G1X34.392Y-110.227
N15840G1X34.262Y-110.620
N15850G1X34.112Y-111.018
N15860G1X33.943Y-111.421
N15870G1X33.753Y-111.829
N15880G1X33.544Y-112.243
N15890G1X33.316Y-112.661
N15900G1X32.799Y-113.514
N15910G1X32.497Y-113.966
N15920G1X32.150Y-114.458
N15930G1X31.318Y-115.562
N15940G1X30.301Y-116.827
N15950G1X29.100Y-118.252
N15960G1X28.117Y-119.401
N15970G1X27.327Y-120.348
N15980G1X26.731Y-121.095
N15990G1X26.328Y-121.641
N16000G1X26.034Y-122.087
N16010G1X25.768Y-122.534
N16020G1X25.528Y-122.982
N16030G1X25.315Y-123.431
N16040G1X34.898
N16050G1Y-126.609
N16060G1X21.982
N16070G1X21.990Y-126.017
N16080G1X22.039Y-125.438
N16090G1X22.130Y-124.870
N16100G1X22.262Y-124.313
N16110G1X22.395Y-123.859
N16120G1X22.546Y-123.407
N16130G1X22.716Y-122.957
N16140G1X22.904Y-122.509
N16150G1X23.110Y-122.062
N16160G1X23.336Y-121.617
N16170G1X23.579Y-121.173
N16180G00Z5.999
N16190G00X37.470Y-119.556
N16200G1Z-1.000F1200.0
N16210G1X39.990Y-119.262F3600.0
N16220G1X40.071Y-119.876
N16230G1X40.176Y-120.451
N16240G1X40.304Y-120.986
N16250G1X40.454Y-121.482
N16260G1X40.628Y-121.939
N16270G1X40.826Y-122.356
N16280G1X41.046Y-122.734
N16290G1X41.289Y-123.073
N16300G1X41.551Y-123.372
N16310G1X41.825Y-123.632
N16320G1X42.113Y-123.851
N16330G1X42.414Y-124.031
N16340G1X42.728Y-124.170
N16350G1X43.055Y-124.270
N16360G1X43.395Y-124.330
N16370G1X43.748Y-124.350
N16380G1X44.173Y-124.321
N16390G1X44.581Y-124.237
N16400G1X44.973Y-124.097
N16410G1X45.348Y-123.900
N16420G1X45.706Y-123.647
N16430G1X46.048Y-123.337
N16440G1X46.372Y-122.972
N16450G1X46.681Y-122.550
N16460G1X46.962Y-122.082
N16470G1X47.205Y-121.576
N16480G1X47.412Y-121.035
N16490G1X47.580Y-120.456
N16500G1X47.712Y-119.841
N16510G1X47.805Y-119.189
N16520G1X47.862Y-118.500
N16530G1X47.880Y-117.775
N16540G1X47.862Y-117.087
N16550G1X47.808Y-116.435
N16560G1X47.718Y-115.822
N16570G1X47.592Y-115.245
N16580G1X47.430Y-114.706
N16590G1X47.232Y-114.204
N16600G1X46.998Y-113.739
N16610G1X46.727Y-113.312
N16620G1X46.428Y-112.929
N16630G1X46.106Y-112.597
N16640G1X45.762Y-112.316
N16650G1X45.396Y-112.086
N16660G1X45.008Y-111.908
N16670G1X44.597Y-111.780
N16680G1X44.164Y-111.703
N16690G1X43.708Y-111.678
N16700G1X43.422Y-111.689
N16710G1X43.143Y-111.723
N16720G1X42.871Y-111.780
N16730G1X42.605Y-111.859
N16740G1X42.347Y-111.961
N16750G1X42.096Y-112.086
N16760G1X41.853Y-112.233
N16770G1X41.616Y-112.403
N16780G1X41.389Y-112.591
N16790G1X41.174Y-112.793
N16800G1X40.972Y-113.008
N16810G1X40.783Y-113.236
N16820G1X40.606Y-113.479
N16830G1X40.441Y-113.734
N16840G1X40.289Y-114.003
N16850G1X40.150Y-114.286
N16860G1X37.897Y-113.882
N16870G1X39.790Y-100.053
N16880G1X49.506
N16890G1Y-103.211
N16900G1X41.709
N16910G1X40.656Y-110.447
N16920G1X41.099Y-110.051
N16930G1X41.547Y-109.708
N16940G1X42.000Y-109.418
N16950G1X42.459Y-109.180
N16960G1X42.923Y-108.995
N16970G1X43.393Y-108.863
N16980G1X43.868Y-108.784
N16990G1X44.348Y-108.758
N17000G1X44.665Y-108.767
N17010G1X44.975Y-108.796
N17020G1X45.280Y-108.844
N17030G1X45.578Y-108.910
N17040G1X45.869Y-108.996
N17050G1X46.155Y-109.101
N17060G1X46.434Y-109.225
N17070G1X46.707Y-109.368
N17080G1X46.974Y-109.531
N17090G1X47.235Y-109.712
N17100G1X47.489Y-109.912
N17110G1X47.737Y-110.132
N17120G1X47.979Y-110.370
N17130G1X48.214Y-110.628
N17140G1X48.444Y-110.904
N17150G1X48.667Y-111.200
N17160G1X48.880Y-111.511
N17170G1X49.079Y-111.833
N17180G1X49.265Y-112.165
N17190G1X49.436Y-112.509
N17200G1X49.594Y-112.863
N17210G1X49.739Y-113.228
N17220G1X49.869Y-113.605
N17230G1X49.986Y-113.992
N17240G1X50.089Y-114.390
N17250G1X50.179Y-114.799
N17260G1X50.254Y-115.218
N17270G1X50.316Y-115.649
N17280G1X50.399Y-116.543
N17290G1X50.426Y-117.481
N17300G1X50.402Y-118.379
N17310G1X50.329Y-119.246
N17320G1X50.209Y-120.083
N17330G1X50.040Y-120.888
N17340G1X49.822Y-121.662
N17350G1X49.556Y-122.405
N17360G1X49.242Y-123.117
N17370G1X48.880Y-123.799
N17380G1X48.640Y-124.195
N17390G1X48.389Y-124.565
N17400G1X48.127Y-124.910
N17410G1X47.854Y-125.229
N17420G1X47.571Y-125.523
N17430G1X47.277Y-125.791
N17440G1X46.973Y-126.033
N17450G1X46.657Y-126.250
N17460G1X46.331Y-126.442
N17470G1X45.994Y-126.608
N17480G1X45.647Y-126.748
N17490G1X45.289Y-126.863
N17500G1X44.920Y-126.953
N17510G1X44.540Y-127.017
N17520G1X44.150Y-127.055
N17530G1X43.748Y-127.068
N17540G1X43.419Y-127.060
N17550G1X43.097Y-127.036
N17560G1X42.783Y-126.995
N17570G1X42.477Y-126.939
N17580G1X42.178Y-126.867
N17590G1X41.887Y-126.778
N17600G1X41.603Y-126.674
N17610G1X41.327Y-126.553
N17620G1X41.059Y-126.417
N17630G1X40.799Y-126.264
N17640G1X40.546Y-126.095
N17650G1X40.301Y-125.911
N17660G1X40.063Y-125.710
N17670G1X39.833Y-125.493
N17680G1X39.611Y-125.260
N17690G1X39.396Y-125.011
N17700G1X39.191Y-124.748
N17710G1X38.998Y-124.476
N17720G1X38.815Y-124.192
N17730G1X38.644Y-123.899
N17740G1X38.335Y-123.280
N17750G1X38.072Y-122.619
N17760G1X37.854Y-121.916
N17770G1X37.681Y-121.171
N17780G1X37.553Y-120.385
N17790G1X37.470Y-119.556
N17800G00Z5.999
N17810G00X53.318Y-126.609
N17820G1Z-1.000F1200.0
N17830G1Y-107.105F3600.0
N17840G1X55.464
N17850G1Y-109.841
N17860G1X55.638Y-109.492
N17870G1X55.825Y-109.160
N17880G1X56.026Y-108.846
N17890G1X56.241Y-108.549
N17900G1X56.469Y-108.269
N17910G1X56.711Y-108.008
N17920G1X56.967Y-107.763
N17930G1X57.237Y-107.536
N17940G1X57.518Y-107.332
N17950G1X57.809Y-107.155
N17960G1X58.110Y-107.005
N17970G1X58.420Y-106.882
N17980G1X58.740Y-106.787
N17990G1X59.069Y-106.719
N18000G1X59.408Y-106.678
N18010G1X59.756Y-106.664
N18020G1X60.141Y-106.678
N18030G1X60.507Y-106.720
N18040G1X60.856Y-106.791
N18050G1X61.187Y-106.889
N18060G1X61.501Y-107.016
N18070G1X61.797Y-107.170
N18080G1X62.075Y-107.353
N18090G1X62.335Y-107.564
N18100G1X62.578Y-107.800
N18110G1X62.801Y-108.059
N18120G1X63.007Y-108.340
N18130G1X63.193Y-108.643
N18140G1X63.362Y-108.969
N18150G1X63.511Y-109.317
N18160G1X63.642Y-109.687
N18170G1X63.755Y-110.080
N18180G1X63.969Y-109.666
N18190G1X64.191Y-109.279
