Hi
I would like to present you the 2nd version of desktop size router designed by myself in SW.
Hoping to mill aluminium as hardest material.
Parameters:
Working area 320x250x100mm (X.Y.Z)
Hiwin, HSR or THK 15mm blocks on Z
Hiwin, HSR or THK 15 or 20mm blocks on X
Hiwin, HSR or THK 15mm blocks on Y
3A steppers (8 cables bipolar parallel) Nema 23
Ballscre RM1605
Belts HDT 15 T20 1:1
Spindle Chinese 1.5KW water cooled
frame box 50x50x4mm
Digital drivers
CSMio/IM-M
Torus trafo 420
Soft start
Pliz safety relay
AB 24V DC
Power relay
I am limited with working size due to size of Milling machine.
All will be tig welded work started, but need your opinion before is too late.
Thank you for comments.
22-12-2016 #2
Looks good Tom. Are the gantry sides aluminium profile or lots of steel box sections joined together? Needs to be steel to get maximum stiffness on this critical area.
23-12-2016 #4
Looks good, I'd beef up the bed as it looks weak compared to the rest of your machine 😊
26-12-2016 #5
26-12-2016 #6
The other weak link will be the spindle clamp. Needs more clamping area or clamp top/bottom.
26-12-2016 #7
26-12-2016 #8
You have the rails bolted to the table, a very good start.
Second picture you go wrong. Your mind is stuck in 2D and it has put a terrible overhang on the router to gantry connection and compelled you to move the bed bearings out from under the gantry creating the awful L shape.
There is no reason why the Z axis slides have to clear the router head, they can go either side of it.
Do it again and think overhangs, think 3D
26-12-2016 #10
Small Fixed Gantry Router Spec and Build
By shaunrod in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 29-07-2016, 06:55 PM -
FOR SALE: fixed gantry router/mill up for grabs
By dazza in forum Items For SaleReplies: 9Last Post: 12-03-2015, 11:15 PM -
BUILD LOG: Monster fixed gantry router for aluminium & wood
By jonboycnc in forum DIY Router Build LogsReplies: 9Last Post: 12-01-2014, 11:26 PM -
BUILD LOG: Vertical fixed gantry. Design & build. (Steel/epoxy)
By Greeny in forum DIY Router Build LogsReplies: 8Last Post: 19-08-2013, 08:26 PM -
BUILD LOG: Fixed Gantry Router
By lateAtNight in forum DIY Router Build LogsReplies: 24Last Post: 28-05-2009, 11:30 PM
