    Hi Guys, along with designing a cnc router I am also looking to buy a milling machine.
    I will use it manually prior to a CNC conversion.
    I have limited space in my garage so the max sizes are the WM18 /AMAT25 /AMAT30LV size.
    I have heard many good things re the Amadeal mils and them being belt driven and having a larger cutting area.
    I basically have a rough idea re drivers and board but I get confused re spindle speeds.
    Do you buy a seperate spindle and fit that with a VFD or do you modify the existing one. ??
    Also is there a way to determine the ball screw length easy enough, and are they end machined at all ?
    Where does the community purchase from ? Any recommended sellers at all ?
    As I am starting from scratch I will also need to buy cutters, clamping and a machine vice so I am trying to keep the cost of items to a minimum but not hinder quality.
    The machine is for hobby use only to make prototype parts in steal and aluminium.
    The mill will sit on a pre built workbench.
    Unfortunately I dont have space for Bridgeport sized machines.
    Any help appreciated.
    Thanks again
    Mike
  1. CONVERSION: Warco WM18 Mill Stepper motor advice
    By Gotty101 in forum Conversion Build Logs
    Last Post: 18-08-2018, 05:06 PM
  2. NEW MEMBER: Big hello from a total novice
    By Edendale in forum New Member Introductions
    Last Post: 29-01-2018, 11:03 PM
  3. NEW MEMBER: Heres me - a Total Novice
    By CrazeUK in forum New Member Introductions
    Last Post: 14-03-2017, 03:47 AM
  4. Total novice seeks advice on stepper motor drivers
    By R.Andersen in forum Motor Drivers & Controllers
    Last Post: 25-01-2012, 11:34 AM
  5. Total novice and lost
    By sfallan in forum Machine Discussion
    Last Post: 10-09-2010, 10:35 AM