N18200G1X64.420Y-108.919
N18210G1X64.658Y-108.586
N18220G1X64.903Y-108.279
N18230G1X65.157Y-107.998
N18240G1X65.418Y-107.745
N18250G1X65.688Y-107.518
N18260G1X65.965Y-107.318
N18270G1X66.250Y-107.144
N18280G1X66.543Y-106.998
N18290G1X66.844Y-106.878
N18300G1X67.153Y-106.784
N18310G1X67.469Y-106.717
N18320G1X67.794Y-106.677
N18330G1X68.127Y-106.664
N18340G1X68.638Y-106.689
N18350G1X69.119Y-106.765
N18360G1X69.569Y-106.890
N18370G1X69.989Y-107.066
N18380G1X70.379Y-107.292
N18390G1X70.738Y-107.568
N18400G1X71.067Y-107.894
N18410G1X71.366Y-108.271
N18420G1X71.631Y-108.700
N18430G1X71.861Y-109.183
N18440G1X72.056Y-109.720
N18450G1X72.215Y-110.312
N18460G1X72.339Y-110.958
N18470G1X72.428Y-111.658
N18480G1X72.481Y-112.412
N18490G1X72.499Y-113.220
N18500G1Y-126.609
N18510G1X70.113
N18520G1Y-114.322
N18530G1X70.098Y-113.400
N18540G1X70.054Y-112.617
N18550G1X69.981Y-111.972
N18560G1X69.879Y-111.467
N18570G1X69.739Y-111.052
N18580G1X69.651Y-110.860
N18590G1X69.551Y-110.679
N18600G1X69.439Y-110.509
N18610G1X69.316Y-110.349
N18620G1X69.180Y-110.200
N18630G1X69.033Y-110.062
N18640G1X68.876Y-109.937
N18650G1X68.713Y-109.829
N18660G1X68.543Y-109.737
N18670G1X68.367Y-109.662
N18680G1X68.183Y-109.604
N18690G1X67.993Y-109.562
N18700G1X67.797Y-109.537
N18710G1X67.594Y-109.529
N18720G1X67.228Y-109.550
N18730G1X66.879Y-109.615
N18740G1X66.545Y-109.721
N18750G1X66.227Y-109.871
N18760G1X65.925Y-110.063
N18770G1X65.639Y-110.299
N18780G1X65.369Y-110.577
N18790G1X65.114Y-110.897
N18800G1X64.883Y-111.265
N18810G1X64.683Y-111.684
N18820G1X64.513Y-112.155
N18830G1X64.375Y-112.676
N18840G1X64.267Y-113.250
N18850G1X64.190Y-113.874
N18860G1X64.143Y-114.550
N18870G1X64.128Y-115.277
N18880G1Y-126.609
N18890G1X61.729
N18900G1Y-113.937
N18910G1X61.720Y-113.403
N18920G1X61.692Y-112.904
N18930G1X61.646Y-112.439
N18940G1X61.582Y-112.008
N18950G1X61.500Y-111.612
N18960G1X61.399Y-111.251
N18970G1X61.280Y-110.924
N18980G1X61.142Y-110.631
N18990G1X60.984Y-110.373
N19000G1X60.803Y-110.149
N19010G1X60.598Y-109.959
N19020G1X60.369Y-109.804
N19030G1X60.118Y-109.684
N19040G1X59.843Y-109.598
N19050G1X59.545Y-109.546
N19060G1X59.223Y-109.529
N19070G1X58.972Y-109.540
N19080G1X58.726Y-109.575
N19090G1X58.485Y-109.632
N19100G1X58.248Y-109.713
N19110G1X58.017Y-109.816
N19120G1X57.790Y-109.942
N19130G1X57.568Y-110.091
N19140G1X57.350Y-110.264
N19150G1X57.143Y-110.458
N19160G1X56.950Y-110.673
N19170G1X56.772Y-110.910
N19180G1X56.609Y-111.168
N19190G1X56.461Y-111.447
N19200G1X56.327Y-111.748
N19210G1X56.208Y-112.069
N19220G1X56.104Y-112.412
N19230G1X56.014Y-112.785
N19240G1X55.935Y-113.197
N19250G1X55.869Y-113.649
N19260G1X55.814Y-114.139
N19270G1X55.742Y-115.236
N19280G1X55.718Y-116.489
N19290G1Y-126.609
N19300G1X53.318
N19310G00Z5.999
N19320G00X76.057
N19330G1Z-1.000F1200.0
N19340G1Y-107.105F3600.0
N19350G1X78.203
N19360G1Y-109.841
N19370G1X78.377Y-109.492
N19380G1X78.564Y-109.160
N19390G1X78.765Y-108.846
N19400G1X78.980Y-108.549
N19410G1X79.208Y-108.269
N19420G1X79.450Y-108.008
N19430G1X79.706Y-107.763
N19440G1X79.976Y-107.536
N19450G1X80.257Y-107.332
N19460G1X80.548Y-107.155
N19470G1X80.849Y-107.005
N19480G1X81.159Y-106.882
N19490G1X81.479Y-106.787
N19500G1X81.808Y-106.719
N19510G1X82.147Y-106.678
N19520G1X82.495Y-106.664
N19530G1X82.879Y-106.678
N19540G1X83.246Y-106.720
N19550G1X83.595Y-106.791
N19560G1X83.926Y-106.889
N19570G1X84.240Y-107.016
N19580G1X84.536Y-107.170
N19590G1X84.814Y-107.353
N19600G1X85.074Y-107.564
N19610G1X85.317Y-107.800
N19620G1X85.540Y-108.059
N19630G1X85.746Y-108.340
N19640G1X85.932Y-108.643
N19650G1X86.100Y-108.969
N19660G1X86.250Y-109.317
N19670G1X86.381Y-109.687
N19680G1X86.494Y-110.080
N19690G1X86.708Y-109.666
N19700G1X86.929Y-109.279
N19710G1X87.159Y-108.919
N19720G1X87.397Y-108.586
N19730G1X87.642Y-108.279
N19740G1X87.896Y-107.998
N19750G1X88.157Y-107.745
N19760G1X88.426Y-107.518
N19770G1X88.704Y-107.318
N19780G1X88.989Y-107.144
N19790G1X89.282Y-106.998
N19800G1X89.583Y-106.878
N19810G1X89.892Y-106.784
N19820G1X90.208Y-106.717
N19830G1X90.533Y-106.677
N19840G1X90.866Y-106.664
N19850G1X91.377Y-106.689
N19860G1X91.858Y-106.765
N19870G1X92.308Y-106.890
N19880G1X92.728Y-107.066
N19890G1X93.118Y-107.292
N19900G1X93.477Y-107.568
N19910G1X93.806Y-107.894
N19920G1X94.104Y-108.271
N19930G1X94.370Y-108.700
N19940G1X94.600Y-109.183
N19950G1X94.795Y-109.720
N19960G1X94.954Y-110.312
N19970G1X95.078Y-110.958
N19980G1X95.167Y-111.658
N19990G1X95.220Y-112.412
N20000G1X95.237Y-113.220
N20010G1Y-126.609
N20020G1X92.852
N20030G1Y-114.322
N20040G1X92.837Y-113.400
N20050G1X92.793Y-112.617
N20060G1X92.720Y-111.972
N20070G1X92.618Y-111.467
N20080G1X92.478Y-111.052
N20090G1X92.390Y-110.860
N20100G1X92.290Y-110.679
N20110G1X92.178Y-110.509
N20120G1X92.055Y-110.349
N20130G1X91.919Y-110.200
N20140G1X91.772Y-110.062
N20150G1X91.615Y-109.937
N20160G1X91.452Y-109.829
N20170G1X91.282Y-109.737
N20180G1X91.106Y-109.662
N20190G1X90.922Y-109.604
N20200G1X90.732Y-109.562
N20210G1X90.536Y-109.537
N20220G1X90.332Y-109.529
N20230G1X89.967Y-109.550
N20240G1X89.618Y-109.615
N20250G1X89.284Y-109.721
N20260G1X88.966Y-109.871
N20270G1X88.664Y-110.063
N20280G1X88.378Y-110.299
N20290G1X88.108Y-110.577
N20300G1X87.853Y-110.897
N20310G1X87.622Y-111.265
N20320G1X87.422Y-111.684
N20330G1X87.252Y-112.155
N20340G1X87.114Y-112.676
N20350G1X87.006Y-113.250
N20360G1X86.929Y-113.874
N20370G1X86.882Y-114.550
N20380G1X86.867Y-115.277
N20390G1Y-126.609
N20400G1X84.468
N20410G1Y-113.937
N20420G1X84.459Y-113.403
N20430G1X84.431Y-112.904
N20440G1X84.385Y-112.439
N20450G1X84.321Y-112.008
N20460G1X84.239Y-111.612
N20470G1X84.138Y-111.251
N20480G1X84.019Y-110.924
N20490G1X83.881Y-110.631
N20500G1X83.723Y-110.373
N20510G1X83.541Y-110.149
N20520G1X83.337Y-109.959
N20530G1X83.108Y-109.804
N20540G1X82.857Y-109.684
N20550G1X82.582Y-109.598
N20560G1X82.284Y-109.546
N20570G1X81.962Y-109.529
N20580G1X81.711Y-109.540
