    Wal's Avatar
    Lives in Stockport, United Kingdom. Last Activity: 31-03-2024 Has been a member for 9-10 years. Has a total post count of 491. Received thanks 71 times, giving thanks to others 29 times.
    Thought I'd make myself a portable ice cream spoon/scoop - I've been going a to a fair few classical concerts recently and can't resist a Doddington's Double Ginger in the interval... You get a plastic spoon tucked into the lid, but they're pretty small and quite flexible - last thing you want in polite company is a lump of ice cream stuck to your specs... Anyway, I needed a bit more practice with F360 tool-paths so I modelled one up and got it made.
    Here's the 3D model:
    https://a360.co/2IrISAz
    And a few pics and videos of what I ended up with:
Name:	roughing contours.jpg
ID:	25944 Click image for larger version.
ID:	25945 Click image for larger version.
ID:	25946 Click image for larger version.
ID:	25947 Click image for larger version.
ID:	25948 Click image for larger version.
    It looks thin, but it's 7075 - it's as sturdy and unbendable as you could ever want it.
    Trickiest part of the job was flipping it to machine the reverse and timing the epoxy just right so it had enough viscosity (as it started going off) to get it into the void between the part and the table and then get the part registered/weighted down in position for it to set. And then releasing it. I boiled the part for twenty minutes, glue didn't fail (meant to fail at 70) - eventually used a combo of epoxy stripper followed by a blowtorch to get rid of a couple of lumps that refused to unstick...
    Ludicrous - as described by a friend.
    Anyway. Off to a jazz concert on Saturday where I'll be testing it...
    Wal.
    Brilliant Wal your work amazes me look forward to the next.
    Phill
  1. Aluminum 7075 15 and 20 mm pricing
    By driftspin in forum Marketplace Discussion
    Last Post: 21-06-2019, 12:17 AM
  2. Replies: 3
    Last Post: 28-04-2017, 10:18 PM
  3. RFQ: Joint assembly needed making from 7075 T6 billet.
    By dudz in forum Projects, Jobs & Requests
    Last Post: 06-11-2013, 11:26 PM
  4. 7075 Aluminium supplier?
    By m_c in forum Marketplace Discussion
    Last Post: 30-12-2010, 12:27 PM
