That'll explain why it's come slack then. IIRC the original mount used 3 bolts, as the other corner is cutoff due to the head casting shape.
To the OP, if you search for my Triac retrofit thread, you'll find how I made a new spindle motor mount to fit a servo, along with some details to rebuild the spindle with new bearings.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
17-04-2018 #3
Also the spindle bearing is 20 odd years old, mine went and i had to change it.
Bearings don't last forever
17-04-2018 #4
My mod was quite a bit of work. I think the lathe work alone took about 3-4 hours, as it was a big lump of bar to hollow out.
Now I've had time, this post gives the process of renewing the bearings - http://www.mycncuk.com/threads/10344...8817#post88817
And the spindle motor mods start a bit further down that page - http://www.mycncuk.com/threads/10344...9732#post89732Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
18-04-2018 #5
Thanks to everyone who has replied, it really is very much appreciated.
Chaz-Tightening the two bolts holding the motor has eliminated nearly all the noise for now. However the top bearing support is still getting hot. Thanks very much for your rapid response and friendly advice.
MC- Thanks I will take a look at those links you have posted and hopefully get some ideas about a long term solution to mounting the motor.
Andy- I looked at an old post of yours on the Denford Forum and hoped that you might have some good advice. Did you replace your bearings like for like or did you upgrade when you made the swap?
Thanks again guys
18-04-2018 #6
18-04-2018 #7
I was lucky in that I had time to design a suitable mod, and didn't have to rush and make do with whatever I could my hands on.
If you want the fusion 360 files or any drawings, let me know and I can email them across. To design it I had to create a model of the head casting, so I could see what would/wouldn't fit.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
The Following User Says Thank You to m_c For This Useful Post:
18-04-2018 #8
Yet another Denford triac at fault!
By jamesgates1000 in forum Denford MillsReplies: 9Last Post: 23-02-2018, 04:43 PM -
Denford Triac Spindle control / ATC
By RocketBoy in forum Denford MillsReplies: 21Last Post: 24-01-2018, 12:35 PM -
3kw Chinese Spindle - ER20 denford triac question
By andy_con in forum Denford MillsReplies: 13Last Post: 03-11-2015, 10:14 PM -
Dell monitor making a funny noise !
By Lee Roberts in forum MonitorsReplies: 1Last Post: 13-09-2013, 12:11 PM -
Denford Triac Spindle Fault
By Sam_Smith in forum Denford MillsReplies: 5Last Post: 04-05-2011, 11:07 PM