N20590G1X81.465Y-109.575
N20600G1X81.224Y-109.632
N20610G1X80.987Y-109.713
N20620G1X80.756Y-109.816
N20630G1X80.529Y-109.942
N20640G1X80.307Y-110.091
N20650G1X80.089Y-110.264
N20660G1X79.882Y-110.458
N20670G1X79.689Y-110.673
N20680G1X79.511Y-110.910
N20690G1X79.348Y-111.168
N20700G1X79.199Y-111.447
N20710G1X79.066Y-111.748
N20720G1X78.947Y-112.069
N20730G1X78.843Y-112.412
N20740G1X78.752Y-112.785
N20750G1X78.674Y-113.197
N20760G1X78.607Y-113.649
N20770G1X78.553Y-114.139
N20780G1X78.481Y-115.236
N20790G1X78.456Y-116.489
N20800G1Y-126.609
N20810G1X76.057
N20820G00Z5.999
N20830G00X104.234Y-74.599
N20840G1Z-1.000F1200.0
N20850G1X112.138F3600.0
N20860G1X112.089Y-74.003
N20870G1X112.022Y-73.445
N20880G1X111.936Y-72.926
N20890G1X111.832Y-72.445
N20900G1X111.709Y-72.003
N20910G1X111.569Y-71.599
N20920G1X111.409Y-71.234
N20930G1X111.232Y-70.907
N20940G1X110.935Y-70.460
N20950G1X110.616Y-70.072
N20960G1X110.277Y-69.743
N20970G1X110.099Y-69.602
N20980G1X109.916Y-69.475
N20990G1X109.727Y-69.363
N21000G1X109.534Y-69.266
N21010G1X109.335Y-69.184
N21020G1X109.130Y-69.117
N21030G1X108.921Y-69.064
N21040G1X108.706Y-69.027
N21050G1X108.485Y-69.005
N21060G1X108.260Y-68.997
N21070G1X107.855Y-69.021
N21080G1X107.466Y-69.093
N21090G1X107.094Y-69.212
N21100G1X106.739Y-69.378
N21110G1X106.399Y-69.593
N21120G1X106.077Y-69.855
N21130G1X105.770Y-70.164
N21140G1X105.481Y-70.522
N21150G1X105.215Y-70.919
N21160G1X104.980Y-71.348
N21170G1X104.777Y-71.809
N21180G1X104.606Y-72.303
N21190G1X104.466Y-72.829
N21200G1X104.357Y-73.387
N21210G1X104.280Y-73.977
N21220G1X104.234Y-74.599
N21230G00Z5.999
N21240G00X101.737Y-74.314
N21250G1Z-1.000F1200.0
N21260G1X101.802Y-73.776F3600.0
N21270G1X101.881Y-73.256
N21280G1X101.974Y-72.752
N21290G1X102.082Y-72.266
N21300G1X102.204Y-71.797
N21310G1X102.340Y-71.346
N21320G1X102.491Y-70.911
N21330G1X102.657Y-70.494
N21340G1X102.836Y-70.094
N21350G1X103.030Y-69.711
N21360G1X103.239Y-69.346
N21370G1X103.461Y-68.997
N21380G1X103.695Y-68.668
N21390G1X103.938Y-68.360
N21400G1X104.189Y-68.074
N21410G1X104.449Y-67.808
N21420G1X104.718Y-67.564
N21430G1X104.995Y-67.341
N21440G1X105.280Y-67.139
N21450G1X105.574Y-66.959
N21460G1X105.876Y-66.800
N21470G1X106.187Y-66.662
N21480G1X106.507Y-66.545
N21490G1X106.835Y-66.449
N21500G1X107.172Y-66.375
N21510G1X107.517Y-66.322
N21520G1X107.871Y-66.290
N21530G1X108.233Y-66.279
N21540G1X108.584Y-66.290
N21550G1X108.927Y-66.321
N21560G1X109.261Y-66.373
N21570G1X109.588Y-66.446
N21580G1X109.906Y-66.539
N21590G1X110.216Y-66.654
N21600G1X110.518Y-66.789
N21610G1X110.812Y-66.945
N21620G1X111.098Y-67.122
N21630G1X111.376Y-67.320
N21640G1X111.645Y-67.538
N21650G1X111.907Y-67.777
N21660G1X112.160Y-68.037
N21670G1X112.405Y-68.318
N21680G1X112.642Y-68.620
N21690G1X112.871Y-68.942
N21700G1X113.089Y-69.284
N21710G1X113.293Y-69.642
N21720G1X113.483Y-70.017
N21730G1X113.659Y-70.409
N21740G1X113.820Y-70.818
N21750G1X113.968Y-71.244
N21760G1X114.101Y-71.687
N21770G1X114.221Y-72.147
N21780G1X114.326Y-72.624
N21790G1X114.418Y-73.117
N21800G1X114.495Y-73.628
N21810G1X114.558Y-74.156
N21820G1X114.608Y-74.700
N21830G1X114.643Y-75.262
N21840G1X114.671Y-76.435
N21850G1X114.657Y-77.317
N21860G1X104.101
N21870G1X104.151Y-78.097
N21880G1X104.234Y-78.830
N21890G1X104.349Y-79.515
N21900G1X104.498Y-80.154
N21910G1X104.679Y-80.746
N21920G1X104.893Y-81.290
N21930G1X105.141Y-81.788
N21940G1X105.421Y-82.239
N21950G1X105.726Y-82.639
N21960G1X106.050Y-82.986
N21970G1X106.393Y-83.279
N21980G1X106.754Y-83.520
N21990G1X107.133Y-83.706
N22000G1X107.530Y-83.840
N22010G1X107.946Y-83.920
N22020G1X108.380Y-83.947
N22030G1X108.703Y-83.932
N22040G1X109.015Y-83.887
N22050G1X109.315Y-83.812
N22060G1X109.603Y-83.708
N22070G1X109.878Y-83.573
N22080G1X110.142Y-83.409
N22090G1X110.393Y-83.215
N22100G1X110.632Y-82.992
N22110G1X110.859Y-82.735
N22120G1X111.075Y-82.443
N22130G1X111.278Y-82.115
N22140G1X111.469Y-81.752
N22150G1X111.647Y-81.353
N22160G1X111.814Y-80.919
N22170G1X111.969Y-80.449
N22180G1X112.112Y-79.943
N22190G1X114.591Y-80.365
N22200G1X114.429Y-81.093
N22210G1X114.235Y-81.778
N22220G1X114.010Y-82.422
N22230G1X113.754Y-83.024
N22240G1X113.467Y-83.584
N22250G1X113.149Y-84.101
N22260G1X112.799Y-84.578
N22270G1X112.418Y-85.012
N22280G1X112.008Y-85.399
N22290G1X111.570Y-85.735
N22300G1X111.105Y-86.019
N22310G1X110.612Y-86.251
N22320G1X110.092Y-86.432
N22330G1X109.544Y-86.561
N22340G1X108.969Y-86.639
N22350G1X108.366Y-86.665
N22360G1X107.983Y-86.654
N22370G1X107.610Y-86.623
N22380G1X107.247Y-86.572
N22390G1X106.894Y-86.500
N22400G1X106.551Y-86.407
N22410G1X106.218Y-86.294
N22420G1X105.895Y-86.160
N22430G1X105.582Y-86.006
N22440G1X105.279Y-85.831
N22450G1X104.987Y-85.635
N22460G1X104.704Y-85.419
N22470G1X104.431Y-85.182
N22480G1X104.169Y-84.925
N22490G1X103.916Y-84.647
N22500G1X103.674Y-84.348
N22510G1X103.441Y-84.029
N22520G1X103.221Y-83.691
N22530G1X103.015Y-83.337
N22540G1X102.823Y-82.966
N22550G1X102.645Y-82.579
N22560G1X102.482Y-82.175
N22570G1X102.333Y-81.754
N22580G1X102.198Y-81.317
N22590G1X102.077Y-80.863
N22600G1X101.970Y-80.393
N22610G1X101.878Y-79.906
N22620G1X101.800Y-79.403
N22630G1X101.736Y-78.883
N22640G1X101.686Y-78.346
N22650G1X101.650Y-77.793
N22660G1X101.622Y-76.637
N22670G1X101.651Y-75.441
N22680G1X101.687Y-74.869
N22690G1X101.737Y-74.314
N22700G00Z5.999
N22710G00X125.201Y-66.720
N22720G1Z-1.000F1200.0
N22730G1X127.600F3600.0
N22740G1Y-86.224
N22750G1X125.201
N22760G1Y-66.720
N22770G00Z5.999
N22780G00X131.125Y-69.484
N22790G1Z-1.000F1200.0
N22800G1X131.361Y-68.952F3600.0
N22810G1X131.637Y-68.467
N22820G1X131.951Y-68.029
N22830G1X132.123Y-67.828
N22840G1X132.305Y-67.638
N22850G1X132.610Y-67.365
N22860G1X132.966Y-67.113
N22870G1X133.373Y-66.882
N22880G1X133.831Y-66.674
N22890G1X134.323Y-66.501
N22900G1X134.832Y-66.378
N22910G1X135.359Y-66.304
N22920G1X135.904Y-66.279
N22930G1X136.314Y-66.290
N22940G1X136.711Y-66.321
