    I took an interest in the thread about mist cooling and I thought that a stepper driven pump, controlled by an Arduino, together with a solenoid operated air valve could give a system that would dispense air, liquid or a mist (with control of the liquid content) using a mister spray as in pic 4
    The easiest pump to control liquid flow would be a peristaltic type, so I set about making one with my 3D printer. Most of the other hardware I needed, I had already (Nema23 stepper motor, Parker Digiplan PK2 drive, bearings, nuts and bolts), I just needed some flexible silicone tubing and though I only needed a foot of it, 5 metres of 8x6mm tube cost £6.29 from China, so I bought it.
    The bits were drawn in Retchup and sliced with Makerbot. I printed in ABS with 100% infill to give it strength. There were several revisions, in order to get the pump working better and I ended up putting 'tyres' on the bearings to spread the pressure across the width of the tube.
    I am pleased with the result as it pumps strongly, self primes and has no back flow (though you can run it backwards easily enough with a stepper).
    The last picture is two tubes joined with '5secondFIX', it works well ! It cost $4.50 from China (or you can buy the JML equivalent for £9.99).
    If anyone is interested, I can post the stl files and a parts list. AND I have lots of the silicone tube left over.
    Cheers and goodnight (or more accurately - Good Morning !)
    Rob
ID:	19313Click image for larger version.
Name:	pump build.jpg
ID:	19314Click image for larger version.
ID:	19315Click image for larger version.
ID:	19316Click image for larger version.
  2. The Following User Says Thank You to cropwell For This Useful Post:
  1. 3D printed Homes and Limits bracket
    By cropwell in forum 3D Printing Machines
    Last Post: 16-03-2016, 11:32 PM
  2. 3D Printed Pop Pop Boat
    By TheGoodGuy in forum 3D Printing Machines
    Last Post: 09-07-2015, 11:40 AM
  3. 3D Printed NASA Ratchet - Video
    By Lee Roberts in forum 3D Printing Machines
    Last Post: 23-01-2015, 09:58 PM
  4. Printed Circuit Boards manufacturer
    By stirling in forum General Electronics
    Last Post: 06-06-2012, 06:53 PM
  5. Milling Printed Circuit Boards - How To
    By Lee Roberts in forum Electronic Project Building
    Last Post: 28-08-2008, 11:25 PM
