Thread: Coolant Pump
Page 3 of 3 FirstFirst 123
  1. #21
    Quote Originally Posted by jamesgates1000 View Post
    I haven't but I will put all the dimensions on here when I get my tray back. It had obviously been left with coolant in it for some time before I bought it, all the water had evaporated off and the oil stripped the paint from the bottom of the tank. It is at the local bodyshop being stripped and powder coated.
    Ah OK. Not a biggie, will take me a few mins to measure.
  2. #22
    Ok, measured.
    The HP of the coolant motor is only 0.08 HP. Lol.
    Height from the mounting flange to the pump suction area - 150mm.
    Hole in Coolant Tank - 90mm.
    Distance between mounting hole centres - 115mm.
    Do you have some dimensions of your pump?
  3. #23
    Hi Chaz,
    Just got my tank back so assembled it at the weekend. My dimensions are the same as yours, my pump is a sacemi IMM50A also 0.08hp.
    This looks like a good replacement...
    http://www.pumpsalesdirect.co.uk/spv...170mm-3ph.html
    Would just need to make up a 20mm spacer to mount on.
    They also sell a single phase version.
  4. #24
    Hi Chaz,
  1. Coolant, I am not sure which one to go with.
    By suesi34e in forum Swarf & Chip Management
    Last Post: 17-10-2015, 07:13 PM
  2. My Coolant System
    By Tenson in forum Swarf & Chip Management
    Last Post: 08-04-2013, 01:59 PM
  3. Washing Machine Pump Coolant System
    By Lee Roberts in forum Electronic Project Building
    Last Post: 05-05-2012, 01:30 AM
  4. coolant
    By luke11cnc in forum Machine Discussion
    Last Post: 11-02-2012, 01:17 PM
  5. What coolant to use??
    By don_jarr in forum General Discussion
    Last Post: 05-11-2011, 03:12 PM