N22950G1X137.096Y-66.372
N22960G1X137.468Y-66.445
N22970G1X137.827Y-66.538
N22980G1X138.174Y-66.651
N22990G1X138.508Y-66.786
N23000G1X138.829Y-66.940
N23010G1X139.134Y-67.113
N23020G1X139.418Y-67.300
N23030G1X139.681Y-67.502
N23040G1X139.924Y-67.719
N23050G1X140.146Y-67.950
N23060G1X140.347Y-68.196
N23070G1X140.528Y-68.456
N23080G1X140.689Y-68.731
N23090G1X140.833Y-69.025
N23100G1X140.965Y-69.343
N23110G1X141.086Y-69.685
N23120G1X141.195Y-70.051
N23130G1X141.293Y-70.441
N23140G1X141.378Y-70.854
N23150G1X141.452Y-71.291
N23160G1X141.515Y-71.752
N23170G1X139.169Y-72.193
N23180G1X139.120Y-71.827
N23190G1X139.051Y-71.481
N23200G1X138.964Y-71.156
N23210G1X138.858Y-70.852
N23220G1X138.732Y-70.569
N23230G1X138.588Y-70.306
N23240G1X138.425Y-70.064
N23250G1X138.243Y-69.842
N23260G1X138.041Y-69.644
N23270G1X137.820Y-69.473
N23280G1X137.579Y-69.327
N23290G1X137.318Y-69.209
N23300G1X137.037Y-69.116
N23310G1X136.737Y-69.050
N23320G1X136.417Y-69.011
N23330G1X136.077Y-68.997
N23340G1X135.678Y-69.009
N23350G1X135.310Y-69.044
N23360G1X134.970Y-69.103
N23370G1X134.661Y-69.186
N23380G1X134.381Y-69.291
N23390G1X134.130Y-69.421
N23400G1X133.909Y-69.574
N23410G1X133.718Y-69.750
N23420G1X133.552Y-69.943
N23430G1X133.409Y-70.143
N23440G1X133.287Y-70.351
N23450G1X133.188Y-70.568
N23460G1X133.111Y-70.792
N23470G1X133.055Y-71.024
N23480G1X133.022Y-71.265
N23490G1X133.011Y-71.513
N23500G1X133.030Y-71.827
N23510G1X133.085Y-72.124
N23520G1X133.176Y-72.405
N23530G1X133.304Y-72.670
N23540G1X133.472Y-72.925
N23550G1X133.681Y-73.157
N23560G1X133.932Y-73.366
N23570G1X134.224Y-73.552
N23580G1X134.934Y-73.855
N23590G1X136.343Y-74.397
N23600G1X137.520Y-74.844
N23610G1X138.504Y-75.248
N23620G1X139.296Y-75.610
N23630G1X139.896Y-75.930
N23640G1X140.140Y-76.088
N23650G1X140.372Y-76.262
N23660G1X140.589Y-76.454
N23670G1X140.794Y-76.662
N23680G1X140.984Y-76.888
N23690G1X141.161Y-77.130
N23700G1X141.325Y-77.389
N23710G1X141.475Y-77.666
N23720G1X141.609Y-77.959
N23730G1X141.726Y-78.269
N23740G1X141.824Y-78.597
N23750G1X141.905Y-78.942
N23760G1X141.968Y-79.304
N23770G1X142.012Y-79.684
N23780G1X142.039Y-80.080
N23790G1X142.048Y-80.494
N23800G1X142.037Y-80.904
N23810G1X142.004Y-81.308
N23820G1X141.950Y-81.706
N23830G1X141.873Y-82.099
N23840G1X141.775Y-82.485
N23850G1X141.655Y-82.865
N23860G1X141.512Y-83.239
N23870G1X141.348Y-83.607
N23880G1X141.164Y-83.961
N23890G1X140.960Y-84.295
N23900G1X140.736Y-84.609
N23910G1X140.494Y-84.901
N23920G1X140.232Y-85.174
N23930G1X139.950Y-85.425
N23940G1X139.649Y-85.656
N23950G1X139.329Y-85.866
N23960G1X138.994Y-86.053
N23970G1X138.648Y-86.215
N23980G1X138.291Y-86.352
N23990G1X137.923Y-86.465
N24000G1X137.544Y-86.552
N24010G1X137.155Y-86.615
N24020G1X136.755Y-86.652
N24030G1X136.343Y-86.665
N24040G1X135.674Y-86.640
N24050G1X135.046Y-86.566
N24060G1X134.459Y-86.442
N24070G1X133.913Y-86.270
N24080G1X133.655Y-86.165
N24090G1X133.407Y-86.048
N24100G1X133.170Y-85.918
N24110G1X132.943Y-85.776
N24120G1X132.727Y-85.622
N24130G1X132.520Y-85.455
N24140G1X132.324Y-85.276
N24150G1X132.138Y-85.085
N24160G1X131.793Y-84.666
N24170G1X131.480Y-84.200
N24180G1X131.201Y-83.686
N24190G1X130.954Y-83.125
N24200G1X130.739Y-82.515
N24210G1X130.557Y-81.859
N24220G1X130.408Y-81.154
N24230G1X130.292Y-80.402
N24240G1X132.665Y-79.888
N24250G1X132.726Y-80.365
N24260G1X132.809Y-80.813
N24270G1X132.915Y-81.232
N24280G1X133.043Y-81.623
N24290G1X133.193Y-81.985
N24300G1X133.366Y-82.319
N24310G1X133.561Y-82.624
N24320G1X133.778Y-82.900
N24330G1X134.017Y-83.145
N24340G1X134.280Y-83.358
N24350G1X134.565Y-83.538
N24360G1X134.872Y-83.685
N24370G1X135.203Y-83.799
N24380G1X135.556Y-83.881
N24390G1X135.932Y-83.930
N24400G1X136.330Y-83.947
N24410G1X136.730Y-83.932
N24420G1X137.103Y-83.889
N24430G1X137.450Y-83.816
N24440G1X137.770Y-83.715
N24450G1X138.063Y-83.584
N24460G1X138.329Y-83.425
N24470G1X138.569Y-83.236
N24480G1X138.783Y-83.019
N24490G1X138.970Y-82.782
N24500G1X139.132Y-82.535
N24510G1X139.270Y-82.278
N24520G1X139.382Y-82.011
N24530G1X139.470Y-81.734
N24540G1X139.532Y-81.447
N24550G1X139.570Y-81.150
N24560G1X139.582Y-80.843
N24570G1X139.571Y-80.570
N24580G1X139.538Y-80.313
N24590G1X139.483Y-80.070
N24600G1X139.406Y-79.842
N24610G1X139.306Y-79.629
N24620G1X139.185Y-79.431
N24630G1X139.041Y-79.248
N24640G1X138.876Y-79.080
N24650G1X138.730Y-78.966
N24660G1X138.538Y-78.844
N24670G1X138.016Y-78.579
N24680G1X137.311Y-78.284
N24690G1X136.423Y-77.959
N24700G1X135.205Y-77.516
N24710G1X134.189Y-77.103
N24720G1X133.376Y-76.722
N24730G1X133.045Y-76.542
N24740G1X132.765Y-76.371
N24750G1X132.517Y-76.195
N24760G1X132.286Y-76.004
N24770G1X132.069Y-75.796
N24780G1X131.868Y-75.572
N24790G1X131.683Y-75.332
N24800G1X131.513Y-75.076
N24810G1X131.358Y-74.804
N24820G1X131.218Y-74.516
N24830G1X131.095Y-74.216
N24840G1X130.988Y-73.908
N24850G1X130.898Y-73.593
N24860G1X130.824Y-73.270
N24870G1X130.766Y-72.939
N24880G1X130.725Y-72.600
N24890G1X130.700Y-72.253
N24900G1X130.692Y-71.899
N24910G1X130.719Y-71.259
N24920G1X130.800Y-70.643
N24930G1X130.936Y-70.052
N24940G1X131.125Y-69.484
N24950G00Z5.999
N24960G00X127.600Y-63.102
N24970G1Z-1.000F1200.0
N24980G1X125.201F3600.0
N24990G1Y-59.301
N25000G1X127.600
N25010G1Y-63.102
N25020G00Z5.999
N25030G00X127.483Y-25.291
N25040G1Z-1.000F1200.0
N25050G1X125.084F3600.0
N25060G1Y-11.135
N25070G1X127.483
N25080G1Y-25.291
N25090G00Z5.999
N25100G00X130.837Y-23.041
N25110G1Z-1.000F1200.0
N25120G1X130.622Y-22.599F3600.0
N25130G1X130.441Y-22.123
N25140G1X130.292Y-21.611
N25150G1X130.175Y-21.065
N25160G1X132.548Y-20.692
N25170G1X132.609Y-21.038
N25180G1X132.693Y-21.364
N25190G1X132.798Y-21.668
N25200G1X132.926Y-21.952
N25210G1X133.076Y-22.215
N25220G1X133.249Y-22.457
N25230G1X133.444Y-22.678
N25240G1X133.661Y-22.878
N25250G1X133.901Y-23.056
N25260G1X134.163Y-23.210
N25270G1X134.448Y-23.341
N25280G1X134.756Y-23.448
N25290G1X135.086Y-23.531
N25300G1X135.439Y-23.590
