Thread: eMachineShop Upgrade
17-11-2022 #141
Chris, I have added you to the Dropbox folder. Good luck with the downloads. Regards.
01-12-2022 #142
If there's a chance you can help me out as well for a previous version: [email protected]
02-12-2022 #143
Should be sorted. I've added you to the Dropbox folder which gives you access to versions 1.932 and 1.935. Good luck.
11-12-2022 #144
Bladevane
Could you please possibly add me so i could get the older software, made the mistake of upgrading and can't export now, been frantically searching for the older software - [email protected] cheers!
13-12-2022 #145
All sorted. You should have access to versions 1.932 and 1.935 via Dropbox. Regards.
17-12-2022 #146
19-12-2022 #1473 axis CNC/router / Alu profile frame....25mm Alu Cutting bed X=500mm Y=300mm Z=110mm.....Supported 25mm X rails ....Supported 20mm Y rails....Supported 20mm Z rails.....2.2kw Chinese WC spindle..... CSLAB CSMIO/IP-M 4-axis Ethernet Motion Controller....M542 Drivers..SY60STH86-3008BF Motors...running....Mach3 / Cambam / Emachineshop.
04-02-2023 #148
Hi, Could you please link me to your dropbox list for the older version of EMS.
Thanks Ace
[email protected]Last edited by Ace; 05-02-2023 at 10:49 PM.
05-02-2023 #149
Ace, All sorted.
The Following User Says Thank You to Bladevane For This Useful Post:
15-02-2023 #150
Do you still have the dropbox for version 1.932 and 1.935? Could you add [email protected]?
There are currently 15 users browsing this thread. (0 members and 15 guests)
PC Upgrade Options?
By Chaz in forum General DiscussionReplies: 11Last Post: 31-08-2016, 04:53 PM -
Laser Upgrade
By dcrowder in forum Laser Machines & BuildingReplies: 8Last Post: 06-05-2016, 01:06 PM -
VFD upgrade
By paulus.v in forum Spindles & Drive MotorsReplies: 11Last Post: 05-11-2014, 11:09 PM -
Upgrade
By Dopy in forum General DiscussionReplies: 0Last Post: 09-11-2011, 01:57 AM -
BUILD LOG: Time for mk2 upgrade!
By routercnc in forum DIY Router Build LogsReplies: 16Last Post: 26-02-2011, 11:38 PM