N25310G1X135.815Y-23.626
N25320G1X136.213Y-23.638
N25330G1X136.613Y-23.627
N25340G1X136.986Y-23.596
N25350G1X137.333Y-23.543
N25360G1X137.653Y-23.470
N25370G1X137.946Y-23.375
N25380G1X138.213Y-23.259
N25390G1X138.453Y-23.122
N25400G1X138.666Y-22.965
N25410G1X138.853Y-22.793
N25420G1X139.016Y-22.614
N25430G1X139.153Y-22.427
N25440G1X139.266Y-22.233
N25450G1X139.353Y-22.032
N25460G1X139.416Y-21.824
N25470G1X139.453Y-21.608
N25480G1X139.466Y-21.385
N25490G1X139.455Y-21.187
N25500G1X139.421Y-21.000
N25510G1X139.366Y-20.824
N25520G1X139.289Y-20.659
N25530G1X139.190Y-20.504
N25540G1X139.068Y-20.361
N25550G1X138.925Y-20.228
N25560G1X138.759Y-20.106
N25570G1X138.613Y-20.023
N25580G1X138.421Y-19.935
N25590G1X137.899Y-19.742
N25600G1X137.195Y-19.528
N25610G1X136.307Y-19.293
N25620G1X135.088Y-18.971
N25630G1X134.072Y-18.671
N25640G1X133.259Y-18.394
N25650G1X132.648Y-18.140
N25660G1X132.401Y-18.012
N25670G1X132.169Y-17.873
N25680G1X131.953Y-17.722
N25690G1X131.752Y-17.560
N25700G1X131.566Y-17.386
N25710G1X131.396Y-17.200
N25720G1X131.241Y-17.003
N25730G1X131.102Y-16.793
N25740G1X130.978Y-16.576
N25750G1X130.871Y-16.352
N25760G1X130.781Y-16.123
N25770G1X130.707Y-15.889
N25780G1X130.649Y-15.649
N25790G1X130.608Y-15.403
N25800G1X130.584Y-15.151
N25810G1X130.575Y-14.894
N25820G1X130.602Y-14.430
N25830G1X130.684Y-13.983
N25840G1X130.819Y-13.553
N25850G1X131.008Y-13.141
N25860G1X131.245Y-12.755
N25870G1X131.520Y-12.403
N25880G1X131.834Y-12.086
N25890G1X132.188Y-11.802
N25900G1X132.493Y-11.603
N25910G1X132.850Y-11.420
N25920G1X133.256Y-11.253
N25930G1X133.714Y-11.102
N25940G1X134.206Y-10.977
N25950G1X134.716Y-10.887
N25960G1X135.242Y-10.833
N25970G1X135.787Y-10.816
N25980G1X136.197Y-10.823
N25990G1X136.594Y-10.846
N26000G1X136.979Y-10.883
N26010G1X137.351Y-10.935
N26020G1X137.711Y-11.003
N26030G1X138.057Y-11.085
N26040G1X138.391Y-11.183
N26050G1X138.713Y-11.295
N26060G1X139.017Y-11.421
N26070G1X139.301Y-11.557
N26080G1X139.564Y-11.703
N26090G1X139.807Y-11.860
N26100G1X140.029Y-12.028
N26110G1X140.231Y-12.206
N26120G1X140.412Y-12.395
N26130G1X140.572Y-12.595
N26140G1X140.716Y-12.809
N26150G1X140.848Y-13.039
N26160G1X140.969Y-13.288
N26170G1X141.078Y-13.553
N26180G1X141.176Y-13.836
N26190G1X141.262Y-14.136
N26200G1X141.398Y-14.788
N26210G1X139.052Y-15.107
N26220G1X139.003Y-14.842
N26230G1X138.935Y-14.591
N26240G1X138.847Y-14.355
N26250G1X138.741Y-14.134
N26260G1X138.616Y-13.929
N26270G1X138.471Y-13.738
N26280G1X138.308Y-13.562
N26290G1X138.126Y-13.401
N26300G1X137.925Y-13.258
N26310G1X137.703Y-13.133
N26320G1X137.462Y-13.028
N26330G1X137.201Y-12.941
N26340G1X136.921Y-12.874
N26350G1X136.620Y-12.827
N26360G1X136.300Y-12.798
N26370G1X135.960Y-12.788
N26380G1X135.562Y-12.797
N26390G1X135.193Y-12.822
N26400G1X134.854Y-12.865
N26410G1X134.544Y-12.925
N26420G1X134.264Y-13.002
N26430G1X134.013Y-13.096
N26440G1X133.792Y-13.207
N26450G1X133.601Y-13.335
N26460G1X133.435Y-13.474
N26470G1X133.292Y-13.620
N26480G1X133.170Y-13.771
N26490G1X133.071Y-13.928
N26500G1X132.994Y-14.091
N26510G1X132.939Y-14.259
N26520G1X132.906Y-14.434
N26530G1X132.895Y-14.614
N26540G1X132.913Y-14.842
N26550G1X132.968Y-15.057
N26560G1X133.059Y-15.262
N26570G1X133.188Y-15.454
N26580G1X133.355Y-15.639
N26590G1X133.564Y-15.807
N26600G1X133.815Y-15.959
N26610G1X134.107Y-16.094
N26620G1X134.817Y-16.314
N26630G1X136.227Y-16.707
N26640G1X137.403Y-17.031
N26650G1X138.388Y-17.325
N26660G1X139.179Y-17.588
N26670G1X139.779Y-17.820
N26680G1X140.024Y-17.934
N26690G1X140.255Y-18.061
N26700G1X140.473Y-18.200
N26710G1X140.677Y-18.351
N26720G1X140.868Y-18.515
N26730G1X141.045Y-18.691
N26740G1X141.208Y-18.879
N26750G1X141.358Y-19.079
N26760G1X141.493Y-19.292
N26770G1X141.609Y-19.518
N26780G1X141.708Y-19.755
N26790G1X141.788Y-20.006
N26800G1X141.851Y-20.269
N26810G1X141.896Y-20.544
N26820G1X141.922Y-20.832
N26830G1X141.931Y-21.132
N26840G1X141.921Y-21.430
N26850G1X141.888Y-21.723
N26860G1X141.833Y-22.012
N26870G1X141.757Y-22.297
N26880G1X141.658Y-22.577
N26890G1X141.538Y-22.853
N26900G1X141.396Y-23.124
N26910G1X141.232Y-23.391
N26920G1X141.047Y-23.649
N26930G1X140.843Y-23.891
N26940G1X140.620Y-24.118
N26950G1X140.377Y-24.331
N26960G1X140.115Y-24.528
N26970G1X139.833Y-24.711
N26980G1X139.533Y-24.878
N26990G1X139.212Y-25.031
N27000G1X138.877Y-25.167
N27010G1X138.531Y-25.284
N27020G1X138.174Y-25.384
N27030G1X137.806Y-25.466
N27040G1X137.428Y-25.529
N27050G1X137.038Y-25.574
N27060G1X136.638Y-25.601
N27070G1X136.227Y-25.610
N27080G1X135.557Y-25.593
N27090G1X134.929Y-25.539
N27100G1X134.342Y-25.449
N27110G1X133.796Y-25.324
N27120G1X133.291Y-25.163
N27130G1X132.827Y-24.966
N27140G1X132.404Y-24.733
N27150G1X132.021Y-24.464
N27160G1X131.676Y-24.160
N27170G1X131.364Y-23.822
N27180G1X131.084Y-23.449
N27190G1X130.837Y-23.041
N27200G00Z5.999
N27210G00X127.483Y-8.510
N27220G1Z-1.000F1200.0
N27230G1X125.084F3600.0
N27240G1Y-5.751
N27250G1X127.483
N27260G1Y-8.510
N27270G00Z5.999
N27280G00X111.593Y-14.970
N27290G1Z-1.000F1200.0
N27300G1X111.452Y-14.677F3600.0
N27310G1X111.293Y-14.412
N27320G1X111.115Y-14.174
N27330G1X110.818Y-13.850
N27340G1X110.500Y-13.568
N27350G1X110.160Y-13.330
N27360G1X109.799Y-13.135
N27370G1X109.417Y-12.983
N27380G1X109.013Y-12.875
N27390G1X108.589Y-12.810
N27400G1X108.143Y-12.788
N27410G1X107.738Y-12.805
N27420G1X107.349Y-12.857
N27430G1X106.977Y-12.944
N27440G1X106.622Y-13.065
N27450G1X106.283Y-13.220
N27460G1X105.960Y-13.410
N27470G1X105.654Y-13.635
N27480G1X105.364Y-13.894
N27490G1X105.098Y-14.183
N27500G1X104.864Y-14.494
N27510G1X104.661Y-14.829
N27520G1X104.489Y-15.187
N27530G1X104.349Y-15.569
N27540G1X104.241Y-15.974
N27550G1X104.163Y-16.402
N27560G1X104.118Y-16.853
N27570G1X112.022
N27580G1X111.972Y-16.421
N27590G1X111.905Y-16.016
N27600G1X111.819Y-15.640
N27610G1X111.715Y-15.291
N27620G1X111.593Y-14.970
N27630G00Z5.999
N27640G00X113.542Y-13.813
N27650G1Z-1.000F1200.0
N27660G1X113.704Y-14.110F3600.0
N27670G1X113.851Y-14.419
N27680G1X113.985Y-14.740
N27690G1X114.104Y-15.074
N27700G1X114.210Y-15.420
N27710G1X114.301Y-15.778
N27720G1X114.378Y-16.149
N27730G1X114.442Y-16.532
N27740G1X114.491Y-16.927
N27750G1X114.526Y-17.335
N27760G1X114.554Y-18.186
N27770G1X114.541Y-18.826
N27780G1X103.984
N27790G1X104.034Y-19.392
N27800G1X104.117Y-19.924
N27810G1X104.232Y-20.422
N27820G1X104.381Y-20.885
N27830G1X104.562Y-21.315
N27840G1X104.777Y-21.710
N27850G1X105.024Y-22.071
N27860G1X105.304Y-22.398
N27870G1X105.610Y-22.689
N27880G1X105.934Y-22.941
N27890G1X106.276Y-23.154
N27900G1X106.637Y-23.328
N27910G1X107.016Y-23.464
N27920G1X107.413Y-23.560
N27930G1X107.829Y-23.618
N27940G1X108.263Y-23.638
N27950G1X108.587Y-23.627
N27960G1X108.899Y-23.595
N27970G1X109.198Y-23.540
N27980G1X109.486Y-23.465
N27990G1X109.761Y-23.367
N28000G1X110.025Y-23.248
N28010G1X110.276Y-23.107
N28020G1X110.515Y-22.945
N28030G1X110.743Y-22.759
N28040G1X110.958Y-22.547
N28050G1X111.161Y-22.309
N28060G1X111.352Y-22.045
N28070G1X111.531Y-21.756
N28080G1X111.698Y-21.440
N28090G1X111.852Y-21.099
N28100G1X111.995Y-20.732
N28110G1X114.474Y-21.039
N28120G1X114.312Y-21.567
N28130G1X114.118Y-22.064
N28140G1X113.894Y-22.531
N28150G1X113.638Y-22.968
N28160G1X113.351Y-23.374
N28170G1X113.032Y-23.750
N28180G1X112.682Y-24.096
N28190G1X112.302Y-24.411
N28200G1X111.891Y-24.692
N28210G1X111.453Y-24.936
N28220G1X110.988Y-25.142
N28230G1X110.495Y-25.311
N28240G1X109.975Y-25.442
N28250G1X109.428Y-25.536
N28260G1X108.852Y-25.592
N28270G1X108.250Y-25.610
N28280G1X107.866Y-25.603
N28290G1X107.493Y-25.581
N28300G1X107.130Y-25.543
N28310G1X106.777Y-25.491
N28320G1X106.434Y-25.424
N28330G1X106.101Y-25.342
N28340G1X105.778Y-25.244
N28350G1X105.466Y-25.132
N28360G1X105.163Y-25.005
N28370G1X104.870Y-24.863
N28380G1X104.587Y-24.706
N28390G1X104.315Y-24.535
N28400G1X104.052Y-24.348
N28410G1X103.800Y-24.146
N28420G1X103.557Y-23.929
N28430G1X103.325Y-23.698
N28440G1X103.104Y-23.453
N28450G1X102.898Y-23.196
N28460G1X102.706Y-22.926
N28470G1X102.529Y-22.645
N28480G1X102.365Y-22.352
N28490G1X102.216Y-22.047
N28500G1X102.081Y-21.730
N28510G1X101.960Y-21.400
N28520G1X101.853Y-21.059
N28530G1X101.761Y-20.706
N28540G1X101.683Y-20.340
N28550G1X101.619Y-19.963
N28560G1X101.569Y-19.573
N28570G1X101.534Y-19.172
N28580G1X101.505Y-18.333
N28590G1X101.534Y-17.465
N28600G1X101.570Y-17.050
N28610G1X101.620Y-16.647
N28620G1X101.685Y-16.257
N28630G1X101.764Y-15.879
N28640G1X101.857Y-15.514
N28650G1X101.965Y-15.161
N28660G1X102.087Y-14.820
N28670G1X102.224Y-14.493
N28680G1X102.375Y-14.177
N28690G1X102.540Y-13.874
N28700G1X102.719Y-13.584
N28710G1X102.913Y-13.306
N28720G1X103.122Y-13.041
N28730G1X103.345Y-12.788
N28740G1X103.579Y-12.549
N28750G1X103.822Y-12.326
N28760G1X104.073Y-12.118
N28770G1X104.333Y-11.925
N28780G1X104.601Y-11.748
N28790G1X104.878Y-11.586
N28800G1X105.163Y-11.440
N28810G1X105.457Y-11.309
N28820G1X105.760Y-11.193
N28830G1X106.071Y-11.093
N28840G1X106.390Y-11.008
N28850G1X106.718Y-10.939
N28860G1X107.055Y-10.885
N28870G1X107.400Y-10.846
N28880G1X107.754Y-10.823
N28890G1X108.116Y-10.816
N28900G1X108.467Y-10.823
N28910G1X108.810Y-10.846
N28920G1X109.144Y-10.883
N28930G1X109.471Y-10.936
N28940G1X109.789Y-11.004
N28950G1X110.099Y-11.087
N28960G1X110.401Y-11.185
N28970G1X110.695Y-11.299
N28980G1X110.981Y-11.427
N28990G1X111.259Y-11.570
N29000G1X111.529Y-11.729
N29010G1X111.790Y-11.903
N29020G1X112.043Y-12.091
N29030G1X112.289Y-12.295
N29040G1X112.526Y-12.514
N29050G1X112.755Y-12.748
N29060G1X112.973Y-12.996
N29070G1X113.176Y-13.256
N29080G1X113.366Y-13.528
N29090G1X113.542Y-13.813
N29100G00Z5.999
N29110G00X98.728Y-14.987
N29120G1Z-1.000F1200.0
N29130G1X98.746Y-15.574F3600.0
N29140G1Y-25.291
N29150G1X96.360
N29160G1Y-16.374
N29170G1X96.346Y-15.704
N29180G1X96.302Y-15.136
N29190G1X96.229Y-14.668
N29200G1X96.127Y-14.301
N29210G1X95.987Y-14.000
N29220G1X95.799Y-13.730
N29230G1X95.564Y-13.490
N29240G1X95.281Y-13.281
N29250G1X94.961Y-13.112
N29260G1X94.614Y-12.991
N29270G1X94.241Y-12.919
N29280G1X93.841Y-12.895
N29290G1X93.476Y-12.910
N29300G1X93.126Y-12.957
N29310G1X92.793Y-13.034
N29320G1X92.475Y-13.143
N29330G1X92.173Y-13.283
N29340G1X91.887Y-13.453
N29350G1X91.617Y-13.655
N29360G1X91.362Y-13.888
N29370G1X91.131Y-14.155
N29380G1X90.931Y-14.459
N29390G1X90.761Y-14.800
N29400G1X90.622Y-15.179
N29410G1X90.514Y-15.595
N29420G1X90.437Y-16.048
N29430G1X90.391Y-16.539
N29440G1X90.376Y-17.067
N29450G1Y-25.291
N29460G1X87.977
N29470G1Y-16.094
N29480G1X87.967Y-15.706
N29490G1X87.940Y-15.344
N29500G1X87.894Y-15.007
N29510G1X87.830Y-14.694
N29520G1X87.747Y-14.407
N29530G1X87.647Y-14.144
N29540G1X87.527Y-13.907
N29550G1X87.390Y-13.695
N29560G1X87.232Y-13.507
N29570G1X87.050Y-13.345
N29580G1X86.845Y-13.207
N29590G1X86.617Y-13.095
N29600G1X86.365Y-13.007
N29610G1X86.090Y-12.945
N29620G1X85.792Y-12.907
N29630G1X85.471Y-12.895
N29640G1X85.220Y-12.903
N29650G1X84.974Y-12.928
N29660G1X84.733Y-12.970
N29670G1X84.496Y-13.028
N29680G1X84.264Y-13.103
N29690G1X84.037Y-13.195
N29700G1X83.815Y-13.303
N29710G1X83.598Y-13.428
N29720G1X83.390Y-13.569
N29730G1X83.198Y-13.725
N29740G1X83.020Y-13.897
N29750G1X82.857Y-14.084
N29760G1X82.708Y-14.287
N29770G1X82.575Y-14.505
N29780G1X82.456Y-14.739
N29790G1X82.352Y-14.987
N29800G1X82.261Y-15.258
N29810G1X82.183Y-15.557
N29820G1X82.116Y-15.885
N29830G1X82.062Y-16.240
N29840G1X81.989Y-17.037
N29850G1X81.965Y-17.946
N29860G1Y-25.291
N29870G1X79.566
N29880G1Y-11.135
N29890G1X81.712
N29900G1Y-13.121
N29910G1X81.885Y-12.868
N29920G1X82.073Y-12.627
N29930G1X82.274Y-12.399
N29940G1X82.488Y-12.183
N29950G1X82.717Y-11.981
N29960G1X82.959Y-11.791
N29970G1X83.215Y-11.613
N29980G1X83.485Y-11.449
N29990G1X83.766Y-11.300
N30000G1X84.057Y-11.172
N30010G1X84.358Y-11.063
N30020G1X84.668Y-10.974
N30030G1X84.987Y-10.905
N30040G1X85.317Y-10.855
N30050G1X85.655Y-10.825
N30060G1X86.004Y-10.816
N30070G1X86.388Y-10.826
N30080G1X86.755Y-10.856
N30090G1X87.104Y-10.907
N30100G1X87.435Y-10.979
N30110G1X87.749Y-11.071
N30120G1X88.044Y-11.183
N30130G1X88.323Y-11.316
N30140G1X88.583Y-11.469
N30150G1X88.825Y-11.640
N30160G1X89.049Y-11.828
N30170G1X89.254Y-12.032
N30180G1X89.441Y-12.252
N30190G1X89.609Y-12.488
N30200G1X89.759Y-12.741
N30210G1X89.890Y-13.010
N30220G1X90.002Y-13.295
N30230G1X90.216Y-12.994
N30240G1X90.438Y-12.714
N30250G1X90.668Y-12.452
N30260G1X90.906Y-12.210
N30270G1X91.151Y-11.987
N30280G1X91.405Y-11.784
N30290G1X91.666Y-11.600
N30300G1X91.935Y-11.435
N30310G1X92.212Y-11.290
N30320G1X92.497Y-11.164
N30330G1X92.790Y-11.058
N30340G1X93.091Y-10.970
N30350G1X93.400Y-10.903
N30360G1X93.717Y-10.854
N30370G1X94.042Y-10.825
N30380G1X94.374Y-10.816
N30390G1X94.886Y-10.834
N30400G1X95.366Y-10.888
N30410G1X95.817Y-10.980
N30420G1X96.237Y-11.107
N30430G1X96.627Y-11.271
N30440G1X96.986Y-11.472
N30450G1X97.315Y-11.708
N30460G1X97.613Y-11.982
N30470G1X97.879Y-12.293
N30480G1X98.109Y-12.644
N30490G1X98.304Y-13.034
N30500G1X98.463Y-13.463
N30510G1X98.587Y-13.932
N30520G1X98.675Y-14.440
N30530G1X98.728Y-14.987
N30540G00Z5.999
N30550G00X73.421Y-18.186
N30560G1Z-1.000F1200.0
N30570G1X73.075Y-18.317F3600.0
N30580G1X72.687Y-18.443
N30590G1X72.258Y-18.564
N30600G1X71.789Y-18.680
N30610G1X70.727Y-18.896
N30620G1X69.503Y-19.093
N30630G1X68.817Y-19.203
N30640G1X68.240Y-19.319
N30650G1X67.771Y-19.443
N30660G1X67.410Y-19.573
N30670G1X67.121Y-19.721
N30680G1X66.867Y-19.901
N30690G1X66.648Y-20.111
N30700G1X66.464Y-20.352
N30710G1X66.318Y-20.616
N30720G1X66.214Y-20.894
N30730G1X66.151Y-21.186
N30740G1X66.131Y-21.492
N30750G1X66.142Y-21.727
N30760G1X66.176Y-21.952
N30770G1X66.233Y-22.167
N30780G1X66.312Y-22.372
N30790G1X66.414Y-22.567
N30800G1X66.539Y-22.751
N30810G1X66.687Y-22.926
N30820G1X66.857Y-23.091
N30830G1X67.049Y-23.241
N30840G1X67.262Y-23.371
N30850G1X67.497Y-23.481
N30860G1X67.752Y-23.571
N30870G1X68.028Y-23.641
N30880G1X68.325Y-23.691
N30890G1X68.644Y-23.721
N30900G1X68.983Y-23.731
N30910G1X69.325Y-23.722
N30920G1X69.657Y-23.693
N30930G1X69.980Y-23.646
N30940G1X70.293Y-23.580
N30950G1X70.596Y-23.494
N30960G1X70.890Y-23.390
N30970G1X71.174Y-23.267
N30980G1X71.449Y-23.125
N30990G1X71.710Y-22.966
N31000G1X71.953Y-22.794
N31010G1X72.178Y-22.607
N31020G1X72.385Y-22.407
N31030G1X72.574Y-22.192
N31040G1X72.746Y-21.964
N31050G1X72.899Y-21.722
N31060G1X73.035Y-21.465
N31070G1X73.126Y-21.250
N31080G1X73.204Y-21.010
N31090G1X73.270Y-20.747
N31100G1X73.325Y-20.459
N31110G1X73.397Y-19.811
N31120G1X73.421Y-19.066
N31130G1Y-18.186
N31140G00Z5.999
N31150G00X73.054Y-16.425
N31160G1Z-1.000F1200.0
N31170G1X73.421Y-16.307F3600.0
N31180G1X73.435Y-15.681
N31190G1X73.424Y-15.328
N31200G1X73.392Y-15.002
N31210G1X73.339Y-14.703
N31220G1X73.265Y-14.431
N31230G1X73.169Y-14.186
N31240G1X73.052Y-13.969
N31250G1X72.914Y-13.778
N31260G1X72.755Y-13.615
N31270G1X72.511Y-13.424
N31280G1X72.239Y-13.259
N31290G1X71.940Y-13.119
N31300G1X71.612Y-13.005
N31310G1X71.257Y-12.916
N31320G1X70.873Y-12.852
N31330G1X70.462Y-12.814
N31340G1X70.023Y-12.802
N31350G1X69.613Y-12.811
N31360G1X69.232Y-12.839
N31370G1X68.878Y-12.885
N31380G1X68.551Y-12.950
N31390G1X68.253Y-13.033
N31400G1X67.982Y-13.135
N31410G1X67.739Y-13.256
N31420G1X67.523Y-13.395
N31430G1X67.328Y-13.557
N31440G1X67.147Y-13.748
N31450G1X66.978Y-13.968
N31460G1X66.822Y-14.216
N31470G1X66.680Y-14.493
N31480G1X66.550Y-14.798
N31490G1X66.434Y-15.132
N31500G1X66.331Y-15.494
N31510G1X63.985Y-15.174
N31520G1X64.071Y-14.807
N31530G1X64.170Y-14.457
N31540G1X64.283Y-14.126
N31550G1X64.408Y-13.813
N31560G1X64.546Y-13.518
N31570G1X64.697Y-13.241
N31580G1X64.861Y-12.982
N31590G1X65.038Y-12.742
N31600G1X65.231Y-12.517
N31610G1X65.445Y-12.305
N31620G1X65.679Y-12.107
N31630G1X65.934Y-11.922
N31640G1X66.209Y-11.750
N31650G1X66.505Y-11.592
N31660G1X66.821Y-11.447
N31670G1X67.157Y-11.315
N31680G1X67.510Y-11.198
N31690G1X67.878Y-11.097
N31700G1X68.258Y-11.011
N31710G1X68.653Y-10.940
N31720G1X69.062Y-10.886
N31730G1X69.484Y-10.847
N31740G1X69.920Y-10.823
N31750G1X70.369Y-10.816
N31760G1X71.233Y-10.842
N31770G1X71.633Y-10.876
N31780G1X72.012Y-10.922
N31790G1X72.370Y-10.982
N31800G1X72.706Y-11.055
N31810G1X73.021Y-11.142
N31820G1X73.315Y-11.242
N31830G1X73.844Y-11.469
N31840G1X74.080Y-11.593
N31850G1X74.298Y-11.724
N31860G1X74.497Y-11.861
N31870G1X74.677Y-12.006
N31880G1X74.838Y-12.157
N31890G1X74.981Y-12.315
N31900G1X75.228Y-12.659
N31910G1X75.434Y-13.046
N31920G1X75.601Y-13.476
N31930G1X75.727Y-13.948
N31940G1X75.780Y-14.316
N31950G1X75.817Y-14.808
N31960G1X75.840Y-15.422
N31970G1X75.847Y-16.160
N31980G1Y-19.359
N31990G1X75.857Y-20.878
N32000G1X75.886Y-22.090
N32010G1X75.934Y-22.994
N32020G1X76.001Y-23.591
N32030G1X76.096Y-24.030
N32040G1X76.229Y-24.459
N32050G1X76.399Y-24.879
N32060G1X76.607Y-25.291
N32070G1X74.101
N32080G1X73.931Y-24.902
N32090G1X73.795Y-24.481
N32100G1X73.691Y-24.029
N32110G1X73.621Y-23.545
N32120G1X72.961Y-24.069
N32130G1X72.636Y-24.301
N32140G1X72.314Y-24.511
N32150G1X71.994Y-24.700
N32160G1X71.678Y-24.869
N32170G1X71.365Y-25.017
N32180G1X71.056Y-25.144
N32190G1X70.745Y-25.253
N32200G1X70.428Y-25.348
N32210G1X70.106Y-25.428
N32220G1X69.778Y-25.494
N32230G1X69.444Y-25.545
N32240G1X69.105Y-25.581
N32250G1X68.410Y-25.610
N32260G1X67.844Y-25.593
N32270G1X67.311Y-25.539
N32280G1X66.812Y-25.450
N32290G1X66.347Y-25.326
N32300G1X65.916Y-25.165
N32310G1X65.518Y-24.969
N32320G1X65.155Y-24.738
N32330G1X64.824Y-24.471
N32340G1X64.531Y-24.176
N32350G1X64.276Y-23.862
N32360G1X64.061Y-23.527
N32370G1X63.885Y-23.173
N32380G1X63.748Y-22.799
N32390G1X63.650Y-22.405
N32400G1X63.591Y-21.992
N32410G1X63.572Y-21.559
N32420G1X63.579Y-21.301
N32430G1X63.601Y-21.050
N32440G1X63.638Y-20.804
N32450G1X63.690Y-20.564
N32460G1X63.756Y-20.329
N32470G1X63.838Y-20.100
N32480G1X63.934Y-19.877
N32490G1X64.045Y-19.659
N32500G1X64.300Y-19.251
N32510G1X64.591Y-18.884
N32520G1X64.919Y-18.561
N32530G1X65.284Y-18.280
N32540G1X65.680Y-18.036
N32550G1X66.099Y-17.823
N32560G1X66.543Y-17.642
N32570G1X67.010Y-17.493
N32580G1X67.409Y-17.401
N32590G1X67.897Y-17.310
N32600G1X69.143Y-17.133
N32610G1X70.500Y-16.952
N32620G1X71.665Y-16.754
N32630G1X72.639Y-16.539
N32640G1X73.054Y-16.425
N32650G00Z5.999
N32660G00X60.706Y-16.587
N32670G1Z-1.000F1200.0
N32680G1Y-25.291F3600.0
N32690G1X58.307
N32700G1Y-16.680
N32710G1X58.289Y-15.993
N32720G1X58.237Y-15.399
N32730G1X58.149Y-14.897
N32740G1X58.027Y-14.488
N32750G1X57.950Y-14.311
N32760G1X57.860Y-14.143
N32770G1X57.756Y-13.984
N32780G1X57.639Y-13.835
N32790G1X57.508Y-13.694
N32800G1X57.363Y-13.563
N32810G1X57.205Y-13.441
N32820G1X57.034Y-13.328
N32830G1X56.852Y-13.226
N32840G1X56.662Y-13.138
N32850G1X56.464Y-13.064
N32860G1X56.259Y-13.003
N32870G1X55.825Y-12.922
N32880G1X55.361Y-12.895
N32890G1X54.984Y-12.910
N32900G1X54.621Y-12.956
N32910G1X54.270Y-13.032
N32920G1X53.933Y-13.138
N32930G1X53.609Y-13.275
N32940G1X53.298Y-13.442
N32950G1X53.000Y-13.640
N32960G1X52.715Y-13.868
N32970G1X52.580Y-13.996
N32980G1X52.454Y-14.138
N32990G1X52.228Y-14.463
N33000G1X52.037Y-14.843
N33010G1X51.880Y-15.277
N33020G1X51.759Y-15.766
N33030G1X51.672Y-16.309
N33040G1X51.620Y-16.907
N33050G1X51.602Y-17.560
N33060G1Y-25.291
N33070G1X49.203
N33080G1Y-11.135
N33090G1X51.362
N33100G1Y-13.148
N33110G1X51.563Y-12.866
N33120G1X51.774Y-12.601
N33130G1X51.996Y-12.355
N33140G1X52.229Y-12.128
N33150G1X52.472Y-11.918
N33160G1X52.727Y-11.727
N33170G1X52.992Y-11.554
N33180G1X53.268Y-11.399
N33190G1X53.555Y-11.262
N33200G1X53.853Y-11.144
N33210G1X54.162Y-11.043
N33220G1X54.481Y-10.961
N33230G1X54.812Y-10.898
N33240G1X55.153Y-10.852
N33250G1X55.505Y-10.825
N33260G1X55.867Y-10.816
N33270G1X56.494Y-10.844
N33280G1X56.798Y-10.880
N33290G1X57.095Y-10.930
N33300G1X57.386Y-10.995
N33310G1X57.671Y-11.074
N33320G1X57.949Y-11.168
N33330G1X58.220Y-11.275
N33340G1X58.480Y-11.395
N33350G1X58.723Y-11.523
N33360G1X58.949Y-11.661
N33370G1X59.158Y-11.807
N33380G1X59.350Y-11.962
N33390G1X59.526Y-12.126
N33400G1X59.684Y-12.300
N33410G1X59.826Y-12.482
N33420G1X60.073Y-12.872
N33430G1X60.279Y-13.298
N33440G1X60.446Y-13.759
N33450G1X60.573Y-14.254
N33460G1X60.631Y-14.650
N33470G1X60.672Y-15.171
N33480G1X60.697Y-15.816
N33490G1X60.706Y-16.587
N33500G00Z5.999
N33510G00X12.602Y-46.323
N33520G1Z-1.000F1200.0
N33530G1Y-48.736F3600.0
N33540G1X5.231
N33550G1Y-46.323
N33560G1X12.602
N33570G00Z5.999
N33580G00Z20.000
N33590G00X0.000Y0.000
N33600M09
N33610M30
---------------Last edited by marbles; 28-04-2015 at 11:38 PM.
29-04-2015 #9
Your simply trying to go too fast for such small text with CV mode. 3600mm/min is way too fast for this size txt.
No way can a constant velocity be maintained at this feedrate on such small radius. You could try exact stop mode by typing G61 in the MDI before running code but it will shake the machine around.
You can play with the CV settings and increasing look ahead to get better but you won't get it to maintain travel at these feedrates in CV mode without rounding it's just not possible.!!
Unfortunately you will have to slow things down. I'd also increase accelleration in motor tuning as 100 is quite low.
Often with moves that are short like engraving etc your better lowering velocity and increasing accelleration in motor tuning. Often this lowers cycle times on small move work.?
Reason for this becomes obvious when you think about how each move or direction change works.?
Every move as to accelerate to commanded feedrate, travel at this feedrate then de-accelerate all before the next direction change happens.
Now on long moves it's no problem hitting the commanded feedrate even if high has we have plenty of time before the next move happens.
On short moves the time interval between moves comes very quickly and no way can high commanded feedrate be reached before having to slow down for next move so some speed clipping occurs. On large jobs like 3D work this clipping can amount to large time increase in cycle times.
Think of it like a race traffic light to traffic light between a F1 car tuned for speed and Bus tuned for stop to stop. When lights are streets apart then no problem F1 car wins every time but put the lights every kerb stone apart and Bus will smoke it.!!
Same thing happening here.!! No matter what you command the feed to be in G-code the machine can only go so fast before having to slow down again.
The feedrate reached will depend on the motor tuning but in general with higher acceleration the machine will produce shorter cycle times as it can reach a higher feed before slowing down again for next move or direction change.
CV is like trying to go around corners without slowing down. This is impossible in tight corners so rounding occurs, how much depends on the CV setting. With high feedrates then even when CV settings are dialed in good for best balance rounding will occur if feeds are set too high.
Edit: Oh and your G-code doesn't help matters by creating arcs with tiny lines. Try using a post processor that uses (i) (j) Arc moves instead of breaking each arc into tiny straight lines. Could also be a setting in the Cam software.?Last edited by JAZZCNC; 29-04-2015 at 07:36 AM.
29-04-2015 #10
Dean. You took the words right out of my mouth I was just about to say all that. ..Clive
the mystery of the wonky corners
By kingcreaky in forum Machine DiscussionReplies: 19Last Post: 06-05-2014, 03:58 PM -
pulley center distance vs. belt tension
By dsc in forum Belt Drive, Pulleys & TimingReplies: 5Last Post: 13-01-2014, 10:48 PM -
RFQ: Mdf Cuts for CNC frame.
By mZeles in forum Projects, Jobs & RequestsReplies: 0Last Post: 12-03-2013, 04:41 PM -
Adding a 'Park Mode' to a cnc router?
By routercnc in forum Computer SoftwareReplies: 5Last Post: 18-06-2010, 06:10 PM
